Galant VR-4 Forums » Galant VR-4 » Technical Discussions » What do you lube your coilovers pillow balls with?
Nebraska
1099/2000
Galant VR-4 org Post #: 1238690 posted 07/23/17 10:49 AM     Remind Me!  Send Private Message   Edit Post
Read a few different things around the web like lithium grease or wd40. What has worked for you guys because I don't want to damage mine!
1099/2000 Summit white
"Do it once, Do it right."
Posts: 120 | From: Lincoln, NE | Member Since: 04/09/15 | IP: (76.84.215.80) | Report this post to a Moderator
138/2000
Galant VR-4 org Post #: 1238691 posted 07/23/17 11:48 AM     Remind Me!  Send Private Message   Edit Post
I had gotten a set of old ksport from Justin Warren and I used on blaster on those and on my new Megan's I have I use white lithium grease every 5k miles, just a little squirt. Depending how bad yours are, you can pull the top hat off and take the ball out, clean it and use Hi-Tech grease like wheel bearing grease and be set for a while..
138/2000
Posts: 3518 | From: Klamath Falls, Or | Member Since: 07/27/11 | IP: (71.89.204.234) | Report this post to a Moderator
Nebraska
1099/2000
Galant VR-4 org Post #: 1238694 posted 07/23/17 05:27 PM     Remind Me!  Send Private Message   Edit Post
Blaster as in the penetrating oil? Right on, I didn't know the ball would come out that easily. I currently have some D2 coils and they've gotten many particles from being in the garage so I have to clean them out. Should I dab the grease around the ball and turn the wheel left and right to work it in? Didn't wanna unbolt the lower strut mount to set it in but I guess I will if I have to.
EMX5636
Carbon Fiber Cage
108/2000
Galant VR-4 org Post #: 1238833 posted 08/01/17 09:16 AM     Remind Me!  Send Private Message   Edit Post
Just be careful. Most liquid lubricants will actually attract dirt/grit and wear the joint out faster. For this, I'd recommend a dry lubricant spray, and wipe off any excess. Another thing to consider is, some pillow ball joints have a thin layer of teflon or other material in the cup so no lubricant is necessary.
91 #108/2000- link
97 Kawi ZX7R Street/Track
03 Kawi KLX400R Supermoto
05 CTS-V Stealth Grey
09 Hummer H3T
Posts: 1625 | From: Bucks County, PA | Member Since: 06/28/08 | IP: (2601:49:100:25a1) | Report this post to a Moderator
Nebraska
1099/2000
Galant VR-4 org Post #: 1238845 posted 08/01/17 07:56 PM     Remind Me!  Send Private Message   Edit Post
Ended up using a few drops of zoom oil. High grade oil seems to do the trick
Generated in 0.095 seconds in which 0.084 seconds were spent on a total of 14 queries. Turbo powered.
