Saturn Exhaust Mannifold studs
Possible replacement for exhaust manifold studs which will permit you to remove studs for easier exh. mannifold removal: Saturn p/n 11518152 under $10 for a set. The Saturn studs have a male torx head so you can turn them in or out without double nutting. And you don't need the torx wrench cuz a 6mm 6-pt socket does the trick. Or is it 5mm? Middle age is setting in. I hope you can access this photo:
http://forums.rennlist.com/rennforums/attachment.php?attachmentid=126912&stc=1
slugsgomoo
Tacoma, WA
that sounds pretty nice. they are the correct thread size & pitch? Is there a discussion about it on rennlist? you do have to be registered to see the image though, so here it is
ken inn
krum texas
those nuts are copper COATED. copper aint magnetic, these nuts are. the later style bmw nut has a larger "shoulder" and an alloy helicoil. they are really trick
JB
MA
Link and price?
JB
MA
I thought Ken was talking about a different stud, i was inquiring about for info on it. /ubbthreads/images/graemlins/banghead.gif /ubbthreads/images/graemlins/blush.gif sorry about that.
G
zompton
ken what's that dam bmw part # again ?
BMW nuts are about $2.50 EACH and you need 9. Not in my budget for a one-time-use item.
ken inn
krum texas
18 10 7 523 805
i also upgraded to ss studs. cost more, but i consider it cheap insurance. the bmw nuts NEVER come off by themselves, but when you need to, they are easy to remove, and i have reused them. the "shoulder" is really big and thick. they fit perfect.
