Galant VR-4 Forums » Galant VR-4 » General VR4 Discussions » Re: 226/1000 Mild Restoration Build
bobbybdemented
Galant VR-4 org Post #: 1242794 posted 06/03/18 05:45 PM     Remind Me!  Send Private Message   Edit Post
All the parts for the AC system I got from Rock Auto. The expansion valve and drier are pretty much universal parts for those years and also the O ring kit is universal. And yes I did convert the system to R134. I also downloaded the factory manual which has a very detailed section on the HVAC System on these cars. And always change the Valve Cores.
Parts I used rebuilding AC system
Drier- FOUR SEASONS 33575
Expansion Valve- FOUR SEASONS 39491
O Ring Kit- FOUR SEASONS 26764
AC compressor- click
I did have to put the pulley from my old compressor on to the new one since they where different sizes. The pulley is held on by about 6 little bolts
Edited by bobbybdemented (06/03/18 05:46 PM)
Posts: 37 | From: Magnolia, Tx | Member Since: 03/27/16 | IP: (107.77.100.89) | Report this post to a Moderator
bobdole
Old member with new to me VR4 and starting over. Respect your elders kids
504/2000
Galant VR-4 org Post #: 1242860 posted 06/08/18 10:02 AM     Remind Me!  Send Private Message   Edit Post
Where did you download the service manuals from please? Trying to get an idea on replacing the expansion valve.
Great deal on BC coilovers. Hit me up.
www.b2autodesigns.com
Email: [email protected]
Youtube: click
Posts: 750 | From: tampa | Member Since: 08/23/07 | IP:
(79.71.93.98) | Report this post to a Moderator
idreamidrive
Member +
394/1000
Galant VR-4 org Post #: 1242930 posted 06/12/18 01:30 PM     Remind Me!  Send Private Message   Edit Post
Lilevo.com/mirage has all the manuals you would ever need
Page 627 of this PDF is ac stuff
Edited by idreamidrive (06/12/18 01:34 PM)
Posts: 368 | From: Murray, KY | Member Since: 10/10/12 | IP: (2605:a000:1610:4) | Report this post to a Moderator
bobbybdemented
Galant VR-4 org Post #: 1242989 posted 06/14/18 04:34 PM     Remind Me!  Send Private Message   Edit Post
Waiting for my Wife in the grocery store for about 15 minutes in 98 degree Houston heat with the AC on and the temp stays right in the middle.
Posts: 37 | From: Magnolia, Tx | Member Since: 03/27/16 | IP: (107.77.66.111) | Report this post to a Moderator
I ain't no puny human
866/1000
Galant VR-4 org Post #: 1242998 posted 06/15/18 06:20 AM     Remind Me!  Send Private Message   Edit Post
If my temp gauge gets anywhere near the location yours is in I start checkin stuff. That is why I have an aftermarket Coolant Temp gauge
Thom
1992 GVR-4 866/1000 (PTE 1200's, 16g, DSMLink v3, eagle/ross, .020 over, 272's, GC/AGX Coilovers)
Posts: 799 | From: Indianapolis, IN | Member Since: 09/24/14 | IP: (12.109.79.254) | Report this post to a Moderator
bobbybdemented
Galant VR-4 org Post #: 1243002 posted 06/15/18 10:21 AM     Remind Me!  Send Private Message   Edit Post
Do you run a thermostat???
Posts: 37 | From: Magnolia, Tx | Member Since: 03/27/16 | IP: (107.77.64.61) | Report this post to a Moderator
"Just to be pedantic!"
Galant VR-4 org Post #: 1243005 posted 06/15/18 10:38 AM     Remind Me!  Send Private Message   Edit Post
On every 6G Galant I've had the temp gauge always reads just a fraction under half at operating temp. I believe the gauge is wired that way so the needle doesn't fluctuate so much, and that it gives the illusion that it warms up quick and is stable. Ie, let's say at 190-220F it's going to read the exact same on the stock temp gauge.
Posts: 2104 | From: Toronto, ON, Canada | Member Since: 02/23/09 | IP: (209.226.66.172) | Report this post to a Moderator
bobbybdemented
Galant VR-4 org Post #: 1243006 posted 06/15/18 10:47 AM     Remind Me!  Send Private Message   Edit Post
My gauge always stays in the middle no matter what temperature it is outside. Also the fan dose not come on until the temp gauge starts moving past the middle. It could be that have the temp senor on the thermostat housing instead of the radiator...
Edited by bobbybdemented (06/15/18 10:55 AM)
866/1000
Galant VR-4 org Post #: 1243009 posted 06/15/18 11:32 AM     Remind Me!  Send Private Message   Edit Post
Mine and my two sons are also located on the Thermostat housing. None of ours ever hit the middle until the temps start getting to high. It could be that the needle is a little off on that gauge
Thom
strokin4dr
1280/2000
1135/2000
Galant VR-4 org Post #: 1243013 posted 06/15/18 08:53 PM     Remind Me!  Send Private Message   Edit Post
Quoting thomcasey:
Same here, Thom. I set my CEL to come of at 206 through ECMlink instead of having a separate gauge. On really hot days when sitting in traffic is starts to flicker a bit when getting close to that temp. As I get back up to speed and get some air flowing through the radiator it will turn back off. It's worked nicely for me like this for years now.
1908- sold and missed.
1280- 2.3, FP 35R, E85, etc.
1135- 100% stock
Posts: 2759 | From: Savannah, GA | Member Since: 08/30/05 | IP: (2601:900:8202:f3) | Report this post to a Moderator
866/1000
Galant VR-4 org Post #: 1243027 posted 06/16/18 09:13 PM     Remind Me!  Send Private Message   Edit Post
In also have link set, lol. I take the temp for the gauge from the upper hose. Let's me know if the fans are doing their job
Thom
Posts: 799 | From: Indianapolis, IN | Member Since: 09/24/14 | IP: (2601:803:c402:6d) | Report this post to a Moderator
bobdole
504/2000
Galant VR-4 org Post #: 1243144 posted 06/27/18 02:06 PM     Remind Me!  Send Private Message   Edit Post
Quoting bobbybdemented:
Working on my AC system now. What convert kit did you use? can't find the correct one.
Charles
Youtube: click
Pages: 1 | 2
2 registered and 53 anonymous users are browsing this forum.
Rating: **
Generated in 0.054 seconds in which 0.012 seconds were spent on a total of 14 queries. Turbo powered.
