Timing Belt and Head Gasket question...
SleepinGVR4
Danville, Pennsylvania
I have a Power Enterprise Timing Belt on my car right now and was wondering after how many miles they should be changed? Should the Kevlar belts be changed as often as the OEM timing belts? I ask because I might very well need to tear my engine down and it only has 30K miles on it now.
I'm also using a Fel-Pro PermaTorque MLS Head Gasket. Can you reuse these head gaskets?
CutlassJim
Manchester, NH
Lol this is one of the big reasons I don't use big money non reusable parts. I have no dilutions that my engine will come apart before minimum factory recommended intervals. On that note I would reuse that timing belt at least until 60k. They are made stronger to take more abuse and or last longer. The headgasket I have no clue. I only run organic OEM.
I've seen those head gaskets reused plenty of times on v8s. Some people wont reuse them, some people reuse them quite a few times. It's going to come down to how it looks when you pull apart the motor.
dmj
orlando FL
I don't know about other people but I have never reused a head gasket simply because once you torque it down all sealing surfaces gets compressed around bolt holes ,waterjacket holes etc. When you reuse a 2nd time there is less to compress which can compromise the gasket ability to conform to any irregularities between the head and block. Ultimately the choice is yours.
