Galant VR-4 Forums » Galant VR-4 » Technical Discussions » why does it smoke?
why does it smoke?
gsxtasee
Galant VR-4 org Post #: 416337 posted 12/10/06 12:41 AM     Remind Me!  Send Private Message   Edit Post
I am on engine #2 now (fully built engines, that is) and this one smokes too, though less than the first... the only things the same between the two are the head and turbo as far as stuff that could leak go...it doesn't seem to smoke on startup (leading me to believe it is not valve stem seals)but it does start to smoke after it has run for a while, especially if it is sitting at an idle for a few minutes...
so... whay does my car smoke?
| | | IP: (69.237.79.203) | Report this post to a Moderator
Josh Weaver
Galant VR-4 org Post #: 416348 posted 12/10/06 01:43 AM     Remind Me!  Send Private Message   Edit Post
it's a Mtsubishi.
What valves did you use? Rings?
-Josh
| | | IP: (76.170.178.145) | Report this post to a Moderator
Senior Ricer
1552/2000
Galant VR-4 org Post #: 416364 posted 12/10/06 06:29 AM     Remind Me!  Send Private Message   Edit Post
It's your valve stem seals. That is a classic symptom of bad valve seals. Sorry you did all that extra work for nothing but at least you can do the seals without removing the head.
John
Edited by atc250r (12/10/06 06:29 AM)
Posts: 13235 | From: Orange County, NY | Member Since: 09/11/03 | IP: (70.107.49.77) | Report this post to a Moderator
475/1000
Galant VR-4 org Post #: 416388 posted 12/10/06 09:32 AM     Remind Me!  Send Private Message   Edit Post
What color is the smoke?
White = steam = head gasket crack in the water jacket etc.
Black = fuel = to much and car isn't burning it. Could be a bad o2 and the afc or what ever can't commensate.
Blue = oil = valve stem seals, turbo seals, rings. If it doesn't worst after hard accel then its probably the carbons in the turbo. If the turbo is worn and hasn't rubbed the housings yet you can simply remove the housings and mark the wheels with a black sharpie then un bolt the compressor wheel nut and rebuild, lining everything up and re torqueing with a t handle.
92 GVR4 0475/1000
Greenhouse Effect Green
Exceeds Mechanical Limits
"Put the dawg to work.
Posts: 11891 | From: Clarksville TN | Member Since: 05/04/03 | IP: (71.87.191.159) | Report this post to a Moderator
marvinmadman
136/1000
Galant VR-4 org Post #: 416392 posted 12/10/06 09:51 AM     Remind Me!  Send Private Message   Edit Post
John
That's all you need to know right there.
1982/2000 sold
1263/2000 parts
136/1000 work n progress
08 ZX14
10 Ford Flex TT/AWD
05 Galant GTS
Posts: 2350 | From: Lafayette, Louisiana | Member Since: 11/10/03 | IP: (68.226.198.251) | Report this post to a Moderator
ANDRES
Galant VR-4 org Post #: 416540 posted 12/10/06 07:23 PM     Remind Me!  Send Private Message   Edit Post
It would be smart to check the turbo before you open the engine (anyway you have to take it off), it might need to be rebuilt and re -balanced) check for oil on the exhaust right after the turbo and air pipes between turbo and intercooler. When burning oil from the turbo, it has a strong smell as the oil doesn't burn by combustion but by hot temperature. If not problem found here, continue with the head.
| | | IP: (69.79.136.148) | Report this post to a Moderator
0 registered and 9 anonymous users are browsing this forum.
Generated in 0.104 seconds in which 0.087 seconds were spent on a total of 14 queries. Turbo powered.
