Rave: D2 Coilovers
Nebraska
Lincoln, NE
Just ordered my first set of Coilovers and now plan to review them for the next possible buyer. I'm guessing it will be a week or two but I'm still pretty excited about them. Apparently mine are being shipped straight from the factory, is that normal? As for the price, I got the last set for $929.25 from The Coilover Store. Very good customer service so far. I'm also modding some dsm rotors for those that need pictars!
Expect updates!
Garrett
This is what I'm working with
Nebraska
Lincoln, NE
They're here!
Very unexpected surprise. I ordered these two days ago! Hmmmmm Sunday Funday this weekend!
Garrett
FlyingEagle
THE Ottawa
I just ordered KSports direct from KSport. They put in the order (because C53a are made to order) and 2-3 weeks lead time before another 2 days to the US and then 2 days to me in Canada.
Wouldn't surprise me if many of the chinese products are all made on the assembly line together. Just like bicycle frames from Giant, amongst other parts.
Would be nice to hear how these do. Keep in mind they should "soften" up with some good miles on them. All coilovers sound like they have a break in period (maybe more for cheaper entry level stuff by design and nature of the parts melding together), versus some higher end stuff; speculation!
Nebraska
Lincoln, NE
Interesting, I don't really know what to expect besides a stiff ride. The adjustability is pretty neat. I don't understand the spring travel yet but by the end of today I hope to be an E-expert on the Subject. Have you had Coilovers before?
TurboDSM
Merica
I had d2's on my old cts-v and they rode pretty good for a cheaper coilover. They are built very well, but you may want to mess with the spring rates if you decide to track the car. The out of the box ones arent very good
FlyingEagle
THE Ottawa
I'm hoping if they hold up well enough, that a set of Swift springs would be the proper upgrade (in matching specs), and then see what happens to the butt dyno.
donniekak
surprise az
I've checked out several different budget brands and tried a few different setups in my cars. I'm back to Koni's and eibachs. The easiest way I've found to judge a suspension setup is to go semi fast around a bumpy corner. Most of what I've experienced involves skipping across the road.
Nebraska
Lincoln, NE
So can someone correct me if I'm wrong but I read the instructions that came with the D2s and they seem pretty straightforward. I'm going to make sure things are secure and what not but to get started and at least semi aligned I was going to measure point to point from certain spots on the Coilover (example: Top of spring to bottom locknut, bottom of spring locknut to the locknut for the strut knuckle) not sure if this makes sense but I would like your input guys.
Garrett
ApexHunter
Marysville, WA
Yes, you've got the right idea! If D2 gave preliminary specs for pre-load and ride height and you plan on using them, then you definitely want to measure just like they want, otherwise measurement points are somewhat arbitrary.
I generally start out with preload at zero (the spring should be just snug). Start at one corner, and then measure the spring length at zero preload. The front left and front right should be equal, and same with rear left and rear right (to start with anyway), so i'll measure and try to get them within 0.5mm of each other.
For ride height, again it's kind of arbitrary unless you are using someone else's specs, but i like to measure the same way you described. I usually write down all my measurements to make setup changes or re-installation a bit easier.
