Galant VR-4 Forums » Galant VR-4 » General VR4 Discussions » Would this manifold setup interfer with the IC piping?
Boostdtalon
Member +++
Galant VR-4 org Post #: 851049 posted 11/19/09 09:29 PM     Remind Me!  Send Private Message   Edit Post
I have the possibility of purchasing a GT3076 for cheap from a friend and was looking at possible setups for it. Now i have seen the reviews they have on dsmtalk and tuners about this kit and how well it works for DSM's and i am interested in maybe purchasing it in the near future. Do you guys think this would kits setup of the external wastegate would interfer with the IC piping? I think it would be close, but i wanted ya'lls opinion on this.
ERL T3 manifold
Posts: 913 | From: Buckley, Wa. | Member Since: 10/15/09 | IP: (75.191.130.142) | Report this post to a Moderator
JNR
20/1000
Galant VR-4 org Post #: 851222 posted 11/20/09 10:49 AM     Remind Me!  Send Private Message   Edit Post
Would the wastegate even be very effective like that I know it'll 'work', but for good control and such. Also, seems like you'd be bringing a heat source closer to your IC piping.
Depends on how your IC piping is, I suppose. Mine sort of angles toward the radiator core support (front) and doesn't go over the middle of the manifold, so it would probably work on mine, as far as clearance and imagine most are setup this way.
Edited by JNR (11/20/09 10:53 AM)
Posts: 9750 | From: ca | Member Since: 04/23/04 | IP: (12.234.232.130) | Report this post to a Moderator
Boostdtalon
Member +++
Galant VR-4 org Post #: 851232 posted 11/20/09 11:07 AM     Remind Me!  Send Private Message   Edit Post
Well the wastegate would be effective as it would be central to the runners. My concerns would be like you said the heat transfer from the wastegate setup to the IC piping or even possible physical contact between the two.
Posts: 913 | From: Buckley, Wa. | Member Since: 10/15/09 | IP: (204.116.67.181) | Report this post to a Moderator
JNR
20/1000
Galant VR-4 org Post #: 851241 posted 11/20/09 11:37 AM     Remind Me!  Send Private Message   Edit Post
I know what you're saying, but if you think abut when the gate valve is open, it just seems a hard path for the gasses to follow up and around, while letting excess gasses spend the turbine (turbo). But, that may be overthinking it. I would think the ideal location would be right at/after the primary collector, coming off in a 90 or so. But, we just don't have the room, unless it were a totally custom manifold (i.e. runners coming up, then down, collector higher up).
Boostdtalon
Member +++
Galant VR-4 org Post #: 851245 posted 11/20/09 12:01 PM     Remind Me!  Send Private Message   Edit Post
Ok yeah I can see your point. It may affect the turbo but not very much to notice.
Hard Snarker
1051/2000
Galant VR-4 org Post #: 851271 posted 11/20/09 02:22 PM     Remind Me!  Send Private Message   Edit Post
It isn't so much that the gases have to follow a difficult path. The pressure is already in there, so releasing it is what controls boost. It would work just fine re: wastegate/boost-control.
-Mark
1051
Posts: 11900 | From: Yakima, WA | Member Since: 04/29/01 | IP: (97.90.49.2) | Report this post to a Moderator
Muskrat
665/2000
Galant VR-4 org Post #: 851289 posted 11/20/09 03:15 PM     Remind Me!  Send Private Message   Edit Post
^+1 the path is still less restrictive than going through the turbine and your exhaust system. Exhaust will follow path of least resistance.
Brian L.
91 Galant VR-4 #665/2000
Posts: 2105 | From: Lexington, KY | Member Since: 06/13/04 | IP: (12.188.154.180) | Report this post to a Moderator
JNR
20/1000
Galant VR-4 org Post #: 851291 posted 11/20/09 03:18 PM     Remind Me!  Send Private Message   Edit Post
True...I'm talking more of a part throttle condition though, where you're releasing some of the gas, but still allowing the remainder to pass to the wheel; just seems to not be 100% accurate that way, but again, this is overthinking it...Remember, it's not just pressure relief, but velocity occuring still, too (unlike the role of the blowoff valve)I'll be running my external off the turbo (on the o2 housing flange) and if it works there, should work here, too. Just not the 'perfect' setup.
Edited by JNR (11/20/09 03:20 PM)
bazeng
work in progress
Galant VR-4 org Post #: 851299 posted 11/20/09 03:56 PM     Remind Me!  Send Private Message   Edit Post
If you are running a GT30, run the intercooler pipe down low instead...
Australia's Slowest VR4
Posts: 2520 | From: Melbourne, Australia | Member Since: 02/06/03 | IP: (58.109.237.150) | Report this post to a Moderator
Boostdtalon
Member +++
Galant VR-4 org Post #: 851307 posted 11/20/09 04:34 PM     Remind Me!  Send Private Message   Edit Post
Yeah i was considering the under path especially since my car already has a radiator other than stock (neon) and i was considering going with a honda 1/2 setup. I looked at the ETS website and the GVR-4 on there pics has a under setup. so i guess going that route would allow use of the ERL kit and no interference with the IC piping.
Generated in 0.255 seconds in which 0.234 seconds were spent on a total of 14 queries. Turbo powered.
