How Often Do Fan Clutches Fail?
Chim55117
Little Canada, Minnesota, United States
Just like the title states, I am wondering if a bad fan clutch could be causing my fan to turn on and off intermittently. The wiring is correct. If it is the fan clutch, where can I buy a replacement? On the VR-4, where is the fan clutch located? Anyone have a picture? Thanks!
- Stephen
grocery_getter
Its an electric motor. On or off. Not a fan clutch.
jepherz
KC, Missouri
You would want to check the temp switch, the fan relay, and the fan low-speed resistor instead, I'd think.
boostedinaz
Scottsdale, AZ
As mentioned our fans are electric (woogy woogy woogy) so they don't have a clutch. They do, however, cycle on and off depending on the temp of the coolant.
Are you overheating or just wondering about the fan cycles?
