Galant VR-4 Forums » Galant VR-4 » General VR4 Discussions » GST with PSI's build & restoration of 1813
A hole
820/1000
1837/2000
Galant VR-4 org Post #: 1081731 posted 08/20/12 03:02 AM     Remind Me!  Send Private Message   Edit Post
This is the intro to my build/restoration thread for 1813. I purchased this car in August of 2011 and have been stacking parts, and doing repairs and restoration slowly over time. I’ve found that the car’s previous owner(s) have done quite a bit of damage by half-ass repairs and mod jobs. 80% of what I’ve done has been reversing damage that’s been done by bad mechanics. You can see more background on the car here click in my initial intro thread from when I bought the car.
My goals for the car are primarily just to be a fun DD. I would like to do some drag racing with it as well in my free time. I have a huge mod list, but the major mods are:
2.0L refresh
1G rod, 2G piston combo
Balanced and blueprinted rotating assembly originally built by RRE
Cyclone Intake
Holset HE351VE Variable Geometry Turbo
Snow Performance Methanol Injection
DSMlink…
So to start, I bought the car and was told by the last owner that all the car really needed was a fuel pump. That turned out to be farther from the truth than I could have ever imagined. I got a sender unit with a kinked outlet line. Here are pics of the reconditioning and -6 AN line conversion.
Here’s how the unit started.
I ground the outlet line flush and drilled and tapped the hole with a 1/8 NPT tap.
I used a 1/8 NPT / -6 AN fitting and put Teflon high temp sealant on the threads after I screwed the fitting into the sending unit. I then used some fuel resistant epoxy putty to seal the fitting just as a precautionary measure.
Lastly, I used a 1/8 NPT coupler and barb fitting to attach the fuel pump hose. I sanded the top of the sending unit and removed all the rust. Taped the fittings and wiring and painted the unit.
Here is the finished product.
I dropped the fuel tank. I cleaned, prepped and painted the exterior. The inside was starting to rust and corrode so I had to do a lot of work cleaning the inside also. I’ll have some after pics of it soon but it turned out good.
For anyone trying to adapt a AN line to the stock hard line here’s how you do it. You MUST have an inverted flare adapter fitting. I got mine from RCI, but they are available other places. If you aren’t familiar with what im talking about, just know if you do not have the correct fitting, the line will leak and shit can catch on fire. That should be enough to deter anyone from screwing the wrong fitting on. See here for a good read on some of the incorrect fittings that are used: click
Notice the flared center inside of this fitting. I included a few shots of the progression of installation from the stock hard line to the finished product with the -6 AN line installed.
As I mentioned before, the previous owners were quite the backyard mechanics. Here are a few shots of how hacked and messed up a few of the previous owner’s repairs were. These were just a few of the things that were messed up by hack job repairs.
The motor.... I bought the car under the impression it just needed a fuel pump. As it turned out though, the car ended up having 8 bent intake valves. Fu*k me. I pulled the head and just planned to get the head fixed and slap it back on. As I started to check out the timing components, I realized the oil pump had RTV sealant oozing from where it sealed to the block. This worried me. I am a firm believer in gaskets. IMO using RTV sealant or gasket maker for anything that a gasket is specifically made for is stupid. It’s a band aid at best, and not using a gasket whenever you can is just dumb to me. People spend tons of money on parts and expensive engine components and then cheap out on shit like gaskets. I just don’t get it? Anyways, because of this find I decided to pull the motor, tear it down and inspect everything; and it's a good thing I did. I dissembled the motor down to the block and rotating assembly. There wasn’t a single gasket in the entire thing. Whoever built this motor used RTV sealer on EVERYTHING!!!??? The oil pickup, oil pump, water pump, oil pan, rear main seal, blah, blah, blah. Literally, the only gasket that was used in the whole motor was a head gasket. Even the thermostat housing was sealed with RTV. I couldn’t understand it. It probably took me 8 damn hours to scrape and clean off all the RTV off of everything. I finally got it all off and cleaned all the mating surfaces good and checked them for trueness and damage. I pulled everything apart and reinstalled everything using FelPro gaskets. I used copper spray on almost all of the gaskets except for the head gasket. It does a great job sealing any imperfections that the paper gasket can’t. Plus, after you spray it on it gets a little tacky so the gasket is easy to place. Copper spray is amazing. I installed ARP head studs and a FelPro composite head gasket (9627PT). Lastly I painted the block with few coats of high temp paint and checked all the torque on the rod and main caps just to be safe.
Before:
After:
Before:
After:
Before:
After:
A few additional shots:
I had the head reconditioned at a local machine shop here in SoCal. They milled the deck surface and replaced all the intake valves. They gave it a nice cleaning and I gave it a coat of high temp paint before I slapped it on the nice clean block. I torque it down with new ARP bolts using ARP molly lube.
I installed Fidanza adjustable on the stock cams for now. EVERYTHING else is gates. New gates water pump, tensioner pulley, idler pulley and hydraulic tensioner. I went with a Gates racing timing belt also. OEM Mitsu thermostat was installed as well as Mitsu knock and temp sensors. I’m just waiting on a few timing tins covers to finish up assembly. I cleaned and touched up all the engine accessories before they were bolted on. The long block is now mostly assembled and looks super clean.
While I had the motor out I went ahead and repainted the engine compartment with some semi-gloss black. I also did the front wheel wells. A few before and after shots.
Before:
After:
Before:
After:
Before
After:
Before:
After:
Before:
After:
Before:
After:
The suspension....Let me just start this by saying what a fu*king disaster this was. If I knew exactly who screwed the suspension on this car up so bad I would have beat them to death with the damn strut assembly. I only started working on the suspension because I was doing a 5 lug swap on the car. As soon as I removed the wheels I knew there was a problem. I noticed the front springs were sitting crooked in the front strut perch. Additionally, the spring was rubbing on the inside of the wheel well when compressed. It wasn’t until after I removed the front and rear strut assemblies that I figured out what was going on. It turns out the guy who had the car before me actually cut the springs so short they wouldn’t even sit snug in the strut anymore. I should mention these weren't even stock springs, but ebach sportlines. I have never heard of anyone cutting a spring that is already designed to lower a car, but I am never ceased to be amazed. Cutting a lowering spring seems really stupid, but after seeing all the other shit messed up by the previous owner I’m not even surprised. Here’s a pic of me actually wiggling the spring in the strut while it’s fully assembled. The springs were so loose I didn’t even need to use a spring compressor to remove them.
Here are some shots of the 5 lug swap, and how I removed the rear axle cups with a 3 jaw puller. I cleaned, inspected, lubed and painted all the hub assemblies before installation. I trashed the cut Eibachs for a set of B&G lowering springs. I reinstalled them on the almost new KYB AGX adjustable struts that were already on the car. I also put on new bump stops and strut rod covers while I had the assemblies apart. I’m excited to see how the car’s stance looks when it’s all said and done. Up top I installed new upper strut mounts on both sides. I threw on my Whiteline 22mm front swaybar and new stock swaybar end links on both sides to finish up.
So I get everything together start bolting the passenger side strut assembly onto the car. I get it on and notice it will only turn about 20 degrees before it locks up. It wasn’t allowing enough motion for the strut to rotate like it should. The ball rotated perfectly in the socket with the strut removed though. It was blowing my mind. Come to find out the lower control arm was bent, and increased the ball joint’s center angle so much that it wouldn’t allow the strut full range of motion. It wasn’t until I ordered new control arms that I realized how messed up the old arm was. I replaced both sides with new arms just to be safe. Here are a few shots of the new arm side-by-side with the old arm.
Bad:
Good:
Next on the agenda is finishing up the motor and throwing it back in the car. I have an external 255 to wire up that will be used in conjunction with the stocker in tank pump, and then need to reinstall the fuel tank. More updates to follow soon...
Posts: 3403 | From: SoCal | Member Since: 01/02/12 | IP: (108.95.125.202) | Report this post to a Moderator
bobdole
Old member with new to me VR4 and starting over. Respect your elders kids
504/2000
Galant VR-4 org Post #: 1081736 posted 08/20/12 05:59 AM     Remind Me!  Send Private Message   Edit Post
Great build. Everything looks great. Look forward to seeing more updates.
Great deal on BC coilovers. Hit me up.
www.b2autodesigns.com
Email: [email protected]
Youtube: click
Posts: 772 | From: tampa | Member Since: 08/23/07 | IP:
(89.243.104.20) | Report this post to a Moderator
matt92vr4
Member ++
474/1000
Galant VR-4 org Post #: 1081750 posted 08/20/12 10:22 AM     Remind Me!  Send Private Message   Edit Post
Looks great! We are currently in a very similar situation lol
474/1000 Summit White
1993 Stealth RT/TT
1995 Montero SR
1998 Montero
Posts: 676 | From: Venice, FL | Member Since: 10/03/10 | IP: (68.34.158.83) | Report this post to a Moderator
Galant VR-4 org Post #: 1081752 posted 08/20/12 10:33 AM     Remind Me!  Send Private Message   Edit Post
Very nice work. Kudos on your efforts.
I'll have to try putting my block on the stand like that. I have never done that.
91 VR4 855 Nile Black
92 VR4 828 Belize Green-SOLD
91 VR4 115 Nile Black -SOLD
Posts: 10695 | From: Michigan | Member Since: 03/05/01 | IP: (12.1.210.228) | Report this post to a Moderator
matt92vr4
Member ++
474/1000
Galant VR-4 org Post #: 1081777 posted 08/20/12 01:10 PM     Remind Me!  Send Private Message   Edit Post
Yeah I noticed that was an interesting way to mount the block.
1993 Stealth RT/TT
1995 Montero SR
1998 Montero
295hp 35r BR4
550/2000
Galant VR-4 org Post #: 1081887 posted 08/21/12 07:54 AM     Remind Me!  Send Private Message   Edit Post
lookin Good Brett, I see one one of the brands from my store, Master pro haha.
are you gonna keep it blue like your 1g?
2001 R34 Nissan Skyline “Eleanor”
JZX90 Toyota Mark II Tourer V "Laura"
90 Nissan Skyline GTR "Tanya"
90 Eclipse GST "Kerri"
91 Galant VR4 "Samara"
Posts: 3705 | From: Houston, Texas | Member Since: 04/07/11 | IP: (75.34.119.38) | Report this post to a Moderator
A hole
820/1000
1837/2000
Galant VR-4 org Post #: 1081942 posted 08/21/12 04:54 PM     Remind Me!  Send Private Message   Edit Post
Thanks Mike. I'm really disappointed you didn't get your car done in time, and just as disappointed I couldn't get mine done either. I know how it is to rush and try to make a deadline just to be let down in the end. After I knew I wasn't going to make it to the shootout, I just slowed down and decided to do all the things I wanted to do anyways but time wouldn't permit by trying to make it to the shootout. I think I will be better off now that I can take my time and give lots of attention to detail. Hopefully you can do the same. Better luck next year to both of us I guess.
I will probably get it painted eventually, but haven't decided whether I'll keep it blue or not. Time will tell.
820/1000
1837/2000
1546/2000-SOLD
1813/2000-SOLD
(97.85.243.206) | Report this post to a Moderator
295hp 35r BR4
550/2000
Galant VR-4 org Post #: 1082048 posted 08/22/12 09:04 AM     Remind Me!  Send Private Message   Edit Post
Yeah now that I have an entire year to wait till the next shootout, this gives me time to do ALOT =) hopefully the both of us can roll out there next year like originally planned.
Anyways, I think that car wouldn't look badass in that darker metallic blue. Or even that Evo 9 grey =)
Edited by GSX_TC (08/24/12 08:34 AM)
Posts: 3705 | From: Houston, Texas | Member Since: 04/07/11 | IP: (208.54.83.167) | Report this post to a Moderator
faqinshiet
Member +
Galant VR-4 org Post #: 1082336 posted 08/23/12 02:24 PM     Remind Me!  Send Private Message   Edit Post
Wow..good work! What color was it originally? Just wondering. What area of sd are you too? Im in the mission valley area usually.
90 GGSX-VR4 clone
Posts: 473 | From: Arlington, Va | Member Since: 12/06/11 | IP: (198.228.216.21) | Report this post to a Moderator
desant78
Member ++
1662/2000
995/1000
Galant VR-4 org Post #: 1082351 posted 08/23/12 04:53 PM     Remind Me!  Send Private Message   Edit Post
dude great work! looks like your a doing a real thorough job, and it's coming out great so far.
Keep up the hard work, and kudos for taking creating what a fine example of a vr4 would be.
i wanna go fast.
1991 GVR4 1662/2000 (parts car)
1992 GVR4 995/1000 (JSB)
2008 Evo X GSR (DD with bolt ons, 17x,xxx miles)
Posts: 732 | From: Clarksboro, NJ | Member Since: 06/23/10 | IP: (138.162.0.45) | Report this post to a Moderator
A hole
820/1000
1837/2000
Galant VR-4 org Post #: 1082872 posted 08/27/12 06:50 PM     Remind Me!  Send Private Message   Edit Post
Quoting faqinshiet:
I'm in located in the Mira Mar area, and The car was originally BG.
Sooooo0o I dropped the motor in yesterday and I have a problem. I installed all new avid aluminum motor mounts in the car click The problem is, as the motor sits now, it's an inch or so too close to the driver side frame rail. It seems like each mount is just a half inch shy of where it should be located to allow the motor to sit perfectly side to side. It's off enough that the power steering pulley is actually hitting the frame rail. I know it's the new mounts too because the motor sat fine with the old stockers installed. I'm not really sure how to go about fixing this issue. Has anyone else had this problem, or had a problem like it? I'll post up some pictures later to give you guys a visual idea of what I'm dealing with. I'm thinking of slotting the passenger transmission mount to allow the upper through bolt to slide back more toward the passenger side of the car, thereby shifting the whole motor a bit to the passenger side. Then I have to figure out how to shift the front and rear mounts though, and am stuck on what to do there. Anybody have any ideas? I only need about another half inch of clearance.
820/1000
1837/2000
1546/2000-SOLD
1813/2000-SOLD
(138.162.140.55) | Report this post to a Moderator
Noobsauce
1865/2000
Galant VR-4 org Post #: 1082876 posted 08/27/12 07:56 PM     Remind Me!  Send Private Message   Edit Post
Have any pics with the engine in the car? And close ups of the engine mounts
Posts: 159 | From: Beaverton, Oregon | Member Since: 04/07/12 | IP: (24.21.177.205) | Report this post to a Moderator
295hp 35r BR4
550/2000
Galant VR-4 org Post #: 1082882 posted 08/27/12 08:58 PM     Remind Me!  Send Private Message   Edit Post
Brett, id return those mounts, get your money back because they prob aren't meant for a GVR4 or something. Then just pick up some of those red or black poly mount inserts and press those in your stock mounts and be done with it.
Posts: 3705 | From: Houston, Texas | Member Since: 04/07/11 | IP: (208.54.83.198) | Report this post to a Moderator
A hole
820/1000
1837/2000
Galant VR-4 org Post #: 1082908 posted 08/28/12 12:02 AM     Remind Me!  Send Private Message   Edit Post
I messed with the fitment a bit today and got 3 of the 4 motor mounts to fit good. I loosened the attaching brackets that connect to the block and used a pry bar to better position the mounts. The driver side mount is hopeless though. These mounts are garbage as far as fitment goes. If I didn't have so much time and money invested in them, I'd throw them in all the trash. I have a few pics of just how far off this thing is from fitting. It sits too high as well as cocked when it's installed and tightened. I'm going to have to make a few cuts to the aluminum stock to get it even close to fitting. At this point I really don't care if the mount gets screwed up, as I'll just buy a new one if this one will not work after I mod it. I'm ready to hack this bitch up with a saw anyways, because I'm really pissed that these mounts fit like shit. For all those of you looking to buy Avid aluminum motor mounts, don't do it. I can't speak to how they fit on other cars, but the VR4 specific ones (which these are) fit like crap. That is all for now...
820/1000
1837/2000
1546/2000-SOLD
1813/2000-SOLD
Edited by GSTwithPSI (08/28/12 12:05 AM)
(70.230.200.160) | Report this post to a Moderator
LIV4PSI
dyslexic 1051
1501/2000
Galant VR-4 org Post #: 1082917 posted 08/28/12 02:03 AM     Remind Me!  Send Private Message   Edit Post
I didn't know there were GVR4 specific Avid mounts. I bought 1G ones for my car, and I didn't have any fitment problems on any of the 4.
Very nice build. I love when members have the proper amount of pride and respect for their GVR4.
-Craig
1501 Build Thread
Posts: 1761 | From: O-H-I-O | Member Since: 11/24/11 | IP: (151.213.205.53) | Report this post to a Moderator
A hole
820/1000
1837/2000
Galant VR-4 org Post #: 1083116 posted 08/29/12 04:10 PM     Remind Me!  Send Private Message   Edit Post
I ended up hacking up the driver side mount to get it to fit. For those of you who have installed these already without issues, I really can't see how. After I modded the mount it was still a bit shy of where it needed to be. I got tired of screwing with it and will probably attack it this weekend sometime. Of all the issues I have come accross so far, this one is by far one of the most frustrating. I'm cool with old parts and stuff breaking or whatever, but this is ridiculous. These things are new, and should fit like stock for what they cost. Regardless of what others are saying, I would not recomend buying Avid aluminum motor mounts to anyone. If someone else here has some pictures of how these mounts fit on their car I'd be interested to see them.
Edited by GSTwithPSI (08/29/12 04:12 PM)
Posts: 3403 | From: SoCal | Member Since: 01/02/12 | IP: (138.162.140.52) | Report this post to a Moderator
bazeng
work in progress
Galant VR-4 org Post #: 1083121 posted 08/29/12 05:18 PM     Remind Me!  Send Private Message   Edit Post
Is it possible to have mounted the gearbox mount upside down?
This may be stopping you from getting the correct engine level on the timing side?
Australia's Slowest VR4
Posts: 2520 | From: Melbourne, Australia | Member Since: 02/06/03 | IP: (220.237.107.105) | Report this post to a Moderator
Tre3zy
correct me if im rite...Wyldcarz been rolling hard for a long time
637/2000
Galant VR-4 org Post #: 1083140 posted 08/29/12 09:24 PM     Remind Me!  Send Private Message   Edit Post
Quoting LIV4PSI:
you bought 1g ones for the gvr4??? id like to see those pictures as well because i was interested on buying this mounts in the future...
GARAGE BUILT
#ZukiFab / Tuned
Build Thread:
Current Personal Best 11.75 @ 119
Posts: 601 | From: South San Francisco, CA | Member Since: 11/25/08 | IP: (108.68.109.184) | Report this post to a Moderator
LIV4PSI
dyslexic 1051
1501/2000
Galant VR-4 org Post #: 1083145 posted 08/29/12 10:48 PM     Remind Me!  Send Private Message   Edit Post
Yes, I bought 1G ones. The research I did before buying them said that they were the same. The front bracket that is different on GVR4s is still used, and that is the only difference between our mounts and DSM mounts.
-Craig
1501 Build Thread
Brianawd
Higher Launch RPM
439/1000
Galant VR-4 org Post #: 1083182 posted 08/30/12 10:04 AM     Remind Me!  Send Private Message   Edit Post
1g and galant vr4 mounts are all the same other then the front roll control mount. I have installed more then a few JDM motors into 1gs and the roll control mount is the only one I change out.
1992 Gaylant vr4 #439/1000
11.1at131 562awhp/484awtq
E85 FP3052 parted out
05 EB EVO SSL 11.48at124mph
450awhp/400awtq New 2.3 e85 hks 7460r
05 JEEP liberty CRD DD/ski slut
200hp/385tq
Posts: 2117 | From: Portland OR, | Member Since: 04/18/05 | IP: (134.134.139.74) | Report this post to a Moderator
A hole
820/1000
1837/2000
Galant VR-4 org Post #: 1083343 posted 08/30/12 10:50 PM     Remind Me!  Send Private Message   Edit Post
I finally got the mounts all in. I had to do some serious modifications to the driver side mount for it to even be close to fitting. Even then, getting them all in was such a pain. But, they are all in and bolted down. The motor sits TIGHT! I mean you can grab the head and shake the shit out of it and the motor doesn't even budge. I'm not sure how this is going to effect drive-ability or how badly the vibrations are going to be. To be honest, I'm a little worried about how rough rigid these mounts are. I guess we'll see how this plays out for daily driving conditions. I'm glad to be over this obstacle though, and am hoping the remainder of the motor install is all down hill from here. I have a 3 day weekend coming up so I guess I'll find out soon enough.
820/1000
1837/2000
1546/2000-SOLD
1813/2000-SOLD
295hp 35r BR4
550/2000
Galant VR-4 org Post #: 1083384 posted 08/31/12 09:36 AM     Remind Me!  Send Private Message   Edit Post
Well if you don't like how much vibration they make I'll happily buy them off you since I was planning on picking up a set anyways. But hopefully they won't shake you to death lol
Posts: 3705 | From: Houston, Texas | Member Since: 04/07/11 | IP: (208.54.83.252) | Report this post to a Moderator
A hole
820/1000
1837/2000
Galant VR-4 org Post #: 1083634 posted 09/02/12 01:06 AM     Remind Me!  Send Private Message   Edit Post
Progress has been coming along well since I have dealt with the motor mount issue. The motor is in and I have started to get things back together in hopes of having a running VR4 by next week.
I completed the rear half of the fuel system. Here's the tank before:
After:
Here's the re-done pump assy and new OEM Mitsu tank gasket.
I also replaced the fuel filler hose:
Cleaned and painted the filler neck:
Final product:
My fuel setup consists of the OEM in-tank pump and an external Walbro 255. The stock pump acts only as a lift pump. I made a custom mount for the 255 on the fuel pump access cover and attached it there. I also did a re-wire for the Walbro using some large 10 gauge wire. Everything is still mounted externally and is all hidden when buttoned up. I was really happy with how it turned out. Hopefully it works as well as it looks.
To run the relay for the re-wire, I had to splice into the factory harness for a 12v source that's hot when the car is on. I made a solder connection and used some heat shrink to weather proof my new connection. I just took the pin out of the connector to get the heat shrink on.
And the final product... Notice the only difference is the 2 large wires used to power and ground the newly installed Walbro 255. An overall nice and clean install.
A quick shot of the rear completed 5 lug swap. New springs, struts, slotted rotors and pads.
I installed all new Gates accessory belts. I would have bought a kevlar racing belt for the power steering, but gates doesn't make one...
Steel braided clutch line to replace the junk rubber OEM line.
Empty engine compartment after paint:
And here it is now with the motor dropped in. I replaced all the old crappy plastic wire covering on the engine harness with nylon braiding. I have also relocated it lower on the bulkhead to tuck it and give the engine bay a cleaner look. The battery has been relocated to the trunk, and the engine compartment seems huge with all the extra space I have. I also replaced much of the hardware on the car with new grade 8 bolts, or stainless hex head hardware. All the detailed work I'm doing is really consuming a lot of time, but the end result is definitely paying off.
My cyclone intake manifold had a bad vacuum actuator. I swapped in a 14B actuator in its place. I made a few custom brackets and it fits like stock. It opens the butterflies at around 8 psi.
Cyclone mani installed:
Before re-installing, I rebuilt both front axles with all new CV boots and high pressure synthetic grease.
New lower dust shield installed:
I disassembled, inspected, cleaned and painted the transfer case while it was out of the car. Here's how it turned out:
Anddddd last but not least, here's a Galant base I saw in the parking lot of Home Depot Racing while making a trip for bolts.
More to come soon...
Posts: 3403 | From: SoCal | Member Since: 01/02/12 | IP: (70.230.200.160) | Report this post to a Moderator
295hp 35r BR4
550/2000
Galant VR-4 org Post #: 1083789 posted 09/03/12 01:47 AM     Remind Me!  Send Private Message   Edit Post
I like that gates racing blue alt belt, im gonna pick one of those up =)
Posts: 3705 | From: Houston, Texas | Member Since: 04/07/11 | IP: (98.197.23.242) | Report this post to a Moderator
A hole
820/1000
1837/2000
Galant VR-4 org Post #: 1083792 posted 09/03/12 03:09 AM     Remind Me!  Send Private Message   Edit Post
I don't know why everyone doesn't. They are hardly more than a new OEM timing belt... click
820/1000
1837/2000
1546/2000-SOLD
1813/2000-SOLD
Edited by GSTwithPSI (09/03/12 03:22 AM)
Pages: 1 | 2 | 3 | 4 | 5 | 6
0 registered and 27 anonymous users are browsing this forum.
Rating: **
Generated in 0.242 seconds in which 0.079 seconds were spent on a total of 15 queries. Turbo powered.
