Low mount battery relocation (Homemade bracket for 52r)
ronkonkoma, ny
So here is the bracket I made to hold my battery. Only problem is I don't have an engine in the bay.
It's still rough just tacked in place really. The bottom pieces are 9.25" inches long.
Will this battery fit with the tyranny mount and everything in place?
EHmotorsports
Beaverton
Yes should be fine. That's where I have mine located and everything clears.
ronkonkoma, ny
do you think i can get the battery out with the tranny mount in place? my battery is a little bigger than yours.
does this box look familiar?
EHmotorsports
Beaverton
Comparing to your pics your battery is only 1/2" bigger. So you will be fine.
boostedinaz
Scottsdale, AZ
On page 4 in the link below you can see the battery tray I made. It for a full size battery and it was a super tight fit.
ronkonkoma, ny
Ok, but the trans mount isn't in place in that picture.
BoostedinAZ
Is it possible to remove your battery with the transmission mount in place?
boostedinaz
Scottsdale, AZ
With the size of the battery I have it is not possible.
If it was something small like PC680 it would be possible but I figured I don't take my battery out that often so no bog deal.
ronkonkoma, ny
Here she is with charcoal canister bracket before paint.
With battery
Battery is not going to come out easy, but Looks damn good.
ronkonkoma, ny
Correction: Changed out the battery removing only the tie down bracket. With a little wiggling the battery came right out.
