whats this wire? now with a picture...
SleepinGVR4
Danville, Pennsylvania
Whats that little white wire on the alternator wiring harness? It comes out of the harness underneath the grounding bracket for the alternator.
SleepinGVR4
I'm telling you its not. I know what the wire looks like you just can't see it in the picture.
The wire I'm holding wouldn't be long enough anyway, it protrudes out of the harness below the grounding bracket that bolts on the alternator.
chach161
Active member
Moses Lake, WA
I am not sure but it looks like it would be the oil pressure switch but with out looking at it I am not sure but the diagram might help.
gramkrakr89
Bunker Hill, WV
Didn't DSM's have2 wires for their oil pressure sender? one for the gauge and another for the dummy-light? /ubbthreads/images/graemlins/dunno.gif
maybe check it for voltage while the engine is running?
citymunky
Chesapeake, VA
What was it? The oil pressure wire? I hare the same wire going nowhere also.
Wizardawd
Franklin, NC
The gauge sender is the one under the crank pulley. The dummy light sender is under the alt facing towards the radiator.
Wiz
