Galant VR-4 Forums » Galant VR-4 » General VR4 Discussions » Re: 936/1000 progress report
mooserage
New Title
254/2000
Galant VR-4 org Post #: 1235474 posted 02/22/17 08:46 PM     Remind Me!  Send Private Message   Edit Post
This makes me want to POR-15 my car so bad. I'm curious, why spray paint instead of POR-15 on the subframe?
-254/2000 Summit White DD (aka "The Yeti")
The Yeti loves winter and hates me.
-ムースライジュ
Posts: 1162 | From: Seattle, WA | Member Since: 05/17/04 | IP: (205.166.76.241) | Report this post to a Moderator
Mn92gvr4
936/1000
Galant VR-4 org Post #: 1235477 posted 02/23/17 06:35 AM     Remind Me!  Send Private Message   Edit Post
I did 2 coats of por-15 then topcoated it with chassis&rollbar paint, gave it a nice matte look. Por-15 does recommend a top coat. Something to do with uv protection.
Edited by Mn92gvr4 (02/23/17 06:40 AM)
Posts: 108 | From: North branch mn | Member Since: 01/11/14 | IP: (2607:fb90:98a2:d) | Report this post to a Moderator
138/2000
Galant VR-4 org Post #: 1235478 posted 02/23/17 06:51 AM     Remind Me!  Send Private Message   Edit Post
for underhood sunlight, you know because of the light weight see through lexan you use for a hood.
138/2000
Posts: 3430 | From: Klamath Falls, Or | Member Since: 07/27/11 | IP: (71.89.204.234) | Report this post to a Moderator
Mn92gvr4
936/1000
Galant VR-4 org Post #: 1235479 posted 02/23/17 09:34 AM     Remind Me!  Send Private Message   Edit Post
Precisely. I guess it just comes down to personal preference. The engine bay will also be receiving a top coat one I'm completely done with it.
936/1000-almost going places
95 Honda civic notec DD
Posts: 108 | From: North branch mn | Member Since: 01/11/14 | IP: (2607:fb90:98be:1) | Report this post to a Moderator
Mn92gvr4
936/1000
Galant VR-4 org Post #: 1235719 posted 03/06/17 10:23 PM     Remind Me!  Send Private Message   Edit Post
So just a little progress here. I dropped the engine in for mock- up purposes.
Side note. Why do I have to run my pics thru photo editor in order to upload them?
I've been throwing around ideas for tires as well. I don't have any rims yet. Just had these laying around the garage. 265/35r18 95w. What's everybody running for width?
Posts: 108 | From: North branch mn | Member Since: 01/11/14 | IP: (208.107.182.207) | Report this post to a Moderator
I ain't no puny human
1025/2000
Galant VR-4 org Post #: 1235722 posted 03/07/17 06:15 AM     Remind Me!  Send Private Message   Edit Post
What size are your photos? There is a 2mb size limit I believe. I have run into it a few times.
those tires are super wide. If you get them to fit in te fenders you may end up with the turning circle of a Dually if they will even fit.
Thom
Posts: 697 | From: Indianapolis, IN | Member Since: 09/24/14 | IP: (12.109.79.254) | Report this post to a Moderator
Mn92gvr4
936/1000
Galant VR-4 org Post #: 1235724 posted 03/07/17 09:38 AM     Remind Me!  Send Private Message   Edit Post
That makes sense. I checked and my photos are 3.6mb, I'll have to change a camera setting or two.
I'm just playing around with the tires right now. It would be nice to use them all around but maybe just rears and go slightly smaller up front.
Posts: 108 | From: North branch mn | Member Since: 01/11/14 | IP: (2607:fb90:989d:e) | Report this post to a Moderator
1025/2000
Galant VR-4 org Post #: 1235725 posted 03/07/17 09:44 AM     Remind Me!  Send Private Message   Edit Post
You will have to be real careful with the tire sizes if you do that, you will destroy the drive-train if the sizes are off. Need to keep the same rotating diameter at all 4 corners
Thom
Mn92gvr4
936/1000
Galant VR-4 org Post #: 1235726 posted 03/07/17 12:03 PM     Remind Me!  Send Private Message   Edit Post
I know you can't run different heights, is it the same rule with width?.
Edited by Mn92gvr4 (03/07/17 12:07 PM)
1025/2000
Galant VR-4 org Post #: 1235727 posted 03/07/17 12:41 PM     Remind Me!  Send Private Message   Edit Post
You can stagger them, but in order to run a wider tire, you have to run a lower aspect ratio. You also have to look into how the tires sit (or compress) as the lower AR will normally have a stiffer side-wall and not compress as much, so you may also have to run different tire pressures t equal out and save the drivetrain.
Thom
A hole
820/1000
1837/2000
Galant VR-4 org Post #: 1235734 posted 03/07/17 07:40 PM     Remind Me!  Send Private Message   Edit Post
All of the tires need to have the same rolling diameter. It will require math to ensure that condition is met.
820/1000
1837/2000
1546/2000-SOLD
1813/2000-SOLD
Posts: 3321 | From: SoCal | Member Since: 01/02/12 | IP:
(2600:1003:b00d:5) | Report this post to a Moderator
Mn92gvr4
936/1000
Galant VR-4 org Post #: 1235737 posted 03/07/17 10:36 PM     Remind Me!  Send Private Message   Edit Post
Ah, I see what your getting at now. Well it's good for thought. I will have to see what kind of clearances I can get and go from there. Probably would be easiest to go with a narrower tire. I just have these floating around the garage, it would be nice to use them.
Mn92gvr4
936/1000
Galant VR-4 org Post #: 1235908 posted 03/16/17 02:19 PM     Remind Me!  Send Private Message   Edit Post
I just finished doing a fuse box relocation. Over all I am happy with the results. It was a huge headache but is well worth it. I still have to finish running my power supply cables.
Posts: 108 | From: North branch mn | Member Since: 01/11/14 | IP: (2607:fb90:989c:e) | Report this post to a Moderator
Mn92gvr4
936/1000
Galant VR-4 org Post #: 1236096 posted 03/24/17 07:48 PM     Remind Me!  Send Private Message   Edit Post
While browsing rockauto I came across this relocation kit. Pair it with a ffofh and it would clear up a lot of downpipe room.
Posts: 108 | From: North branch mn | Member Since: 01/11/14 | IP: (2607:fb90:98a8:2) | Report this post to a Moderator
Mn92gvr4
936/1000
Galant VR-4 org Post #: 1238521 posted 07/13/17 05:46 PM     Remind Me!  Send Private Message   Edit Post
It's been a busy few months but I have managed to get an update for everybody.
Introducing the "new" 936
Posts: 108 | From: North branch mn | Member Since: 01/11/14 | IP: (2607:fb90:a0a9:b) | Report this post to a Moderator
TheRedBaran3
Newbie
Galant VR-4 org Post #: 1238530 posted 07/14/17 08:02 PM     Remind Me!  Send Private Message   Edit Post
Looks great man! My engine bay and subframe are por15. The stuff is great. Maybe one day I can get deep into a build like this
Posts: 6 | From: Buffalo, NY | Member Since: 09/04/15 | IP: (68.133.15.104) | Report this post to a Moderator
Mn92gvr4
936/1000
Galant VR-4 org Post #: 1238548 posted 07/15/17 11:38 AM     Remind Me!  Send Private Message   Edit Post
Stuff is happening now. Missed being able to work on her. Brake lines and clutch lines installed. Motor and trans going in next.
Posts: 108 | From: North branch mn | Member Since: 01/11/14 | IP: (2607:fb90:9887:d) | Report this post to a Moderator
Mn92gvr4
936/1000
Galant VR-4 org Post #: 1238779 posted 07/29/17 12:05 PM     Remind Me!  Send Private Message   Edit Post
Posts: 108 | From: North branch mn | Member Since: 01/11/14 | IP: (2607:fb90:58ba:2) | Report this post to a Moderator
Pages: 1 | 2 | 3
0 registered and 66 anonymous users are browsing this forum.
Generated in 0.028 seconds in which 0.003 seconds were spent on a total of 14 queries. Turbo powered.
