Galant VR-4 Forums » Galant VR-4 » General VR4 Discussions » 848/1000 new project build.
Lesac
Galant VR-4 org Post #: 1245026 posted 01/01/19 09:01 PM     Remind Me!  Send Private Message   Edit Post
Years ago I owned a 91 rust bucket and even after 20 or so other cars, Iíve always missed the vr4. When I saw the opportunity to acquire another one I jumped on it, maybe too anxiously, maybe not. Time will tell. I plan on documenting the process of turning what I hope is not a can of worms into a very unique daily driver. Anyway here she is. Ill be posting updates pretty regularly, as long as this car isnt a total pile.
the day I purchased the car after a long delivery ride.
and yesterday after a needed wash.
I know for certain the car needs an alternator belt, valve cover gasket, rear diff seal, and most importantly new fuel line. the current braided line leaks like a fountain. new line has been ordered and I cant wait to fire the car up for the first time.
736/2000 sold
848/1000 current daily
Edited by Lesac (01/01/19 09:21 PM)
Posts: 37 | From: OMAHA | Member Since: 12/09/18 | IP: (2600:8804:0:b800) | Report this post to a Moderator
Eztoril
1450/2000
Galant VR-4 org Post #: 1245028 posted 01/02/19 12:17 AM     Remind Me!  Send Private Message   Edit Post
Congrats. Came out lookin nice after the wash. I would add a timing belt and water pump service to that list if you dont know when it was changed last. Looks like a nice car that can be restored to dd status.
91 GVR4 1450/2000
2.3 Stroker
HKS cams
FP 3052
Spal puller
EVO MAF 3"intake
EVO8 560 injectors
EVO8 ECU tephramod v7
Walbro 255
FRH intake mani
EVO3 exhaust mani
44mm tial wg
EVO3 tranny
Posts: 51 | From: Irvine CA | Member Since: 08/31/16 | IP: (2600:387:8:11::a) | Report this post to a Moderator
Lesac
Galant VR-4 org Post #: 1245031 posted 01/02/19 08:37 AM     Remind Me!  Send Private Message   Edit Post
The car actually has full detailed service records to about 120k miles, showing records of both. It has 170k on it now, but looks like the timing belt has been replaced since then after I took off the cover. Was looking underneath and has rust, but Iíll see how bad it is and if any of it is fixable.
736/2000 sold
Posts: 37 | From: OMAHA | Member Since: 12/09/18 | IP: (2620:0:1029:fd00) | Report this post to a Moderator
Lesac
Galant VR-4 org Post #: 1245036 posted 01/02/19 07:08 PM     Remind Me!  Send Private Message   Edit Post
Well, waiting on parts today but had a short time to work on the car.
Valve cover and COPs came off for cleaning and new gasket as it was clearly leaking. Here are some in progress photos.
you can see in my photos above how dirty and gross the parts were.
here it is with the COP setup taken off.
after sand blasting
and after some nice red paint
and the coil cover after a blast and some new stainless hardware
slow progress, but im glad I got to do something.
736/2000 sold
Edited by Lesac (01/02/19 07:11 PM)
Lesac
Galant VR-4 org Post #: 1245103 posted 01/12/19 07:05 PM     Remind Me!  Send Private Message   Edit Post
full day in the garage today but productive.
-drained fuel tank
-replaced supply fuel line from tank to fuel rail
-installed new inline fuel filter
-replaced fuel line from fuel rail to FPR
-remounted FPR
-made a new mount for new fuel filter
-installed alternator belt
-unfroze front caliper
-probably more. I don't remember.
anyway after struggling a bit the car fired up for the first time. I have no way of telling when the last time the car ran was, besides what the previous owner had told me, however I have a feeling the car sat for much longer than stated.
wanted to get a few more pictures but between fixing and running around for parts, it didnt happen.
So happy the car runs. although lethargic to rev, I have a feeling that the giant tumble weed that came out of the exhaust may have something to do with that. Another day of work on the car tomorrow and I should be able to take it around the block at least. Forward progress is good, but it still needs a decent amount.
all that junk came out of the tail pipe after it started.
736/2000 sold
138/2000
Galant VR-4 org Post #: 1245104 posted 01/12/19 07:20 PM     Remind Me!  Send Private Message   Edit Post
Nice save, car is coming along.
The lethargic throttle feel could be from the cruise control unit, check it out and make sure all the cables are adjuated.
138/2000
Posts: 3527 | From: Klamath Falls, Or | Member Since: 07/27/11 | IP: (71.89.204.234) | Report this post to a Moderator
Lesac
Galant VR-4 org Post #: 1245107 posted 01/13/19 05:38 AM     Remind Me!  Send Private Message   Edit Post
Thanks for the tip, Iíll look into that today.
736/2000 sold
Galant VR-4 org Post #: 1245108 posted 01/13/19 12:51 PM     Remind Me!  Send Private Message   Edit Post
Or there is more of that mouse nest clogging the exhaust. Blocked exhaust can cause very poor performance.
91 VR4 855 Nile Black
92 VR4 828 Belize Green-SOLD
91 VR4 115 Nile Black -SOLD
Posts: 10651 | From: Michigan | Member Since: 03/05/01 | IP: (2600:1702:5a0:37) | Report this post to a Moderator
Lesac
Galant VR-4 org Post #: 1245110 posted 01/13/19 02:34 PM     Remind Me!  Send Private Message   Edit Post
went to go unclog the exhaust and and see if i could make the car run better today, but before i did anything, I figured a compression test is in order.
I got arround 130 for 1,2, and 4 but cyl 3 only shows about 80psi for compression so my thought is possibly headgasket or who knows. I also think there may be a mouse nest in the exhaust but im less concerned until the car runs on all 4 cyls again. (after doing quite a bit of research, I have a few things im going to try before writing off this engine)
as of now im considering just scrapping the engine that is in it since it has 170k of very beat miles and quite a bit of unknown history. I will definitely keep going and get the car up and running but im not sure what the best option is yet.
736/2000 sold
Edited by Lesac (01/13/19 03:22 PM)
Lesac
Galant VR-4 org Post #: 1245125 posted 01/14/19 06:46 PM     Remind Me!  Send Private Message   Edit Post
Worked on the car today with great success.
Verified spark
Verified compression. This was huge as all cyls are in awesome shape.
Verified all injectors are firing but 2 and 3 are completely clogged.
This is awesome news since I know exactly what has to be done to make the car run. Iím going to start by cleaning them, I was told they are 850cc but if that doesnít work I havenít decided if I will be sending them off for cleaning or just purchasing new ones.
736/2000 sold
Lesac
Galant VR-4 org Post #: 1245146 posted 01/20/19 07:46 AM     Remind Me!  Send Private Message   Edit Post
took the injectors to a local a few days ago to see if there was any way they could be saved. After an hour of messing with one, we decided it was best to just start over. New FIC 850ccs arrived! plugged them in and the car fires right up and runs great. I have a large oil leak coming from somewhere above the oil filter adapter, so my thought is it could be the gasket for that or the balance shaft seal. either way Ive ordered all seals and gaskets associated with the oil pump and front cover on the engine. Once those get here next week I can solve that issue and move on to its first drive. Getting excited as Ive had the car a month and havent been able to drive it yet.
736/2000 sold
Lesac
Galant VR-4 org Post #: 1245163 posted 01/22/19 07:40 AM     Remind Me!  Send Private Message   Edit Post
removed all the accessory belts and timing covers yesterday to try and find the source of my oil leak. Turns out I was right. The balance shaft seal is spraying like a fountain. Good news is that appears to be the only leak. Everything is super dirty however. Ill be cleaning and repainting everything while im waiting for parts to come in. Ill get some more pictures soon.
736/2000 sold
Posts: 37 | From: OMAHA | Member Since: 12/09/18 | IP: (2620:0:1029:f:6c) | Report this post to a Moderator
Lesac
Galant VR-4 org Post #: 1245198 posted 01/26/19 11:41 AM     Remind Me!  Send Private Message   Edit Post
Had about an hour this morning to work on the car. Good news is that the balance shaft seal was definitely the issue. A non OEM seal must have been used as it was black instead of brown and literally fell out when I removed the balance shaft sprocket. So now that the oil leak is fixed tomorrow Ill be able to reassemble the timing cover and all the accessories then (fingers crossed) be able to take it on its first drive! (probably to find more problems)
736/2000 sold
Lesac
Galant VR-4 org Post #: 1245469 posted 03/01/19 09:19 AM     Remind Me!  Send Private Message   Edit Post
Found my vacuum leak I just made a mistake when replacing injectors and the #4 injector o ring was not fully seated into the manifold. adjusted, tightened, and bam it works. glad it was an easy fix. but in the process I rebuilt the entire throttle body as well. It needed it as well so not too concerned. O2 bung welded in and all my gauges from my turbo miata got transferred over to the galant so now I can address the next in the line of 100000 issues. Good news is It should see its first test drive in who knows how long on sunday. The temperature is a toasty high of 5 on that day, here in the arctic that is omaha nebraska this time of year. I should probably wait for warmer weather, but Id really like to get some more things diagnosed and get to daily driving the thing.
736/2000 sold
Posts: 37 | From: OMAHA | Member Since: 12/09/18 | IP: (2620:0:10ee:10:c) | Report this post to a Moderator
Galant VR-4 org Post #: 1245470 posted 03/01/19 10:21 AM     Remind Me!  Send Private Message   Edit Post
Been there done that on the injector seal.
Good luck with the test drive. Spring can't come soon enough for me.
Posts: 10651 | From: Michigan | Member Since: 03/05/01 | IP: (205.144.100.200) | Report this post to a Moderator
Lesac
Galant VR-4 org Post #: 1245494 posted 03/03/19 08:31 PM     Remind Me!  Send Private Message   Edit Post
Again 1 step forward and 2 steps back. Was fortunate enough to drive the car for the first time, however as soon as it was out of the garage, it decided to puke power steering fluid allllll over. Was easy to see though since everything here is covered in snow. I said screw it and took it around the block to see if there were any other issues. Needs some tuning work, but other than that seems ok. This week Iíll get to the rear steer bypass then removal. The feed lines running to the back were so rusted that there were a few holes in them. I found a post from 5 years ago when the car was sold stating that it had new read ps lines. If this was the case it either wasnít these, or the car was sitting in a lake for a bit.
736/2000 sold
Posts: 37 | From: OMAHA | Member Since: 12/09/18 | IP: (2600:1014:b116:8) | Report this post to a Moderator
LordAthey
Almost Runs E85
Galant VR-4 org Post #: 1245500 posted 03/04/19 09:08 AM     Remind Me!  Send Private Message   Edit Post
Once it gets a bit warmer out I will be able to go through my parts list, but I'm right across the river in Iowa and have a ton of spare parts (block, crankshaft, cylinder head, 4 bolt diff, etc). Let me know if you need anything.
"If your car is loud, it's fast"
Posts: 207 | From: Council Bluffs, Iowa | Member Since: 08/05/09 | IP: (198.203.221.242) | Report this post to a Moderator
Lesac
Galant VR-4 org Post #: 1245501 posted 03/04/19 12:25 PM     Remind Me!  Send Private Message   Edit Post
I work over in CB. Iíd love to come check out what you have once we thaw out a bit.
736/2000 sold
LordAthey
Almost Runs E85
Galant VR-4 org Post #: 1245512 posted 03/05/19 08:05 AM     Remind Me!  Send Private Message   Edit Post
Great! I will send you a pm once we have warmer weather .
Lesac
Galant VR-4 org Post #: 1245514 posted 03/05/19 05:13 PM     Remind Me!  Send Private Message   Edit Post
Only had about 20 min of time today, but I got a few things accomplished. Rear steering lines are blocked off and I should be good for now. Plan is to remove the entire rear steer setup and go to a dsm rack and rear diff. Also confirmed that my dakei miata steering hub does fit the car but is too shallow to make either the turn signals of horn work. Iíll be ordering the correct hub, but at least i know what my Greddy wheel will look like on the car.
736/2000 sold
G Galant VR4.org Moderator
JDM Unit
486/1000
Galant VR-4 org Post #: 1245515 posted 03/05/19 08:52 PM     Remind Me!  Send Private Message   Edit Post
I've got a nib hub from japan if you are interested.
www.japanesenostalgiccar.com
www.nostalgic.co.jp
Posts: 8884 | From: zompton | Member Since: 02/24/04 | IP: (75.86.151.204) | Report this post to a Moderator
Lesac
Galant VR-4 org Post #: 1245517 posted 03/06/19 08:27 AM     Remind Me!  Send Private Message   Edit Post
G, you have a PM.
736/2000 sold
Posts: 37 | From: OMAHA | Member Since: 12/09/18 | IP: (2620:0:10ee:10:3) | Report this post to a Moderator
Lesac
Galant VR-4 org Post #: 1245518 posted 03/06/19 08:30 AM     Remind Me!  Send Private Message   Edit Post
Couple random pictures. New gauge pods came in today, so I have one oldschool and one newschool gauge. Will be installed after work today, so I can do some more tuning.
Also here is a picture of myself working on this turd, I have a wheel for a head.
736/2000 sold
Posts: 37 | From: OMAHA | Member Since: 12/09/18 | IP: (72.14.241.63) | Report this post to a Moderator
Lesac
Galant VR-4 org Post #: 1245523 posted 03/06/19 08:24 PM     Remind Me!  Send Private Message   Edit Post
Gauges installed
Next Iíve started tuning the car with the safc. I know it was on e85 with the setup it currently has before I got it, but it runs so poorly. Do all safc tunes kinda suck? Iím at the point where Iíd rather just get a ecm link and go back to pump gas.
736/2000 sold
I ain't no puny human
866/1000
Galant VR-4 org Post #: 1245527 posted 03/07/19 08:43 AM     Remind Me!  Send Private Message   Edit Post
If you can, definitely ditch the SAFC and go for Ecmlink. You will be much happier. You can even keep the e85.
Thom
Posts: 824 | From: Indianapolis, IN | Member Since: 09/24/14 | IP: (108.31.216.175) | Report this post to a Moderator
Pages: 1 | 2
0 registered and 17 anonymous users are browsing this forum.
Generated in 0.291 seconds in which 0.229 seconds were spent on a total of 14 queries. Turbo powered.
