Galant VR-4 Forums » Galant VR-4 » General VR4 Discussions » 89-92 and 93-94 DSM rear calipers?
Larry Parker
Rally Member
Galant VR-4 org Post #: 328912 posted 04/17/06 08:29 AM     Remind Me!  Send Private Message   Edit Post
I have run the stock 92 rear calipers in my rally car for a while now and I need to get some new parts.... I see that 92's and 93's have a different brake pad?? Anyone know the difference in the parts? I have a set of 4 pistons brembos that I plan to use, but not until i finish my front setup... Which wont be till after STPR.... NO TIME!!
LP
Parker Rally Sport/Hotbits tuning USA
Rally America #622
OPEN class
Posts: 1092 | From: Metro detroit | Member Since: 02/11/04 | IP: (204.80.222.11) | Report this post to a Moderator
Tom_N
Galant VR-4 org Post #: 328915 posted 04/17/06 08:32 AM     Remind Me!  Send Private Message   Edit Post
Only difference I can think of would have to do with abs.
The actual rotors and calipers are the same size and take the same pads.
| | | IP: (24.73.194.14) | Report this post to a Moderator
Lucian Bartik
Galant VR-4 org Post #: 328966 posted 04/17/06 10:01 AM     Remind Me!  Send Private Message   Edit Post
edit: Fixed VR4 piston size
early 89-90 dsm pads different.
MR389566 90-94 all same. same as e39a galant vr4 too. I double checked this with actual car VINs.
1g AWD:ad35p, ~35mm piston
vr4: ad35p, ~35mm piston
1g DSM NT ABS: 30mm
1g FWD turbo: 30mm
2g FWD: 35mm piston
2g AWD: 38mm piston and ++rotor diam. this is according to the tech manual, the service manual says that ALL 2g have identical 35mm rear braking systems
Edited by Lucian Bartik (04/17/06 11:28 AM)
| | | IP: (71.211.12.39) | Report this post to a Moderator
joec
or maybe lick the biss
/2000
Galant VR-4 org Post #: 328969 posted 04/17/06 10:18 AM     Remind Me!  Send Private Message   Edit Post
Maybe they changed the pad compound? Organic vs metallic? Or some sort of EPA regs that forced them to change the compound?
1991 GVR4 1630/2000 (sold)
Posts: 1141 | From: Westchester, NY | Member Since: 01/02/03 | IP: (64.238.194.14) | Report this post to a Moderator
Lucian Bartik
Galant VR-4 org Post #: 328999 posted 04/17/06 11:29 AM     Remind Me!  Send Private Message   Edit Post
Made mistake above on VR4 piston size, fixed now.
Galant VR-4 org Post #: 329061 posted 04/17/06 02:16 PM     Remind Me!  Send Private Message   Edit Post
They should all interchange. I think there was a slight thickness change when they added shims. That is the only difference I can see in CAPS.
91 VR4 855 Nile Black
92 VR4 828 Belize Green-SOLD
91 VR4 115 Nile Black -SOLD
Posts: 10602 | From: Michigan | Member Since: 03/05/01 | IP: (12.1.210.225) | Report this post to a Moderator
0 registered and 37 anonymous users are browsing this forum.
Generated in 0.209 seconds in which 0.196 seconds were spent on a total of 14 queries. Turbo powered.
