ABS rotor stuck on drive shaft
bigandbad
Hamburg, Germany
My outer wheel bearings are crap - bought all the stuff to overhaul the rear driveshaft and have to face a new problem...
The brass ABS rotor is stucked at the shaft, it doesn't move anyway.
Can't use my hydraulic press because the wheel hub is too big....
Any suggestions?
Nebraska
Lincoln, NE
Maybe saw a slit in each side and smack it good assuming you'd like to get rid of the ABS. For me, I just took the spindles to a shop and they put the new bearing and seal on. Sorry I don't have more for you this time. Maybe an impact could give the extra jolt it needs
bigandbad
Hamburg, Germany
@Nebraska: deleting the ABS is not an option. To keep it strrelwgal, the ABS must be functional. I would kill the gear if a new was available - but these are discontinued...
I have some too.
bigandbad
Hamburg, Germany
Update:
After heating it with an electric heatgun, the puller at its maximum, at medium temperature for half an hour it suddenly decided to move with a big bang...
Thx to all for your advices!
