lets see where you guys mounted your aftermarket gauges
KiNgMaRtY
Corona, CA
I mounted mine under my aftermarket radio within the cluster. Others also mount them on the left dash speaker grill. You can also send your main gauge cluster to Ortiz and they can add some pods on it.
paltik
Whiting, NJ
You might also want to try ralliart tri-guages mounted below the radio, or something similar.
jnava
Arlington, Tx
Quoting gvr4ever:
Lotek gauge pod. Holy mother of god, they still make them. click
Is that the full a pillar gauge pod? I have a Lotek which was a replacement for the entire pillar on my Xterra SC.
cheekychimp
East Sussex, U.K.
One I did quite a few years back using the factory ECS pod. It's a neat solution but has two main drawbacks. First it requires cutting the dash which is a huge step unless your dash is already hacked, damaged or otherwise in bad shape. Secondly the range of gauges that work effectively are limited. Fitment isn't an issue but getting a clear view of many gauges especially analog ones is. Gauges like these ones or possibly AEM's digital line work fine though.
Cherry Hill, NJ
im currently running autometer gauges (all black) and not these prosports anymore. i can see everything great and it only blocks a little bit of the cluster.
turbohf
Lake Stevens, WA
Quoting raptorWagon:
glove box
same here
raptorWagon
Oak Harbor, WA
Quoting turbohf:
glove box
same here
I only look at my gauges as needed, and it's nice that it just adds to the car looking stock /ubbthreads/images/graemlins/smile.gif.
turbohf
Lake Stevens, WA
same here, i really dont care for the look of gauges.
Eaglesfly
St. Cloud, FL
Quoting transparentdsm:
What pod is that and where can I get it?
Indianapolis, IN
MITSUBISHI GALANT VR-4
1992 1996 Mitsubishi Galant VR-4 - Dual Cluster - OCPMIT-79
$ 150.00
Submit
CUSTOM GAUGE POD 52mm
Made from OEM Parts
Perfect fit, no modification required
1 Year Warranty
Look down in the 92-96 Galant section
