abikepeddler
Active member
I'm such a sic pup... A cracked bell housing has ended up leading me to not only fix that issue but to basically tear the entire car apart and fix EVERYTHING. So basically I have torn #1607 apart. Just pulled out the clutch and wanted an opinion if I should replace it. I'm guessing the answer will be yes but just wanted verification from those of you that are far wiser than I. Clutch does not slip when I drive the car but the disc is looking a bit thin and the flywheel is pretty glazed. Also on a side note does the starter backing plate normally have some bend in it or it supposed to be dead flat? Mine has some subtle undulations that look Factory. Thanks for any input... I want to take care of crap while I have everything apart.
