Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Rear calipers replaced and bled...spongy pedal now
4dr_vr4
Galant VR-4 org Post #: 1241592 posted 02/11/18 10:52 AM     Remind Me!  Send Private Message   Edit Post
I replaced the rear calipers recently. I left the rear calipers off for a while waiting for new ones to ship. I lost a lot of fluid due to that. I went ahead and did a speed bleed of the rear calipers starting with the right rear. I *think* that the master ran dry by leaving the calipers off but I am not sure. Do the fronts now need to be bled as well?
I am also concerned because I purchased a set of Dorman speed bleeders and they bottomed out meaning the hex nut reached the caliper. I read a post on tuners where someone had that problem with some russell speed bleeders and it is supposed to be a no-go and yet when I press the brakes after the speed bleeders are tightened no fluid comes out so I am not sure if the speed bleeder is really at fault. In reality, I have only replaced just the left rear speed bleeder with the Dorman. The rest are Russell speed bleeders. For whatever reason, the speed bleeder/bleeder hole on the old caliper was only m8 as opposed to M10.
Any ideas?
Thanks.
Edited by 4dr_vr4 (02/11/18 11:14 AM)
Posts: 77 | From: NC | Member Since: 05/18/13 | IP: (71.206.182.9) | Report this post to a Moderator
Galant VR-4 org Post #: 1241593 posted 02/11/18 12:42 PM     Remind Me!  Send Private Message   Edit Post
You will likely need to fully bleed the entire system. Fluid goes through the ABS unit as well, so it helps to push new fluid through everywhere.
If the speedbleeders don't leak they may be ok. I don't have any personal experience with them, but have heard others have had issues with them working properly all the time.
91 VR4 855 Nile Black
92 VR4 828 Belize Green-SOLD
91 VR4 115 Nile Black -SOLD
Posts: 10607 | From: Michigan | Member Since: 03/05/01 | IP: (2600:1702:5a0:37) | Report this post to a Moderator
4dr_vr4
Galant VR-4 org Post #: 1241638 posted 02/15/18 11:48 AM     Remind Me!  Send Private Message   Edit Post
Thanks. It was actually the Dorman speed bleeder causing the issue. It was too short. Returned those and got some rusells and things are perfect. Just FYI, I have had awesome experience with speed bleeders. I don't have to annoy anyone to pump the brakes which is important to me.
Generated in 0.023 seconds in which 0.007 seconds were spent on a total of 13 queries. Turbo powered.
