Galant gsx clutch ?
cbr900turbo
Adamstown, PA
Im looking at picking up a GGSX with a bad clutch my question is what clutch and flywheel setup do they use. Im assuming they have a 1G awd trans and that would mean that they would use a turbo clutch disk and pressure plate setup?
Thanks,
Eric
actually from what i have read they are different. but i swapped in my eclipse flywheel wheel and exedy stage one clutch with the eclipse tranny and tcase and rear diff. the trannies are different there a huge debat about if the ggsx is actually worse the the vr4/dsm many believe it is.
atc250r
Orange County, NY
They do not have a 1G AWD trans. The trans the GGSX uses has different gears which are weaker and different ratios. I'm 99% sure that the clutch in a GGSX is different than that of a 1G/GVR4. Don't re-invent the wheel, just put a stock replacement clutch in it.
John
