why isn't my 2 step working?
MellowVR4
Milwaukee, Wi
I recently installed a chip everything, tried out my 2step... nothing. Then i found out that i had to do the clutch wire mod to my ecu. Still nothing, has anybody had this problem if so what did u do to fix it. let me know please, thnx.
Diego
Did you put the wire to the right pin.... did you solder the wire?
MellowVR4
Milwaukee, Wi
yea im pretty sure i did, the smallest plug from all three plugs on the ecu,the black wire just how the pictures show on dsmchips.com
Brunoboy
San Bruno,CA Home of SFO
you splice the red/black wire on the clutch pedal switch, run a wire from the switch part end to the ECU Black wire. try it again.
Make sure you connected to the right clutch wire. There is wiring for the cruise control also. You may have tapped one of those wires.
raptorWagon
Oak Harbor, WA
Have you checked your VSS (Vehicle Speed Sensor)? That could have gone bad and need to be replaced.
MellowVR4
Milwaukee, Wi
you mean that one with one prong by the throttle cable. yea i dont have that connected would that cause my 2step not to work.
MellowVR4
Milwaukee, Wi
Quoting brunoboy:
thats where im confused i dont know if you have to just cut the black wire on the plug and tap into that end and leave the other half of the wire just hangin. Then run the taped wire to the black and red clutch wire.
Brunoboy
The wire on the ecu cut un half the wire runs from black/red on the clutch switch to the ecu half black wire the other half tape and leave alone
raptorWagon
Oak Harbor, WA
Quoting MellowVR4:
That plugs into the trans, yes, then you're 2 step would not work. Try plugging that back in and see what happens.
MellowVR4
Milwaukee, Wi
the only ones that are on the trans are the reverse switch, and the sensor that has a cable attached to it. i heard that the vss is located on the cluster on 1g
MellowVR4
Milwaukee, Wi
Quoting MellowVR4:
Quoting brunoboy:
thats what i did /ubbthreads/images/graemlins/dunno.gif
MellowVR4
Milwaukee, Wi
got my 2step woking, dont really know what i did but it works /ubbthreads/images/graemlins/grin.gif. All i changed was the isc, jdm throttle body, and a idle position sensor.
