5th O2 sensor wire?
Iggy
Ashland. Wi
Today went to replace my O2 sensor and was surprised to find a 5th wife in the loom before the 02 connector. I can't find the other half of it, but I'm guessing to goes some where? doesn't help that the insulation is gone.
G
zompton
That's a ground.
Iggy
Ashland. Wi
A ground for what?
G
zompton
Or shielding, I forgot.
mjdarg
Active member
Raleigh, NC
Yea, that looks like shielded that is in the harness under the heat shrink.
Agreed, that is the shielding wire.
FlyingEagle
THE Ottawa
See the diagram in the site thread below.
Click for GVR4 thread
It's a big fanout sheet for 4g63 type wiring. Pins with the little circles drawn around the wires, for the 02 sensor and the knock sensor are a shared shield setup; open an unattached at one end, connected at the other, but not part of a circuit - just noise/RF rejection, likely only could be causing by radios/plugs/etc.
I just build a little harness to replace my current one should anything in it go bad, and I had my hands on those wires first hand. The other guys before me, nailed it!
