ac plug?
gmp
Denver,co
Hey all,
Im making a way way stripped down harness and there is a plug i cant figure out if i need or not.So on the loom right next to the knock sensor plug its trianlge shaped with three wires going in. I traced the wires 2 of them go to the white plug under the dash toward the driver side, The other a black w/ red stripe go's into the main harness plug bottom right looking at female end.
Guess the question is do i need it or can it be cut out like the rest if im not running ac?
Every ounce counts.
Likely the a/c plug, as that one is a three wire, triangle shaped plug.
