Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Prothane motor mount in Galant VR4
gvr4me
Galant VR-4 org Post #: 681064 posted 08/13/08 10:00 AM     Remind Me!  Send Private Message   Edit Post
I bought these motor mount inserts and install them in my motor mounts. Then I dropped the engine in the engine bay. When I tried to install them in with my engine, only the transmission, driver side, and rear mounts would bolt on. The front mount is off by half of an inch. Did I install the back mount correctly? I will include some pictures to show you what I mean. Any advice would be greatly appreciated.
back mount top view:
back mount side view with flash:
front mount top view:
front mount side view:
Posts: 73 | From: MO | Member Since: 08/20/06 | IP: (168.166.253.161) | Report this post to a Moderator
3rdstrikedsm
Now mandatory for Wendy's Chili to come with cheese
Galant VR-4 org Post #: 681152 posted 08/13/08 01:15 PM     Remind Me!  Send Private Message   Edit Post
Are you sure that front mount bracket is gvr4 spec? If it is from a tel this would be the problem. I can't remember what the number is supposed to be on the gvr4 mount but I will check some time today.
I have the same mounts and they went right in with no trouble at all.
1994 supra 6spd 612whp and more to come soon!
1995.5 Audi s6 Vi-pec powered!
Posts: 3402 | From: 32159, FL | Member Since: 02/18/08 | IP: (98.212.163.184) | Report this post to a Moderator
gvr4me
Galant VR-4 org Post #: 681181 posted 08/13/08 02:12 PM     Remind Me!  Send Private Message   Edit Post
The car had TEL motor swap but I would think that they used the same mount brackets. Everyone said they had no problems putting the motor in so I don't know . Maybe someone can just check the numbers on the brackets for me. I can also take pictures of the other 2 brackets to make sure I didn't screw up putting them in. If the numbers are correct, then I really don't have clue. Maybe I'll just run 3 motor mounts.
strokin4dr
1280/2000
1135/2000
Galant VR-4 org Post #: 681182 posted 08/13/08 02:12 PM     Remind Me!  Send Private Message   Edit Post
You have the wrong front mount bracket on the engine. The galant vr4 specific mount # is 344.
1908- sold and missed.
1280- 2.3, FP 35R, E85, etc.
1135- 100% stock - 88k miles
Posts: 2744 | From: Savannah, GA | Member Since: 08/30/05 | IP: (71.229.63.35) | Report this post to a Moderator
gvr4me
Galant VR-4 org Post #: 681184 posted 08/13/08 02:13 PM     Remind Me!  Send Private Message   Edit Post
Hmm... I wonder why it bolt up when I first got the car..... I guess I can order a new bracket.
gvr4me
Galant VR-4 org Post #: 681185 posted 08/13/08 02:14 PM     Remind Me!  Send Private Message   Edit Post
Quoting strokin4dr:
Is the rear bracket number correct?
strokin4dr
1280/2000
1135/2000
Galant VR-4 org Post #: 681189 posted 08/13/08 02:21 PM     Remind Me!  Send Private Message   Edit Post
I will have to go check. Not sure on that one off the top of my head.
strokin4dr
1280/2000
1135/2000
Galant VR-4 org Post #: 681192 posted 08/13/08 02:25 PM     Remind Me!  Send Private Message   Edit Post
Yes, your rear bracket is correct. Change the front bracket to a 344 and you will be fine. Do you have the correct bracket already? If not, check the for sale section for a part out. They are NLA from the dealer.
Edited by strokin4dr (08/13/08 02:33 PM)
DSMTurbos
Galant VR-4 org Post #: 681283 posted 08/13/08 04:51 PM     Remind Me!  Send Private Message   Edit Post
what number should be on the rear bracket?
| | | IP: (64.14.85.2) | Report this post to a Moderator
IncorpoRatedX
I'm an idiot...
501/2000
Galant VR-4 org Post #: 681350 posted 08/13/08 07:35 PM     Remind Me!  Send Private Message   Edit Post
front bracket worked before because of stock motor mounts. I've seen this happen, basically your drivetrain was twisted a little bit. the prothane mounts make it impossible to put the TEL mount back on.
Good luck getting the GVR4/GGSX mount cheap though. I had to shell out like $50 for mine.
-Joshua Adventure Driven Design
Resto-mod squad.
1979 4G54 Galant Sigma Wagon (air con)
1984 Turbo Diesel Mighty Max 4WD
1991 Galant VR4
Posts: 5573 | From: Arizona | Member Since: 05/28/03 | IP: (98.226.54.106) | Report this post to a Moderator
IncorpoRatedX
I'm an idiot...
501/2000
Galant VR-4 org Post #: 681351 posted 08/13/08 07:37 PM     Remind Me!  Send Private Message   Edit Post
Quoting DSMTurbos:
195B but i've heard of others working.
Resto-mod squad.
1991 Galant VR4
strokin4dr
1280/2000
1135/2000
Galant VR-4 org Post #: 681384 posted 08/13/08 09:04 PM     Remind Me!  Send Private Message   Edit Post
^^I think that is correct. Mine says 195 of the top of it and so does yours in the pic.
14u2nV
Resident Pedobear
Galant VR-4 org Post #: 681575 posted 08/14/08 08:02 AM     Remind Me!  Send Private Message   Edit Post
FYI: 195 A and B are the same mount, it's A on one side and B on the other.
~Kenneth Brian
"Censorship offends me" ~Author Unknown
Posts: 9397 | From: Agency/St. Joe, MO | Member Since: 07/22/04 | IP: (207.192.252.228) | Report this post to a Moderator
gvr4me
Galant VR-4 org Post #: 687254 posted 08/27/08 10:51 AM     Remind Me!  Send Private Message   Edit Post
Thanks for the help guys, I got a mount bracket from a guy locally for $15 and it went in just fine.
Generated in 0.204 seconds in which 0.184 seconds were spent on a total of 14 queries. Turbo powered.
