#431 runs single digit passes
NateCrisman
Blairstown, NJ
Youtube Video of the runs
check the video!
GizmoVR4's 92..#431/1000. Island yesterday Nov 5th. We got three 9 sec passes out of the car before being kicked out for lack of safety equipment. This was the first day we were able to make complete passes without any major issues and thankfully hit the goal of a 9.
So we now have some issues to deal with for the winter:
[*]obviously getting the roll bar upgraded to a full cage w/ the roof halo & dash bars, chassis certification, and getting NHRA license.
[*]intercooler needs a significant upgrade as we were seeing 141-156*F AIT at the traps.
[*]ignition upgrade. we were ok at 40psi, but 42.6psi was blowing out the spark.
[*]ECU needs an upgrade as we are running on the very last bottom row of the fuel table, and the boost control doesn't have enough resolution to tune with.
[*]suspension & alignment needs work, as the car is roasting tire in first gear and sliding around and isn't efficient as it could be. It went 1.37 on the pass w/ misfire even with lifting throttle in first gear!
[*]Weight loss....car is still a real streetcar. elec sunroof, leather seat, full dash w/ all the inside guts. all stock wiring. sway bars. stock brakes. significant weight to lose [/list]
That 9.6 was done with the trans not really revving up in first gear or making a solid 1-2 shift. 2-3 shift was pretty early too. We are still figuring out this adjustable rpm shift box vs the automatic shift lag. We had the shift points set too low, actually below where the converter would stall to, which makes the logs looks strange, as if the car launched and stayed in 3rd gear the whole way. I guess we want to shift the thing at about 8500rpm.
Next year I think we are going to make a goal of overtaking #1062 /ubbthreads/images/graemlins/devil.gif
Yikes how much converter do you have? Breakin up pretty bad on the last run eh?
Man congrats on the 9 sec pass!
NateCrisman
Blairstown, NJ
Quoting Zak:
Converter is a re-stalled stocker done by a trans shop that is local to Gizmo in Long Island, NY. I'll see if I can get the info on the shop. It seems to be able to get nearly 5000rpm and 20psi on the starting line without any nitrous. We haven't sprayed it yet this year at all, haven't had to. We expected the car to need a small dry shot on the line to get up on the converter, but the combo of 2.3L bottom end, ball bearing turbo, short IC piping, and the loose converter seem to work out pretty well. I think once we get the car to go straight and keep from lifting the front, we can get the 60' time down into the low 1.3's if not maybe hit a 1.2.
Barnes
Richland, WA
I love the way the clock pops out of the dash on run #4. /ubbthreads/images/graemlins/rofl.gif
Ya, the unit would prolly blow the tires off pretty hard. What tire you running anyways? 26x8?
congrats! i love videos like these!! what turbo are you running btw?
NateCrisman
Blairstown, NJ
Quoting Zak:
26x8.5x15" M&H Racemaster bias ply slicks on 15x7' ARE wheels (old school wheels!). Unfortunately we can't really fit anything bigger, as the car could benefit from 28" dia tires to give us a little more rpm in 3rd gear. It's coming through at about 8800rpm in drive to see 144mph trap speed, which IMHO is getting close to the limit for a 2.3L 100mm stroker bottom end.
Part of the traction issue is the alignment is totally wrong. It has static toe out a tiny bit due to "eyeball alignment" at the last minute after putting D2 coil overs on the front. The thing lifts the front, which adds even more toe out, leading the thing to drift around and scrub the front tires. We need to limit strap the front shocks and set the toe to 0.0* exact on the straps. The rear needs to be stiffer so it doesn't blow through the travel and let the camber go way negative. Set of active toe elim ends would also help. We'll get it to hook better next year, I promise!
NateCrisman
Blairstown, NJ
Quoting GSX_TC:
The turbo is a GT37R with a T3 turbine housing. Not 100% sure of the turbo model # nor do I know the A/R of the housing. He got the turbo in a weird deal w/ a machine shop that took it from a different customer as collateral on an unpaid bill. So we don't really know exactly what the turbo is. We are running it at 40psi on the 9.6 run. Turning the boost control map in DSMlink V3 up "one click" brought boost up to 42.6 average. Not really sure what the limit is with a 37R, but I guess I'd just keep cranking in more boost until we don't see a mph increase.
48-50psi of boost might be the max /ubbthreads/images/graemlins/dunno.gif
marvinmadman
Lafayette, Louisiana
Use some fishing string next time instead of eyeballin it. /ubbthreads/images/graemlins/grin.gif
wow thats actually quite impressive for a 37R, good job
marvinmadman
Yeah one of my buddy's had a 37r on his 11 sec civic. Didn't think one would propel a galant into the 9's. /ubbthreads/images/graemlins/jawdrop.gif
3rdstrikedsm
32159, FL
That's a solid car!
Is that Marks old car? I never heard where it went after he sold it but I thought it was out east.
NateCrisman
Blairstown, NJ
NOT Mark's car. not the car, not any of the parts. It just happens to be another auto swapped white GVR4 w/ a similar engine combo. But seriously, totally different car.
Quoting Barnes:
And then goes back in when the brakes are applied. /ubbthreads/images/graemlins/rofl.gif
Congrats!
ApexHunter
Marysville, WA
Quoting Barnes:
Classic. /ubbthreads/images/graemlins/rofl.gif /ubbthreads/images/graemlins/worthy.gif
broxma
San Antonio Tx
Do you have some idea as to what kind of realistic power numbers the car is laying down at that boost level?
How is boost holding on the top end of almost 9K rpm and do you think a 2.0L or 2.1L would be better?
/brox
beaner
b'ham, mi
Nice Nate. Giving me some motivation to finish my setup with the exact same snail. 9's is silly silly fast.
