Spring Rates for GVR-4
JSchleim18
Long Island, NY
I am thinking of going the route Nick at DSG did with the Evo MR suspension and Ground Control Coilover sleeves. I was wondering what would be a good spring rate for a car that's going to be around 3000 lbs dry. The car is going to be used mainly for a street car but it will see its days at a road race course. This means I want something a little stiff but feels good driving around town.
Thanks for the input.
Yao
Denver, CO
Going by memory, I think gvr4 and gsx are 150lb/in2 Front and Back, too soft. Evo is 180lb/in2 Front and 220lb/in2 or 240lb/in2 Fack. Forgot what H&R is.....
I used either 350F/275R or 350F/250R on my coilover setup per Ground Control advice.
496of2000
San Diego, CA USA
I'm using 2.5" gorund control springs 350 lbs. front and 250 lbs. rear. Which is streetable. Before, I ran 450 front and 350 rear kinda stiff for my daily driver.
I remembered you had those high rates before. I always wondered how you liked that for the street.
JSchleim18
Long Island, NY
Hmmm thanks for the replies. I was checking spring rates last night and I was considering a 350F/300R setup but I may go softer in the rear bc of the weight difference. I am relocating the battery to the trunk and at times will have an extra 100 Lbs. back there. Would it be wiser to get 275 or 250 in the rear? I appreciate the help fellas
atc250r
Orange County, NY
I know its a little bit apples to oranges but I'm running stock Evo 8 springs in the rear and the car rides very nicely. Not too hard or soft, just tight and the under steer is basically non-existent now. I'd say that the 250 or 275 rear springs would be fine.
John
atc250r:
You said your running th evo springs in the back? With what dampers? What do you have in the front?
JSchleim18
Long Island, NY
I figured I'll throw in the fact I'll be running a 22mm front swaybar and 26mm rear adj. bar.
496of2000
San Diego, CA USA
BTW, I have the whiteline 22mm front and 26mm rear adjustable bar. The 450/350 was kinda stiff, now have a wife and 9 month old kid to drive around. So I softened it up a bit.
atc250r
Orange County, NY
I have AGX's all the way around and 1G DSM springs in the front with about 3/4 of a turn cut off. I like it enough that I'm taking the suspension just the way it is out of the GVR4 and putting it into the GGSX I'm swapping my drivetrain into. Oh, and I have urethane bushings almost everywhere and a 1" (24mm) rear bar. It handles well enough that my buddy who owns a Z06 and builds performance Vettes and F-bodies for a living said he was very impressed by the ride and handling. I think I just unknowingly stumbled onto a good combo.
John
