Oh, and coming soon to a forum near you: How to repair a block with destroyed B.S journals.
Here is a preview. This is the first step in pluging the oil journals. This step is fairly inportant, but easy. I don't belive that anyone would ever beable to remove the philips head plug with out doing this step.
First, clean the threads with a wire brush:
Second, Thread on a 10mm nut (12mm or 13mm size wrench) on to the philips plug:
Third, Tighten snug. It will give you roughly half a nut to weld to:
Fourth, Weld the opening in the nut so that the nut and plug are welded together:
Fith, Remove the plug and repeat on the second plug for the inner B.S. bearing:
