GalantVR4.org
Galant VR-4 » Technical Discussions
Author Topic: HKS CAMS 264i/272e SET UP WITH CAM GEARS
peter_pie
Newbie
Post #: 742380 posted 01/06/09 07:24 PM     Remind Me!  Send New Private Message  Print Post    Edit Post
I am trying to find out what is the most common/proven setting (For adjustable cam gears that is) for the HKS 264i/272e cams on 1g 4g63 and Evo3 16g.
I know that on 272/272 set ups people are running -4,-1 or -3,-3.
However, there isn't much about the 264/272 set up on the internet even though they are often highly recommended for not so big turbos on 4g63.
Any advice based on real world experiences or trusted source would be appreciated.
Thanks in advance.
Peter
Posts: 7 | From: Brisbane | Registered: 01/06/09 | IP:  | Report this post to a Moderator
peter_pie
Newbie
Post #: 742784 posted 01/07/09 10:30 PM     Remind Me!  Send New Private Message  Print Post    Edit Post
Anyone?
Rausch Moderator
stvmow nao feels hawt
Post #: 742796 posted 01/07/09 11:03 PM     Remind Me!  Send New Private Message  Print Post    Edit Post
You really should dial them in yourself. Degree them and go from there if you have Dyno time available. Every engine will be a bit different, so the adjustments will vary.
Rance lives here...
No Longer JSB Pres.
Auto Cru.
Posts: 10819 | From: Cleveland, OH | Registered: 12/21/04 | IP:  | Report this post to a Moderator
peter_pie
Newbie
Post #: 742825 posted 01/08/09 12:59 AM     Remind Me!  Send New Private Message  Print Post    Edit Post
So once you dial the cams in; what is the most common/recommended amount of degrees to be retarded or advanced for each cam to get best all round performance (Low and mid torque is my preference). Just like the settings I mentioned earlier for 272/272s where cars with those cams (all dialed in) and then set to either -4,-1 or -3,-3 responded in the same manner meaning they experienced Lots more torque down low and in mid range and very little loss up the top and running E316g.
Any correlation there?
Luke
201/2000
Post #: 742877 posted 01/08/09 09:29 AM     Remind Me!  Send New Private Message  Print Post    Edit Post
Advance the intake gear for more low end, and better spool.
Retard the intake gear for shift the power band to the higher end, and possibly decreases spool ( depending on what turbo you have )
I have played with both, and I do like the slightly retarded intake gear setting ( -2i/0e )
2.3L 6-bolt, BJ's ported 2G head, TRE tranny, GT3076R, 255lph, 850cc, AFPR, ROM emulator, Aquamist, Griffin FMIC, LSD rr Quaife ft diff, WL swaybars, Hotbits, HKS 264/272 cams, ZT2 WBO2
Posts: 728 | From: San Jose, CA | Registered: 07/16/02 | IP:  | Report this post to a Moderator
Dialcaliper
Flagration Member
1269/2000
Post #: 742946 posted 01/08/09 12:01 PM     Remind Me!  Send New Private Message  Print Post    Edit Post
Cams and valve timing are actually affecting your effective compression and expansion ratios (which are quite different from the static compression ratio of your pistons). In a "theoretical engine" your cam would have a tiny 180 degree duration and instantaneous ramp rates (the valve opens to its full height immediately), and the intake and exhaust valves would open and close at the top and bottom of the stroke.
But because the air has inertia, and you can't open the valve immediately with a cam, you need to open the valves earlier so that the air starts moving before the piston starts down, and close them later so that you have the valve open while the air is still moving. You can also overlap the valves so that the air moving out of the exhaust "sucks" air in from the intake to get it started moving faster (aka scavenging)
All of those events mean that the actual compression ratio is never as high as the "static CR" of the pistons. This is why longer duration cams allow you to run more timing advance (because you've actually dropped your compression ratio even more). Alternately, you can bump the static CR ratio up higher to get back some of the actual CR that you lost. The longer duration the cam, the higher the static CR you need to get the same "actual" compression. (This is why people get away with running CR's of 9.0-10.0 while using large cams, but the same CR with shorter/stock cams are more likely to have detonation problems).
The general effects (broken down) are as follows:
Advance centerline (both cams): powerband moves to lower RPM
Retard centerline (both cams): powerband moves to higher RPM
Increase overlap (retard exhaust, advance intake): Sharper (higher) power/torque peaks, narrower powerband
Decrease overlap: (advance exhaust, retard intake intake): Flatter power/torque peaks, broader powerband
You are basically balancing valve opening and closing events to trade between stroke efficiency, effective compression (and expansion) ratios and cylinder filling efficiency.
Since the intake valve closes after the bottom of the intake stroke, closing the intake valve earlier gives you a longer compression stroke, and higher peak cylinder pressure.
But at higher RPMs the valves are open for a much shorter period - with the later intake opening there is not enough time for the cylinder to fill so the peak pressure actually drops off.
Likewise, the exhaust valve opens before the bottom of the exhaust stroke, so opening the exhaust valve later gives you a longer more efficient expansion stroke.
But at low RPM the exhaust valve closing later (while the intake valve is open) causes some of your intake charge to pass through the engine, and get vented into the exhaust manifold.
When you just move one gear, you're making two different adjustments, which can be good for specific situations. Advancing or retarding the intake gear only is an effective way to adjust engine behavior, without really messing everything up.
Advancing the intake gear simultaneously moves your powerband lower by moving the advancing the centerline (towards the RPM range of your turbo spoolup) and increases overlap, increasing the airflow at that point - you allow more air to pass out of the exhaust valve, helping the turbo spool and giving you a stronger, but peakier midrange. Obviously this ends giving you a up costing you on the top end because the earlier intake close reduces cylinder filling.
Retarding the intake gear simultaneously both moves your powerband higher (keeps the intake valve open longer) but also increases your compression and peak pressure, making the powerband broader and more drivable. You lose a little potential power due to lost overlap, but give the engine better manners in the mid to top end.
As you might guess, there's a lot of stuff going on, and a lot of compromises being made. The only way to really find the best setting is to decide what you're trying to do, and try adjusting a couple degrees at a time until you find what you want. There's no ideal setting for every part of the powerband (This is why variable valve timing is such a brilliant idea - you can, with certain limitations, find a more ideal setting for every part of the powerband)
Smaller turbos like advanced, shorter duration cams because they run out of breath up high, while big turbos are better with retarded, long duration cams because they spool up much later, and produce more power at the top end.
To make it even more complex, the cam settings on a turbo engine will vary based on where your turbo hits its sweet spot, and what kind of characteristics you're trying to get out of it. OEMs tend to put shorter cams with a peakier low end with small turbos, because you can make up for the loss at the top end by simply adding boost and throwing in taller gears. They do the same thing for auto transmissions. N/A MT cars tend to run higher RPMs, longer duration cams for more power, and shorter gearing. Ironically, cars with bigger turbos get tuned more like N/A engines.
Another sidenote is that a in a stroker engine, displacement is increased, but the valve events are happening at the same RPM as a normal stroke, you're just trying to pull more air in. As a result, the stroker will like a bit more cam duration and earlier valve opening due to the piston speed, but less overlap is required. This in turn gives you the characteristic of a broader torque band at lower RPMs (in addition to the increased torque from crank length). Likewise, it has a harder time breathing up top.
I guess I didn't really answer the question, because there's no "perfect" setting, but if you understand a bit about what's going on, you can experiment and find one you like with any type of cam.
1269/2000 Summit White
Edited by Dialcaliper (01/08/09 04:12 PM)
Posts: 1255 | From: Mountain View, CA | Registered: 06/22/07 | IP:  | Report this post to a Moderator
855/2000 828/1000
Post #: 742961 posted 01/08/09 12:20 PM     Remind Me!  Send New Private Message  Print Post    Edit Post
Excellent treatise and explanations. Thank you.
It handles like garbage, has no power and brakes are iffy. I kinda like it. Roger
91 VR4 855 Nile Black
92 VR4 828 Belize Green-New and improved! Now with a number.
91 VR4 115 Nile Black -SOLD
Posts: 7496 | From: Illinois | Registered: 03/05/01 | IP:  | Report this post to a Moderator
peter_pie
Newbie
Post #: 743113 posted 01/08/09 05:47 PM     Remind Me!  Send New Private Message  Print Post    Edit Post
Thanks for taking the time to answer my question Dialcaliper. Truly appreciated.
This is great in depth info. I always say that it is good to either have a mental picture or a real animation of the engine in motion to fully comprehend what you are talking about.
Ps. Did you take away some fuel down low on your 264/272 set up or do you just let it run rich with this overlap at idle.
Also, how much base ignition timing are you running? I have mine set to 10 and I know it could take more without knock but I am not sure if I should without Dyno run? Any advice there?
Cheers
BoostedAWD91
815/2000
Post #: 743178 posted 01/08/09 07:57 PM     Remind Me!  Send New Private Message  Print Post    Edit Post
Do u think its definatly beneficial to use adjustable cam gears if u upgrade cams? Im gonna run 264/264 most likey for my street car and have been going back and forth if i should invest in a set of cam gears or just use the stock
#815/2000- Lexus Pearl White
Posts: 2395 | From: Danville,Pa | Registered: 03/01/07 | IP:  | Report this post to a Moderator
peter_pie
Newbie
Post #: 743320 posted 01/09/09 03:08 AM     Remind Me!  Send New Private Message  Print Post    Edit Post
Hey BoostedAWD91 I think that the following thread might answer your question.
BoostedAWD91
815/2000
Post #: 743539 posted 01/09/09 05:08 PM     Remind Me!  Send New Private Message  Print Post    Edit Post
pretty much the same info as above
atc250r Moderator
Senior Ricer
1552/2000
Post #: 743555 posted 01/09/09 05:55 PM     Remind Me!  Send New Private Message  Print Post    Edit Post
Quoting peter_pie:
Honestly, I have never seen a GVR4/DSM on that can run that kind of base timing on a stock ECU. Our timing maps are fairly aggressive from the factory and in order to make the most of the available octane in a street car you'll probably need to run 5* (stock) or less. I realize you're in AUS so you might have different octane levels than we do in the U.S. but 10* base sounds like it'd even be a lot for race gas (116 octane).
John
Posts: 12945 | From: Orange County, NY | Registered: 09/11/03 | IP:  | Report this post to a Moderator
peter_pie
Newbie
Post #: 743570 posted 01/09/09 06:39 PM     Remind Me!  Send New Private Message  Print Post    Edit Post
Generally speaking you are right.
As you mentioned I live in Aus therefore I have access to 98octane, we used to have Shell V-power racing 100octane but for some reason no more.
My stock ecu (with keydivers tune for 98octane and extended maps to 25psi to say the least seams to be dealing with the tune for now.). I also have most of the necessary mods to support 25psi on E316g (no gas or water and no knock. I used tu run 23psi falling to 17 with more prone to knock setup but on 5* base timing(ported 14b, 450 at 44psi BFP, jap spec intercooler and keydivers chip)I used to get knock (keep in mind that my knock sensor was never replaced at that time) and it used to happened at whenever my butterflies in cyclone manifold where switching from long to short runners.(it wasn't the best set up as it was not working of the rpm's as it should). However a bottle of octane booster used to do the trick.
Anyhow, now I'm running bigger things with new knock sensor and 264/272 cams which allow me to run more advanced timing. Actually after I put the cams in the car felt not so good down low but nice up there. Cranking up the base timing to 10 woke up the car a lot but still not good enough. I had it advanced to more before and it felt really good down low in the rev range but I was not prepared to run it like that all the time without dyno time.
Hope this helps in anyway.
I wonder though how much potential Hp/Kw do we loose through the higher air temperatures we constantly see here in Aus (Brisbane, Queensland).
Cheers,
brisvr4
Bottom of the Planet
Post #: 743575 posted 01/09/09 07:00 PM     Remind Me!  Send New Private Message  Print Post    Edit Post
Peter, don't forget that our 98octane is about the same as 93 - 94 in the states as we us RON which is a different measurement.
And I also think that 10deg base timing is too high for that octane rating. Bu if it is working for you then that's great
1992 Auspec
11.69 @ 122.32 - E85 goodness!
Official Australian home of the Ugh decal!
Posts: 591 | From: brisbane australia | Registered: 02/13/04 | IP:  | Report this post to a Moderator
peter_pie
Newbie
Post #: 743661 posted 01/09/09 09:37 PM     Remind Me!  Send New Private Message  Print Post    Edit Post
Thats right Tim. I think it is the cams more than anything that allow me to run more advanced timing. Things will change after they are dialed in properly. I am sure of that.
Once I had my CAS 180* off (you know what I mean) and when I checked my base timing advance it was on about 20* I reckon. It was hard to say but it was there about. The car was going very hard down low. The boost was coming on instantly. When I checked the timing I wasn't happy. But guess what. Just a little knock came on. No more than 15 counts. After taking it back to 5* with the CAMs it felt like sloooow down low hence me turning it up to 10*.
Cheers,
atc250r Moderator
Senior Ricer
1552/2000
Post #: 743691 posted 01/09/09 10:28 PM     Remind Me!  Send New Private Message  Print Post    Edit Post
That doesn't make any sense. If you had the CAS off 180* then the timing wouldn't be off 20*. It sounds to me like you are misreading your timing marks or not putting the ECU into base timing mode. I can see the cams having a small effect on the amount of timing you can get away with but there is no way that you were running 20* base and only having a little knock. What are you basing these timing numbers off of? I'm assuming its off a timing light, right?
John
peter_pie
Newbie
Post #: 743801 posted 01/10/09 09:30 AM     Remind Me!  Send New Private Message  Print Post    Edit Post
In regards to the 10* timing advance here is some recommendations from RRE:
Advance Base Ignition Timing - Advance base ignition timing from 5 degrees stock to a total of 10 degrees. With 92 octane it is a waste of time, on 93-94 octane gas it can help some, usually you just end up back where you started after the ECU retards for knock. This is best done on high octane race gas.
Ref:http://www.roadraceengineering.com/gvr4upgradepath.htm
Notice though that their 10* recommendation does not apply to the 1g Talon/Eclipse upgrade path.
Also, Dialcaliper made a good point with the following statement which you can read a bit earlier:
"...All of those events mean that the actual compression ratio is never as high as the "static CR" of the pistons. This is why longer duration cams allow you to run more timing advance (because you've actually dropped your compression ratio even more). Alternately, you can bump the static CR ratio up higher to get back some of the actual CR that you lost. The longer duration the cam, the higher the static CR you need to get the same "actual" compression. (This is why people get away with running CR's of 9.0-10.0 while using large cams, but the same CR with shorter/stock cams are more likely to have detonation problems)."
I guess, running 10* should not be surprising or odd. With all the port work, big intercooler and the engine running rich because of the cams - I see no problems so far.
In regards to the 20* base timing; All I remember is that I did not have the timing light at that moment and I had to drive the car so I put the CAS back on and drove. Later when I had the timing light I checked the timing (it was done the right way too) and there we actually 3 of us DSMers (so we call our selfs ) when this happened and we all were shocked at the result of around 20* base timing . So we quickly tried to retard the timing but the mark was going back and forth, nothing constant but ruffly between 15-25* (Dont ask me, I dont know). Thats what it looked like to all of us.Keep in mind I had octane booster in my fuel from the last Q.Mile runs so that could have helped to keep the knock down to max 15counts at times but most of the time there was hardly any knock. Thats when we discovered that the mark on the Cas was 180* off. Just to make things clear when you are facing the pulley (being on the side of the car) the mark was to the left about 3cm. Thats advance right? I thought so. After getting timing back to 5(initially) the car felt like sh!t down low of boost and thats why I am running 10* base timing now. Not even because of what RRE recommends. It just looked right on my logger and my butt Dyno. I don't know if this does or doesn't make sense but I have no reason to mislead people. Its just not in my nature. Hope this experience might come in handy for some one day.
What do you think of this? When I replaced my stock intercooler piping with 2.5" my stock boost jumped from 11 to 18psi with the E316g. I never expected this to happen.
Cheers,
Luke
201/2000
Post #: 746322 posted 01/16/09 04:03 PM     Remind Me!  Send New Private Message  Print Post    Edit Post
You need to ground the timing-adjustment wire before you check base timing.
Otherwise, that is exactly what you will see. The ECU does not really run 5-degree timing at idle ( after the car is warmed-up etc ). The 5-degree is just the base timing, and the ECU adds timing on top of this base timing even at idle.
atc250r Moderator
Senior Ricer
1552/2000
Post #: 746523 posted 01/17/09 07:12 AM     Remind Me!  Send New Private Message  Print Post    Edit Post
Quoting atc250r:
.........or not putting the ECU into base timing mode...................What are you basing these timing numbers off of? I'm assuming its off a timing light, right?
I hate to quote myself but answering those questions is important in order for us to help you. The timing number displayed by the logger is assuming you have 5* base (although some MMCD's will allow you to adjust the logger to work from a different starting point but it will NOT change the actual timing the engine is seeing). Also, when RRE gives their figures based on octane ratings they are assuming you are in the US. The way we rate it here (R+M/2) is different than the way they rate it in Europe and AUS.
John
1 registered and 1 anonymous users are browsing this forum.
Moderator:  number3, Team Ducktape, Sam, atc250r, Terry Posten, jepherz, Rausch
Jump to
Generated in 0.613 seconds in which 0.316 seconds were spent on a total of 14 queries.
