Galant VR-4 Forums » Galant VR-4 » General VR4 Discussions » Brake, Alternator and ABS lights came on?
OneTitle to rule them all.
77/2000
Galant VR-4 org Post #: 51862 posted 08/27/02 11:56 PM     Remind Me!  Send Private Message   Edit Post
Just before I was parking the car tonight my ALT and ABS lights flicked on for a second, went out and as I was parking they came on again -- this time I noticed that the E-Brake light was on also... with no apparent affect.
If it wasn't for the E-brake light, I would have assumed that my alternator belt was loose or something (I do get a bit of a "warm" smell, but no audible slippage). I have all new belts and honestly haven't checked the tension in 300 miles.
BUT, the E-brake light? The brake wasn't touched -- handle is down all the way.
As Bob in Chicago suggested (regarding some idle problems) I should check my ECU for capicator leakage. Could this strange behavior be ECU-related or alternator/belt related?
Any help would be appreciated -- I'll investigate further tomorrow, just wanted to "troll" a little bit before hand. Thanks.
-Ryan
Posts: 13499 | From: Chicago, IL | Member Since: 07/29/02 | IP: (67.36.184.174) | Report this post to a Moderator
4g63t
Galant VR-4 org Post #: 51863 posted 08/28/02 03:38 PM     Remind Me!  Send Private Message   Edit Post
About a week ago my alt and parking brake lights came on and they would stay on whenever the car car was running. I checked everything - all wires, connections,etc... but nothing was wrong anywhere. (caps were done a while back) Then I had a leak in my exhaust system fixed and the lights went out and haven't given me a problem since. My experience w/ it probably doesn't help you at all - just really weird.
Posts: 2073 | From: Lancaster PA | Member Since: 01/31/02 | IP: (65.179.80.213) | Report this post to a Moderator
howard
Galant VR-4 org Post #: 51864 posted 08/28/02 05:58 PM     Remind Me!  Send Private Message   Edit Post
Just to add to the confusion, I have a
year old Mitsu 90 GVR4 90 amp alternator, fresh caps, all grounds intact, and out of the blue my dash warning lights have begun to flicker at 6K rpm and up. The battery connections are solid, and I have no clue why this is happening.
| | | IP: (129.120.56.205) | Report this post to a Moderator
Ian M
waiting for the bus
487/2000
Galant VR-4 org Post #: 51865 posted 08/28/02 06:18 PM     Remind Me!  Send Private Message   Edit Post
The ALT,Brake,and ABS lights will all come on when the alternator is going out. Check the voltage at the battery while its running,you should see around 14.4 volts. Mine did it off and on,when the lights came on,Id see about 12.5v -when the lights went out,Id see 14.4. I replaced the alternator and it hasnt done it since. Unfortunatly,your alternator being only a year old isnt a guarantee,it doesnt seem you can get a good quality reman alternator anymore,and even the factory ones are usually reman too...
Posts: 2342 | From: Martinsburg,WV | Member Since: 01/11/02 | IP: (129.71.114.112) | Report this post to a Moderator
howard
Galant VR-4 org Post #: 51866 posted 09/02/02 08:46 AM     Remind Me!  Send Private Message   Edit Post
quote:
Yeah, fortunately, this "new" factory one was free, but you're right, it does say something about being remanned by Mitsu on it. I can't believe I thought it would be a better quality reman than the crappy autoparts stores alternators.
| | | IP: (129.120.56.207) | Report this post to a Moderator
howard
Galant VR-4 org Post #: 51867 posted 09/06/02 10:29 AM     Remind Me!  Send Private Message   Edit Post
Well, after replacing the 1 year old Mitsu reman alternator, the car works great again. SinceI needed the car to run PRONTO for my wedding + honeymoon this weekend, I put in an AutoZone 75 amp reman, which is working well (for now).
I've never had an O2 housing heat shield, so now that I'm on my 3rd or 4th alt, I'm going to make a small heat shield for it.
| | | IP: (4.47.85.160) | Report this post to a Moderator
Kibo
Galant VR-4 org Post #: 51868 posted 09/08/02 03:34 AM     Remind Me!  Send Private Message   Edit Post
Howard, could you use a stock 1G/GVR4 lower heat shield? I've got one I can send you if you'd like, but I'm sure you could find something like that locally pretty easily.
Erik A.
#206/1000
| | | IP: (206.196.136.231) | Report this post to a Moderator
ken inn
BJ Titsengolf lifer
Galant VR-4 org Post #: 51869 posted 09/08/02 07:42 AM     Remind Me!  Send Private Message   Edit Post
howard got married yesterday, and is on his honeymoon.
Posts: 7529 | From: krum texas | Member Since: 02/23/01 | IP: (4.47.36.231) | Report this post to a Moderator
DongeR
Galant VR-4 org Post #: 51870 posted 03/14/03 03:05 PM     Remind Me!  Send Private Message   Edit Post
I went tuning/logging yesterday in the rain. Stupid me...I know how alternators near the bottom of the engine tend to get soaked by water. I had this happen in 2 other cars. Whelp my abs, battery, and brake light came on and now im waiting for my alternator to die. what was the quote from one of our members. "This car frustrates me so much. But I still love her."
So..mitsubishi alternator or kragen/pepboys brand? any suggestions appreciated.
DongeR615
| | | IP: (63.201.88.120) | Report this post to a Moderator
DongeR
Galant VR-4 org Post #: 51871 posted 03/14/03 09:59 PM     Remind Me!  Send Private Message   Edit Post
oh yea does anyone know if the 90 amp alternator for the DOHC automatic galant will fit in our vr4's. I looked at the service manual and it says that we use a 75 amp alternator.
DongeR615
| | | IP: (63.201.91.242) | Report this post to a Moderator
77/2000
Galant VR-4 org Post #: 51872 posted 03/14/03 10:54 PM     Remind Me!  Send Private Message   Edit Post
Shit.
I believe that OEM is the way to go. And secondly, you can never be sure -- new and reman alternators can die hours after you install them.
Eww.. good luck changing that alternator. It sucks. I think there's been some discussion on it here, do a search -- might have been Ken Inn with the details....
Posts: 13499 | From: Chicago, IL | Member Since: 07/29/02 | IP: (64.108.201.168) | Report this post to a Moderator
howard
Galant VR-4 org Post #: 51873 posted 03/15/03 08:46 AM     Remind Me!  Send Private Message   Edit Post
First off, I recommend buying the factory alternator, it's about $200.
Second, GVR4's came with the 90 amp model from the factory, not the 75.
| | | IP: (4.3.175.131) | Report this post to a Moderator
DongeR
Galant VR-4 org Post #: 51874 posted 03/15/03 01:57 PM     Remind Me!  Send Private Message   Edit Post
quote:
anyone got a used working alternator they want to sell me?
Will this bolt on onto our cars?
91-96 Mitsubishi,Diamante,3000GT, ALTERNATOR
DongeR
atsiauto
Galant VR-4 org Post #: 51875 posted 03/15/03 02:59 PM     Remind Me!  Send Private Message   Edit Post
do an interchange theres about 5 dif cars that had the same alt as ours I pulled mine off a colt or mirage or some dookie.
Posts: 1575 | From: Richmond Va, | Member Since: 10/21/02 | IP: (68.57.152.6) | Report this post to a Moderator
Generated in 0.264 seconds in which 0.213 seconds were spent on a total of 14 queries. Turbo powered.
