Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Car Starts but Stalls Immediately after Built Engine Install
Chad989of2000
blows both ways and is skilled in magic with any mention of diarrhea
989/2000
141/1000
Galant VR-4 org Post #: 1216528 posted 09/15/15 03:30 PM     Remind Me!  Send Private Message   Edit Post
Finally got the engine in and everything hooked up. Car starts right up, revs to about 3k and then drops quickly to stall. Build is quite mild, just the usual Wiseco (9.0 pistons), Kelford 272 cams, EVO III 16G, and E-85. Fuel should be find as pressure is reading spot on (I use FIC 1100cc injectors with a re-wired walbro 255hp pump). I use link and have a wideband. I can get the car to stay running if I apply gas, both link and wideband show it funning extremely lean (off the scale on the wideband). I haven't run it for long since it's a brand new build and I don't want to break it in under these conditions. I'm thinking maybe CAS went bad, but it worked fine before the engine build up. Any other routes I should explore?
I certainly already checked for boost/vac leaks and found none.
Chad A.
-'91 GVR-4 989/2000
-'92 GVR-4 141/1000
-'92 Miata
-'15 Forester XT Touring
-'14 Fiesta ST
-'93 NSX
Posts: 1775 | From: Livermore, CA | Member Since: 01/13/05 | IP: (24.130.210.245) | Report this post to a Moderator
MellowVR4
5" too short
372/2000
Galant VR-4 org Post #: 1216534 posted 09/15/15 04:27 PM     Remind Me!  Send Private Message   Edit Post
Possibly a bad maf.
89 RAIDER V6 5speed
90 GALANT GSX SOLD
91 578/2000 sold
92 417/1000 DIED
87 4RUNNER LS400 SWAP SOLD:(
Posts: 1631 | From: Milwaukee, Wi | Member Since: 07/25/09 | IP: (69.11.233.34) | Report this post to a Moderator
Galant VR-4 org Post #: 1216540 posted 09/15/15 04:59 PM     Remind Me!  Send Private Message   Edit Post
Isc not set properly or just not functioning properly.
Log tps isc step and maf to rule out these as possibilities.
Edited by tektic (09/17/15 03:24 PM)
Posts: 1395 | From: ronkonkoma, ny | Member Since: 12/19/12 | IP: (172.56.35.85) | Report this post to a Moderator
715/1000
1284/2000
Galant VR-4 org Post #: 1216542 posted 09/15/15 05:16 PM     Remind Me!  Send Private Message   Edit Post
If your applying the throttle and it stays running, then check your TPS reading and log it to see if it's reading properly. (explains the lean condition too)
Otherwise, I agree with Tektic, your ISC isn't doing it's job otherwise, try backing out the BISS and see if that helps. If the CAS were bad completely then the ignition would not see RPM and fire at all. Chances are that's fine. Next would be the MAF.
#1284/2K NB, Totaled
#715/1K KG, Rebuilding
02 Acura TL daily duty unit
12yr+ Vr4 owner.
Honda/Acura master tech.
Family Guy
Posts: 4201 | From: Sioux Falls, SD | Member Since: 07/04/08 | IP: (96.2.247.27) | Report this post to a Moderator
Chad989of2000
989/2000
141/1000
Galant VR-4 org Post #: 1216548 posted 09/15/15 06:34 PM     Remind Me!  Send Private Message   Edit Post
Thanks for all the immediate responses. I'll start trouble shooting when I get some time. Is the used market the best place to find replacements if anything is found faulty, or are some of these items affordable new?
Chad A.
-'91 GVR-4 989/2000
-'92 GVR-4 141/1000
-'92 Miata
-'14 Fiesta ST
-'93 NSX
715/1000
1284/2000
Galant VR-4 org Post #: 1216577 posted 09/16/15 08:11 AM     Remind Me!  Send Private Message   Edit Post
Used parts are fine. They are great for swapping things around to try and find the problem before spending big bucks on new stuff
12yr+ Vr4 owner.
Family Guy
Chad989of2000
989/2000
141/1000
Galant VR-4 org Post #: 1216619 posted 09/16/15 02:55 PM     Remind Me!  Send Private Message   Edit Post
That seems like a solid strategy. Now I just gotta find the time to start diagnosing.
Chad A.
-'91 GVR-4 989/2000
-'92 GVR-4 141/1000
-'92 Miata
-'14 Fiesta ST
-'93 NSX
Chad989of2000
989/2000
141/1000
Galant VR-4 org Post #: 1241273 posted 01/10/18 02:40 PM     Remind Me!  Send Private Message   Edit Post
Bringing this thread back from the dead....a couple years have passed and I haven't had time to get to the car...until now.
First thing I did was drain the old E85 that was in there. Filled the tank with some fresh 91 octane. I then set about using ECMLink to change my global settings to accommodate the 91 instead of the E85. Tested battery (had it on a tender) and it tested fine. Tested fuel pump with Link and whirs just like it should. The engine turns over but doesn't start. Before I could get it to run with throttle application, now it won't start no matter what I do. Gonna start by checking for spark. Not really thinking the MAF is bad (it's a 482) and has always functioned perfectly. Any other things to check out?
Chad A.
-'91 GVR-4 989/2000
-'92 GVR-4 141/1000
-'92 Miata
-'14 Fiesta ST
-'93 NSX
Posts: 1775 | From: Livermore, CA | Member Since: 01/13/05 | IP: (67.160.220.10) | Report this post to a Moderator
Chad989of2000
989/2000
141/1000
Galant VR-4 org Post #: 1241275 posted 01/10/18 02:49 PM     Remind Me!  Send Private Message   Edit Post
Does my math check out?
Chad A.
-'91 GVR-4 989/2000
-'92 GVR-4 141/1000
-'92 Miata
-'14 Fiesta ST
-'93 NSX
Chad989of2000
989/2000
141/1000
Galant VR-4 org Post #: 1241276 posted 01/10/18 02:56 PM     Remind Me!  Send Private Message   Edit Post
Fuel is getting to the rail. Aeromotive FPR is showing normal fuel pressure after cranking the engine.
Chad A.
-'91 GVR-4 989/2000
-'92 GVR-4 141/1000
-'92 Miata
-'14 Fiesta ST
-'93 NSX
strokin4dr
1280/2000
1135/2000
Galant VR-4 org Post #: 1241277 posted 01/10/18 04:40 PM     Remind Me!  Send Private Message   Edit Post
Injectors are clogged up and not spraying. Pull them out and send them off to be cleaned and flow tested.
1908- sold and missed.
1280- 2.3, FP 35R, E85, etc.
1135- 100% stock - 88k miles
Posts: 2754 | From: Savannah, GA | Member Since: 08/30/05 | IP: (2601:900:8202:48) | Report this post to a Moderator
Chad989of2000
989/2000
141/1000
Galant VR-4 org Post #: 1241281 posted 01/10/18 06:52 PM     Remind Me!  Send Private Message   Edit Post
Should have mentioned...brand new FIC 1100cc injectors.
Chad A.
-'91 GVR-4 989/2000
-'92 GVR-4 141/1000
-'92 Miata
-'14 Fiesta ST
-'93 NSX
strokin4dr
1280/2000
1135/2000
Galant VR-4 org Post #: 1241282 posted 01/10/18 10:00 PM     Remind Me!  Send Private Message   Edit Post
Have you checked for signal at the injectors?
I ain't no puny human
1025/2000
Galant VR-4 org Post #: 1241283 posted 01/11/18 06:24 AM     Remind Me!  Send Private Message   Edit Post
Are you smelling fuel? What does Link state your coolant temp is?
Thom
1992 GVR-4 866/1000. Ready for all of the above.
1992 GVR-4 148/1000. Rescue
Posts: 760 | From: Indianapolis, IN | Member Since: 09/24/14 | IP: (12.109.79.254) | Report this post to a Moderator
Chad989of2000
989/2000
141/1000
Galant VR-4 org Post #: 1241286 posted 01/11/18 11:16 AM     Remind Me!  Send Private Message   Edit Post
Quoting strokin4dr:
Have not yet, but plan to just to make sure the injectors are functioning properly.
Chad A.
-'91 GVR-4 989/2000
-'92 GVR-4 141/1000
-'92 Miata
-'14 Fiesta ST
-'93 NSX
Posts: 1775 | From: Livermore, CA | Member Since: 01/13/05 | IP: (17.224.23.187) | Report this post to a Moderator
Chad989of2000
989/2000
141/1000
Galant VR-4 org Post #: 1241287 posted 01/11/18 11:18 AM     Remind Me!  Send Private Message   Edit Post
Quoting thomcasey:
Not smelling fuel at all. No leaks around the injectors. I will log the coolant temp when I get a moment. Are you thinking coolant temp sensor?
Chad A.
-'91 GVR-4 989/2000
-'92 GVR-4 141/1000
-'92 Miata
-'14 Fiesta ST
-'93 NSX
1025/2000
Galant VR-4 org Post #: 1241288 posted 01/11/18 11:40 AM     Remind Me!  Send Private Message   Edit Post
It can definitely cause a not start. if it reads -74, it will dump fuel and flood. If it reads in the high 200's or 300's, it will cut fuel.
Thom
Galant VR-4 org Post #: 1241289 posted 01/11/18 12:07 PM     Remind Me!  Send Private Message   Edit Post
Quoting Chad989of2000:
Are they the same new parts installed back in 2015? If so, they have sat with fuel having been run through them at some point. If different than those installed then, disregard.
91 VR4 855 Nile Black
92 VR4 828 Belize Green-SOLD
91 VR4 115 Nile Black -SOLD
Posts: 10549 | From: Michigan | Member Since: 03/05/01 | IP: (205.144.100.200) | Report this post to a Moderator
Chad989of2000
989/2000
141/1000
Galant VR-4 org Post #: 1241290 posted 01/11/18 05:50 PM     Remind Me!  Send Private Message   Edit Post
Quoting thomcasey:
For sure, it is certainly on my list to test.
Chad A.
-'91 GVR-4 989/2000
-'92 GVR-4 141/1000
-'92 Miata
-'14 Fiesta ST
-'93 NSX
Chad989of2000
989/2000
141/1000
Galant VR-4 org Post #: 1241291 posted 01/11/18 05:53 PM     Remind Me!  Send Private Message   Edit Post
Quoting iceman69510:
They are the same from back in 2015. Never had gas run through them...only E85. I've heard that ethanol can get a little gunky over time. I can certainly send them to FIC to get a cleaning and flow check and cross that off my list of possible issues.
Chad A.
-'91 GVR-4 989/2000
-'92 GVR-4 141/1000
-'92 Miata
-'14 Fiesta ST
-'93 NSX
Chad989of2000
989/2000
141/1000
Galant VR-4 org Post #: 1241292 posted 01/11/18 05:54 PM     Remind Me!  Send Private Message   Edit Post
Again, thank you so much for all the advice guys. Can't wait to get her up and running. It has been...way...too...long.
Chad A.
-'91 GVR-4 989/2000
-'92 GVR-4 141/1000
-'92 Miata
-'14 Fiesta ST
-'93 NSX
AllanL
Heal and Toe
Galant VR-4 org Post #: 1241293 posted 01/11/18 08:03 PM     Remind Me!  Send Private Message   Edit Post
compression test?
Posts: 241 | From: NV | Member Since: 08/05/08 | IP: (122.53.101.242) | Report this post to a Moderator
strokin4dr
1280/2000
1135/2000
Galant VR-4 org Post #: 1241294 posted 01/11/18 08:18 PM     Remind Me!  Send Private Message   Edit Post
Then this is definitely one of your issues. I bet they are frozen shut! Check for signal first before pulling them though.
-Ryan
89Mirageman
Galant VR-4 org Post #: 1241317 posted 01/14/18 08:38 PM     Remind Me!  Send Private Message   Edit Post
You can fab up a simple tool to clean injectors. Think it's on Jafromobiles youtube videos. While it may not be as good as the guys with professional equipment, it should at least let you know if that's your issue or not. I fabbed up one to clean the oe injectors from the 89 Raider I had a few years back and it worked perfectly.
94 Eagle Summit DL coupe
98 Mitsubishi Mirage DE sedan
15 Mitsubishi Mirage ES hatch
Posts: 2499 | From: Stantonsburg, NC | Member Since: 07/05/06 | IP: (65.41.184.95) | Report this post to a Moderator
Chad989of2000
989/2000
141/1000
Galant VR-4 org Post #: 1241443 posted 01/27/18 02:41 PM     Remind Me!  Send Private Message   Edit Post
Finally got a few minutes on the car today...a 1 year old and life stuff can sure get in the way.
Took the battery off the tender and threw it in. I then attempted to start it up but it wouldn't even turn over. Checked the battery and got 12.34 volts, but clearly the amperage wasn't there. So first thing on my list is a new battery.
Chad A.
-'91 GVR-4 989/2000
-'92 GVR-4 141/1000
-'92 Miata
-'14 Fiesta ST
-'93 NSX
Pages: 1 | 2 | 3 | 4
0 registered and 23 anonymous users are browsing this forum.
Generated in 0.045 seconds in which 0.004 seconds were spent on a total of 14 queries. Turbo powered.
