Galant VR-4 Forums » Galant VR-4 » General VR4 Discussions » Car cuts off when reaching Normal Op Temps
Hittman
my title is ghey
Galant VR-4 org Post #: 1248051 posted 12/28/19 08:44 PM     Remind Me!  Send Private Message   Edit Post
1990 JDM Galant VR4
After installing the Plazmaman IC setup, once my car reached operating temps it would randomly shutoff
I did some research and saw that possibly a failing TSTAT could cause this issue, so I replaced it today, and still am having the same issue...
Any ideas on what else it could be?
JDM e39a
Posts: 471 | From: Northern VA | Member Since: 09/11/09 | IP: (50.242.216.77) | Report this post to a Moderator
raptorWagon
1350/2000
362/1000
Galant VR-4 org Post #: 1248052 posted 12/29/19 07:59 AM     Remind Me!  Send Private Message   Edit Post
That sounds more like a failing ECU temp sensor (2 prong one) problem than the Tstat causing the issue. If the signal from the temp sensor is non-existent, it will trigger the ECU to shut the engine off as a fail safe when it reaches operating temp. So check your wiring for breaks in the wires at the connector. The wiring in that area gets brittle over time and tends to break apart.
Also, how do you like the Plasmaman IC kit? I had been eyeing that for a while, but was unsure.
92 Galant VR-4 362/1000
76 Galant Hardtop
79 Galant Sigma Wagon
88 Fiji Blue Starion
94 Montero SR
Posts: 2778 | From: Oak Harbor, WA | Member Since: 05/17/07 | IP: (2601:601:4500:52) | Report this post to a Moderator
Hittman
my title is ghey
Galant VR-4 org Post #: 1248053 posted 12/29/19 09:30 AM     Remind Me!  Send Private Message   Edit Post
So the 2 prong sensor on the bottom of the thermo housing?
The kits quality looks nice, but the fitment was far from OEM, between working with plazmaman and doing some research here on the forum, I got it to fit, definitely NOT worth the money I paid IMO, but I couldnít find any full lightly used or ďnewĒ ETS kits at the time.
JDM e39a
Edited by Hittman (12/29/19 09:31 AM)
Posts: 471 | From: Northern VA | Member Since: 09/11/09 | IP: (2600:1003:b115:f) | Report this post to a Moderator
A hole
820/1000
1837/2000
Galant VR-4 org Post #: 1248056 posted 12/29/19 02:51 PM     Remind Me!  Send Private Message   Edit Post
The ECU doesn't have any fail safe features built into it. The ECU (especially in stock form) will run the car bone cold or until the engine seizes from overheating. The only thing the ECU will do to save the engine is pull timing when overly hot or after sensing knock. If the ECU is killing the car, it's because it's failing.
Is the car shutting down, or dying? Shutting down meaning the entire thing goes dead (dash, engine, fuel pump, etc), or dying meaning the engine dies/ceases to run until restarted? Depending on the condition, it could be anything from a failed component to a tune issue caused by a simple vacuum leak. If you could describe the symptoms better, we could possibly help better.
820/1000
1837/2000
1546/2000-SOLD
1813/2000-SOLD
Posts: 3431 | From: SoCal | Member Since: 01/02/12 | IP:
(2600:1012:b149:4) | Report this post to a Moderator
raptorWagon
1350/2000
362/1000
Galant VR-4 org Post #: 1248060 posted 12/29/19 06:22 PM     Remind Me!  Send Private Message   Edit Post
It most definitely will shut off the engine, if the ECU is getting no signal from the ECU coolant temp sensor.
76 Galant Hardtop
94 Montero SR
A hole
820/1000
1837/2000
Galant VR-4 org Post #: 1248061 posted 12/29/19 07:18 PM     Remind Me!  Send Private Message   Edit Post
No, it won't.
If there's no signal from the CTS, the ECU may over-fuel during a warm start because it thinks the car is cold, which will lead to a no start condition. But the ECU won't simply kill the engine if there's no signal from the CTS.
Go start your car, and unplug the sensor...I guarantee you the car stays running no problem.
Again, there's no kill or fail safe features built into the DSM/Galant ECU aside from the timing adjustments I mentioned above. If you've read or understood otherwise, it was misinformation.
820/1000
1837/2000
1546/2000-SOLD
1813/2000-SOLD
Hittman
my title is ghey
Galant VR-4 org Post #: 1248064 posted 12/30/19 06:16 PM     Remind Me!  Send Private Message   Edit Post
Exact symptoms are as follows:
Start car normally, idles great, drives fine, no issue.
Once the needle on the temp gauge reaches the halfway point, while driving, only when switching gears or when the idle goes lower than 1500RPM, it INTERMITTENTLY cuts the car off, all lights are on, radio, all electronics are still on, and even if I engage in gear (while still rolling) it will cut the car back on. (I had a similar issue with the IAC on my first Galant, as well as my Evo, but the only difference was I had come to a complete stop when the cars would cut)
I played with the wiring to said temp/ecu sensor today and lo and behold had no issue at all. So if it is indeed this area that is the culprit, I suspect that the actual wiring to the sensor may be in need of replacement.
JDM e39a
Hittman
my title is ghey
Galant VR-4 org Post #: 1248065 posted 12/30/19 08:59 PM     Remind Me!  Send Private Message   Edit Post
So just parked it, after driving, idle struggles a bit and then engine just cuts off.
JDM e39a
Posts: 471 | From: Northern VA | Member Since: 09/11/09 | IP: (2600:1003:b12e:f) | Report this post to a Moderator
A hole
820/1000
1837/2000
Galant VR-4 org Post #: 1248066 posted 12/30/19 09:31 PM     Remind Me!  Send Private Message   Edit Post
Sounds like a vacuum leak. Did you boost leak test the car after the intercooler install?
820/1000
1837/2000
1546/2000-SOLD
1813/2000-SOLD
I ain't no puny human
866/1000
Galant VR-4 org Post #: 1248067 posted 12/31/19 04:56 AM     Remind Me!  Send Private Message   Edit Post
Stock ECU? BOV recirculated or vented?
Thom
Posts: 894 | From: Indianapolis, IN | Member Since: 09/24/14 | IP: (2600:1700:6c83:0) | Report this post to a Moderator
gvr4bnr
Newbie
Galant VR-4 org Post #: 1248068 posted 12/31/19 08:50 PM     Remind Me!  Send Private Message   Edit Post
So usually when something goes wrong, it's the last thing you touched. A boost leak test could reveal the issue.
I will throw out there, that the coolant temp sensor might not be that far off as the answer. The ECU will switch over to closed-loop at about 130* during warmup, which would be right where you said the issue starts to happen. If you could somehow lock the ECU in open-loop, it would be interesting to see if the issue goes away.
Posts: 1 | From: rochester michigan | Member Since: 07/24/19 | IP: (96.27.14.116) | Report this post to a Moderator
Hittman
my title is ghey
Galant VR-4 org Post #: 1248073 posted 01/02/20 02:19 PM     Remind Me!  Send Private Message   Edit Post
Havenít boost leak tested yet, but will this weekend if itís not solved.
Stock ECU, with an Evo 8 BOV, recirc.
I think it this is boost related, I may have found the issue, but Iím not sure the best way to fix it yet.
The line that ran from the boost solenoid/actuator and Tíd off to the LICP on the stock setup...there wasnít any spot on the new setup to plug it in, so I just cut it and didnít think much of it. If this is the issue should I just plug it, or tap into the LICP like the stock setup?
JDM e39a
Edited by Hittman (01/02/20 02:20 PM)
Posts: 471 | From: Northern VA | Member Since: 09/11/09 | IP: (2600:1003:b115:7) | Report this post to a Moderator
0 registered and 18 anonymous users are browsing this forum.
Generated in 0.364 seconds in which 0.309 seconds were spent on a total of 14 queries. Turbo powered.
