will this fit with 3kgt vr4 brakes?
Tre3zy
South San Francisco, CA
im wondering if this wheels will fit if i put my 3kgt vr4 brakes.... without putting spacers
Tre3zy
yea thats what i was thinking.... just wanted to clarify it thnx though..
-triz
boostedinaz
Scottsdale, AZ
The off set has little to do with the fitment of the brakes. Spoke design is more critical for brake clearence than offset. The offset could be 100% spot on but if the spokes curve in to much they could hit the calipers.
Spam
Las Cruces, NM
Those are the same wheels I was looking at getting for my new daily driver...BMW 318TI. Been trying to search the web hoping someone would have a review on them but no luck.
Universal lug pattern wheels are just ugly most times though. I'd try to find alternatives.
bobdole
U.K.
Brake clearence is low on that wheel I can tell you that. They will clear most standard brakes. But not BBK. Brake clearence is all in the back pad of the wheel. Nothing to do with the offsets.
Vman911
Douglas county, Ga
I had to use a 5/8" spacer on mine to clear my 17" axis rims. Ending up doing back to match but front sticks out a little further then the rear. Calipers just barely clear rims. Those rims look good.
Ralli380Gvr4
BOULDERADO/UWS-NYC/BURQUE
Quoting crankwalk:
I agree...not so much on them being ugly, but strongly agree on finding an alternative. Because knockoff's like xxr's and rota's seem unsafe and IMO are too good to be true. I googled "xxr wheels quality" and found MR2 forum.
You get what you pay for.
Might as well save for a set of oem Evo BBS's (forged=lighter, stronger and oem standards), found these on
Craigs in Cali
Tre3zy
cool thnx for looking out guys... like i said i just wanted to see what people think about them.... i was just gonna get this as a spare.... i am planning on running the BBS evo 9
Whoodoo
Binghamton, NY
There are tons of horror stories about knockoff wheels. I agree that they are form over function, but they still must meet minimum standards or else they would be sold under 'for offroad use only' status. I bet you all those broken wheels had been raced, or hot a massive pothole or something like that.
Wheels don't just break because your car is too heavy for them. Even a steel wheel will get messed up from running into a curb or pothole. The difference between a steel wheel and an aluminum knockoff is that steel bends but cast aluminum breaks due to small imperfections. Knockoffs work great for a road car and look good too, thats about it.
I agree that, for caliper clearance, offset doesn't play as much of a role as spoke design. Having a smaller offset will get you as much room as possible though.
RedTwo
New Zealand
The distance between the hub face and the back of the spokes is the critical part. I don't have the measurements at hand so, from memory, you need around 45-55mm to clear 'large' 4 piston calipers (Evo Brembos) and around 40mm to clear 'small' 4 piston calipers.
Tre3zy
hey guys i picked this up a set of borbet type e for my 5 lug swap....they are 17x8 +35 i was wondering if they are going to clear the 3kgt vr4 brakes.... here is wat the wheels look like:
click,r:3,s:0
