Sleeper DD build
calcaliente
Active member
Oakland
Bored so i decided to post up my work thus far. I never really introduced my self i just kinda lurk here and buy parts. Most of my parts i bought here or tuners. So yeah check it out and feel free to comment! /ubbthreads/images/graemlins/tongue.gif
Head
BC springs
HKS 272 cams
Arp head studs
Evo 8 retainers
New NGK spark plugs & wires
Evo 8 Injectors
Mitsubishi composite head gasket
Short Block
Wiseco HD's 8:5:1 .20 over
Manley Turbo tuff I beam rods
Stock crank inspected polished and straightened
ACL race bearings stock size
Brand new Mitsubishi Oil Pump with new Straight gears
Brand new Mitsubishi Water Pump
Brand new Mitsubishi timing components with Evo 9 timing belt
Fluidampr pulley with ARP balance bolts
Brand new Mitsubishi oil strainer
Brand new Mitsubishi oil pan bolts
Balance shaft delete
Brand new stock clutch with ARP flywheel bolts
Cometic full gasket set
Fp 4 inch intake for speed density
Genuine MHI Evo 3 16g
Greddy black sleeper front mount intercooler
Exhaust
Fp manifold
Punishment racing 02 housing
Tial 38mm 2 bolt ext waste gate
Full 3 inch slip fit exhaust
Electronics
AEM ECM
Trigger disk for AEM
GM SD 4.5 bar map sensor
AEM Boost gauge
AEM Oil pressure Gauge
AEM Wideband gauge
Battery relocated to trunk
GM IAT sensor
ABS deleted
A/C deleted
Power steering deleted
Extra goodies
APR FPR
Brand new shifter cables & clips
Walboro 255 fuel pump re wired
Prothane motor mounts
Mishimoto Coolant over flow can
Catch can
Racing steering wheel
AWS deleted
4bolt rear
5 lug swap
AFCO racing radiator with brand new radiator hoses and clamps
Engine bay painted black
Evo 8 wheels
Evo 8 suspension with Tein springs
Stainless steel brake lines
Stainless steel clutch line
Brand new Mitsubishi Clutch master cylinder
Brand new clutch slave cylinder
Redline shock proof in transfer case
Redline mt 90- MTL cocktail mix in transmission
10-30 Advance auto conventional oil (for break in)
10w-30 Mobil 1 synthetic oil
calcaliente
Active member
Oakland
Kinda grimy
Backshot
A familiar place...
calcaliente
Active member
Oakland
stripping it down for the take out
Pointing out the ghettoness
Buy this car he said. It has a ACT 2600 he said
calcaliente
Active member
Oakland
Parts
Tri Metal goodness
Machine shop
balancing the rods
Back from the dead
All shiny /ubbthreads/images/graemlins/ooo.gif
Previous owners idea of a balance shaft delete... /ubbthreads/images/graemlins/idea.gif /ubbthreads/images/graemlins/dunno.gif
calcaliente
Active member
Oakland
Every thing brand new OEM from Mitsubishi. Oil pump water pump, Oil pump gears, A real stubby shaft. All timing components blah blah blah 2g knock sensor. Oil strainer yahh
PTT twin disk for 9 grand shifting on yo bittch asss
Reassembly time...
Current status as of 4/7/13
calcaliente
Active member
Oakland
calcaliente
Active member
Oakland
So i decided to go ahead and paint the engine bay while its out of the car. And my bay is rusty as fuckkkkk
Some Colt action a Black Evo 8 and a Mirage in the back
My buddy Avery helping me sand and sh*t
[/url]
Started getting dark out side so we hit it with one coat of gloss black paint for the night
G
zompton
/ubbthreads/images/graemlins/applause.gif
Redlinegvr4
Tampa Bay
Sweet build man keep the pics coming.
Everything looks great! Oh and by the way a 2g knock sensor will not work with the 1g ecm. It will show way different values.
calcaliente
Active member
Oakland
I got AEM goodness but thanks tho! /ubbthreads/images/graemlins/wink.gif
oh snap. Just looking out for ya
calcaliente
Active member
Oakland
yah i know thanks! I just got off work now time to start turning some wrenches! Im missing parts tho i just found out. The Bolts to my Flywheel are stretched. And i didnt get injector seals /ubbthreads/images/graemlins/banghead.gif And the bolts to my FP manifold to turbo are longer so i may have to put the stock mani on for now. /ubbthreads/images/graemlins/bawling.gif looks like Extreme PSI is going to have my paycheck again. /ubbthreads/images/graemlins/uhh.gif
Romanova
Cypress, TX
Couldn't understand half the sh*t you typed but the pictures of the build look great. /ubbthreads/images/graemlins/hsugh.gif
calcaliente
Active member
Oakland
In the last stages before i drop the motor in just a few misc things i have to buy. Should be ready this weekend!!! /ubbthreads/images/graemlins/cool.gif
calcaliente
Active member
Oakland
Got the motor in the car! Now just need to connect the wiring harness and down pipe and axels.
nsin
monterey bay, ca.
Looking awesome!
calcaliente
Active member
Oakland
Got the car running! Just ran into a few snags tho. /ubbthreads/images/graemlins/bawling.gif The radiator was leaking but i didn't care i just wanted to see if it would start and it did. And there was a lot of smoke coming out the tail pipe. It was from the turbo it has a blown seal. Probably wasn't used to all that pressure from my new oil pump and gears. So i Bought a AFCO radiator and a MHI Evo 3 16g. I didn't want to buy a turbo just yet because i wanted to save some cash and buy a 6262 down the line but after i buy a trans. Then the clutch would not go into gear, so i was pretty bummed and i pretty much wanted to drop a grenade in my engine bay and torch it. But i didnt...i bought a new clutch master cylinder and that didn't fix it. /ubbthreads/images/graemlins/banghead.gif WTF!??! So i said screw it and bought a stock clutch and dropped the trans again and put that in. So tonight i will bleed the clutch and hopefully i can drive off. /ubbthreads/images/graemlins/uhh.gif My buddy is going to let me borrow his 14b in the meantime. But i definitely got big plans for the car and its come a long way. The turbo will be here tomorrow and I'm pretty excited. I'm going to hold off on big power for a while just because i want a built transmission and the costs involved with switching my whole exhaust setup. But i definitely feel my short block can take some abuse.
Leaky turbo
Leaky radiator
Jesus_Negros
USA
Nice progress. Where in VA are you?
