Thoughts on windage tray
ronkonkoma, ny
I'm building a rwd 4g63 and am already adding baffles to the rwd oil pan.
I was considering the addition of a windage tray or crank scrapper. In the case if the windage screen it would most likely be a slightly convexed 20 gauge screen attached by bolts welded to the inside of the pan so I could adjust the distance from the crank and also remove it if need be.
Have others here made either screens or scrapers for their 4g63?
ronkonkoma, ny
Seen this but don't like the idea of using the main bolts. I'm probably going to make one out of aluminum that bolts to the oil pan ring. Then weld an arched mesh windage tray over the top. I'll post when done.
bazeng
Melbourne, Australia
Make a girdle and attach it on that. Or use a kiggly one and attach accordingly?
This is my work in progress.
ronkonkoma, ny
wow. thats impressive.
I Ordered a crank scraper from click last night. Talked with him for over an hour. Real nice guy and very knowledgeable.
Going to do something like an evo9 windage tray attached to the pan I think
