Chip features
keydiver Unregistered
posted 04/03/03 05:05 PM
Well, not to open the floodgates or anything, but I'm trying to develop new "features" for my chip, especially new applications for the boost gauge. I can easily duplicate the function of any TMO gauges, like: 1) O2 meter 2) spark advance 3) injector duty cycle 4) Battery voltage, or 5) Octane For GVR-4's, Todd also usually gives a "magnified O2", but I'm not sure which part of the scale is magnified, I'll have to look at the interpolation. I plan to offer a single gauge, not selectable, with my chip, which is rewritten in such a way that it does not copy the TMO code. So, besides the above, what can you think of, new and different, that you think would be worthwhile? I've done a knock gauge for one guy, where each LED segment, except the first one, is worth 5 on the knock sum. I just did another one that will turn on the first 3 LED's when it reaches 6000 rpm, and the other 3 at 7000, sort of a 2-step shift light. I also did my own "magnified O2" where each segment is worth .02 volts, from .86 to .92 (the first 2 segments light together at .86). I'm looking for new, innovative ideas, and it has to be something the ECU monitors, like intake air temps, barometric pressure, airflow, fuel or spark related, coolant temperature, or TPS voltage. I could even try to do a combination, like airflow/rpm. I've even thought of connecting a MAP sensor to the EGR temperature sensor input, and actually making it work as a REAL boost gauge. So, any ideas you have will be considered. I HATE to be a me-too guy, but so far everything everyone asks for is stuff the TMO already has. And yes, I will have a version of the chip with stutterbox Jeff O.
| | | IP: (67.34.209.188) |
theymightbegalants Unregistered
posted 04/03/03 05:28 PM
| | | IP: (134.10.23.206) |
posted 04/04/03 09:20 AM
quote: Originally posted by udriveu: jeff, i've been meaning to ask you something. when you are at the gauge selection stage (before the engine is on) what gauge is set on the 6th segment?
"For GVR-4's, Todd also usually gives a magnified O2"
| | | IP: (68.158.97.225) |
posted 04/04/03 09:31 AM
quote: Originally posted by Ash: I 2nd this question, and will I be able to get one from over here somehow. I really want a stutterbox.
Ash, when can one of you guys send me a stock chip? I can work from a binary file or an EPROM, whichever is easier for you. Jeff O.
posted 04/04/03 09:41 AM
quote: Originally posted by spoulson: I also vote for knock sensor display. But to have selectable gauges would be even better, mostly for troubleshooting purposes.
I know selectable gauges would be the best, but unless TMO makes their stuff shareware, I'll won't be offering that. For now, in my FREE GVR-4 chip, I will offer one gauge, customer's choice, one stutterbox rpm (that doubles as a clutchcut rpm if I use the code I have written now), no fuelcut, rev limiter increase, octane reset, and probably A/C cutout at 90% throttle. These are all things I'm able to do without using ANY of TMO's code. More advanced options, like injector correction, fuel or timing map remapping, etc, will probably NOT be free, but cheap Any new ideas? Jeff O. #1886/2000
posted 04/04/03 09:50 AM
quote: Originally posted by theymightbegalants: You mentioned each bar was worth 5 counts of knock, except the first one. How much is that one worth?
3, I think. The actually steps between most of the LED's is 2, but the first step is only one, so its only half a step and should be 2 or 3. The 2nd LED is 5, the 3rd LED is 10, 4th LED is 15, etc.
quote: Originally posted by theymightbegalants: I'd also thought of modifying it to work as a shift light, but I was going to make it progressive instead of a two step. For example, have the first light come on at 6k and have each light be worth 250 rpm.
That could be done, no problem. However, the boost gauge is a little slow responding, and may lag too much to be usable at such resolution. If I have some time this weekend, maybe I'll give it a try.
quote: Originally posted by theymightbegalants: If you're only doing one gauge, will the buyer get to choose which one?
Yes. But I need more ideas. I'm going to cross-post this in the Yahoo groups too, so sorry to any of you guys who have to read this twice.
meshwork Unregistered
posted 04/04/03 01:35 PM
quote: Originally posted by spoulson: What is 'octane reset'? And how is the ECU able to determine octane rating?
If the ECU detects a lot of knock, it will keep lowering the value in one memory address, which causes it to use less aggressive timing, because it thinks you have a bad tank of gas. This feature resets the value to maximum every time you start the car, so you always start with peak performance.
| | | IP: (216.178.83.214) |
posted 04/04/03 06:43 PM
quote: Originally posted by keydiver: quote: Originally posted by theymightbegalants: I'd also thought of modifying it to work as a shift light, but I was going to make it progressive instead of a two step. For example, have the first light come on at 6k and have each light be worth 250 rpm.
I realize it's a bit slow to respond, which is why I suggested it start as low as 6k... so as soon as you start to see 'em light up, you grab for that gear. Just an idea; I don't think I'd go for the shift light option on my chip anyway.
Gvr4-330 I feel of the short bus 330/2000
posted 04/04/03 09:13 PM
quote: Originally posted by keydiver: and probably A/C cutout at 90% throttle.
I would LOVE an A/C cutout. I always thought this was a great feature of the TMO chips.
And THANKS so much for making these chips. I know it must be a lot of work for you.
Rob
Posts: 1543 | From: DC | Member Since: 12/30/01 | IP: (68.100.212.81) |
howard Unregistered
posted 04/05/03 09:19 AM
quote: Originally posted by a_santos: Is it possible to have it read oil pressure?
No.
| | | IP: (129.120.56.72) |
