Galant VR-4 Forums » Galant VR-4 » General VR4 Discussions » source for electrical wire
belize1334
1334/2000
Galant VR-4 org Post #: 963762 posted 01/17/11 06:37 PM     Remind Me!  Send Private Message   Edit Post
I need to rebuild the harness for the passenger side of the engine (o2 sensor, temp sensors, etc) and I can't seem to source the striped wires necessary to keep the original color-code. Jegs had a few color options but not the ones I'm looking for. Does anybody know of a source for that stuff?
Roger B. Scott
'91 Belize Green
Posts: 3295 | From: Dundee, Scotland, UK | Member Since: 11/18/03 | IP: (174.45.93.14) | Report this post to a Moderator
TrendSetter
Galant VR-4 org Post #: 963772 posted 01/17/11 07:20 PM     Remind Me!  Send Private Message   Edit Post
try waytekwire.com
| | | IP: (70.119.231.122) | Report this post to a Moderator
Galant VR-4 org Post #: 963800 posted 01/17/11 10:32 PM     Remind Me!  Send Private Message   Edit Post
Waytek has striped wire, but custom ordered and expensive I think. How much do you need? colors and how long? I have a harness from a 1g that I have been canabalizing for years for matching wire colors.
91 VR4 855 Nile Black
92 VR4 828 Belize Green-SOLD
91 VR4 115 Nile Black -SOLD
Posts: 10602 | From: Michigan | Member Since: 03/05/01 | IP: (74.44.220.60) | Report this post to a Moderator
belize1334
1334/2000
Galant VR-4 org Post #: 963808 posted 01/17/11 11:22 PM     Remind Me!  Send Private Message   Edit Post
The wiring is nice and soft back where it passes under the TB but up by the water pipe it's brittle and broken, on top of the carnage that I reaped. Also, I'm missing the plug for the AC temp sensor (top temp sensor on water-neck).
The colors are variations on Green. G w/ B, G w/ Y, etc. How's that section on your spare harness? Intact? Nice and soft? If it's good to go I'd buy it off of you and then splice it in...
Roger B. Scott
'91 Belize Green
Muskrat
665/2000
Galant VR-4 org Post #: 963837 posted 01/18/11 07:02 AM     Remind Me!  Send Private Message   Edit Post
See if you can find a good condition wiring harness from a DSM or Galant in a junk yard. Get the whole thing, then de-pin wires from the ecu connector and pull the wires you need. You probably wont need to find a turbo model, just one with a 4g63 engine. Don't buy a JDM harness, some of their connectors aren't the same, and they use a different o2 sensor.
That's basically what I did and it worked out great. You'll get really good at de-pinning connectors too!
Brian L.
91 Galant VR-4 #665/2000
Edited by Muskrat (01/18/11 07:03 AM)
Posts: 2105 | From: Lexington, KY | Member Since: 06/13/04 | IP: (63.238.139.239) | Report this post to a Moderator
belize1334
1334/2000
Galant VR-4 org Post #: 963869 posted 01/18/11 10:50 AM     Remind Me!  Send Private Message   Edit Post
Unfortunately the junk-yard here leaves something to be desired as far as Mitsus go. That's what happens in a state thats nearly the size of california with less than a million residents. The last time I asked the guy at the desk he said that he just crushes DSMs on site because in this climate nobody is interested in rear-wheel-drive sports cars.
Roger B. Scott
'91 Belize Green
Galant VR-4 org Post #: 963880 posted 01/18/11 11:45 AM     Remind Me!  Send Private Message   Edit Post
I just fixed my 92 for all those wires this summer. I will look at my harness and see what I have and what colors I used for repair. It is not the same harness, just a body harness from a 1g.
RWD sports cars?
Posts: 10602 | From: Michigan | Member Since: 03/05/01 | IP: (12.1.210.228) | Report this post to a Moderator
Muskrat
665/2000
Galant VR-4 org Post #: 963933 posted 01/18/11 03:39 PM     Remind Me!  Send Private Message   Edit Post
Did you at least enlighten him that these cars are FWD or AWD, and therefore very desirable in that climate? Make HIM bang his head against the wall too!
Brian L.
belize1334
1334/2000
Galant VR-4 org Post #: 963941 posted 01/18/11 04:49 PM     Remind Me!  Send Private Message   Edit Post
Never try to enlighten the man who works at the junkyard. That's his turf and he doesn't take kindly to wise-asses.
I think I'll just get some spools of solid-color wire and match them as closely as I can... it's not perfect but I'm tired of this thing not running...
Roger B. Scott
'91 Belize Green
Edited by belize1334 (01/18/11 04:50 PM)
Posts: 3295 | From: Dundee, Scotland, UK | Member Since: 11/18/03 | IP: (153.90.194.143) | Report this post to a Moderator
Too Clean
1881/2000
50/1000
Galant VR-4 org Post #: 963950 posted 01/18/11 05:23 PM     Remind Me!  Send Private Message   Edit Post
FYI, the plug on the top of the thermostat housing is the same as the A/C pressure plug on DSMs.
-Jeff
1881/2000
50/1000
Posts: 7870 | From: KC, Missouri | Member Since: 08/08/04 | IP: (159.140.254.10) | Report this post to a Moderator
belize1334
1334/2000
Galant VR-4 org Post #: 963952 posted 01/18/11 05:27 PM     Remind Me!  Send Private Message   Edit Post
^^ Where is that on the harness? My A/C is gone so I don't really care about that sensor but as a matter of principle I'd like to avoid deleting harness plugs.
Roger B. Scott
'91 Belize Green
Too Clean
1881/2000
50/1000
Galant VR-4 org Post #: 963953 posted 01/18/11 05:31 PM     Remind Me!  Send Private Message   Edit Post
It's way in the front left, by the coolant overflow tank. Right next to the sensor for power steering.
-Jeff
1881/2000
50/1000
Galant VR-4 org Post #: 964002 posted 01/18/11 09:22 PM     Remind Me!  Send Private Message   Edit Post
Quoting jepherz:
Exactly the same, or "will work"? I had to repair that on 115 but I don't recall it being identical.
Posts: 10602 | From: Michigan | Member Since: 03/05/01 | IP: (74.36.86.18) | Report this post to a Moderator
Too Clean
1881/2000
50/1000
Galant VR-4 org Post #: 964014 posted 01/18/11 10:03 PM     Remind Me!  Send Private Message   Edit Post
Pretty sure its the same, ill check tomorrow.
-Jeff
1881/2000
50/1000
Posts: 7870 | From: KC, Missouri | Member Since: 08/08/04 | IP: (24.31.244.75) | Report this post to a Moderator
belize1334
1334/2000
Galant VR-4 org Post #: 964371 posted 01/20/11 03:56 PM     Remind Me!  Send Private Message   Edit Post
What about the little metal pins that go into these plugs? Can they be sourced or do I have to salvage them from the old brittle wires?
Roger B. Scott
'91 Belize Green
0 registered and 41 anonymous users are browsing this forum.
Generated in 0.272 seconds in which 0.246 seconds were spent on a total of 14 queries. Turbo powered.
