Galant VR-4 Forums » Galant VR-4 » Technical Discussions » downshifting is smooth as silk, upshifting is notchy - normal?
scottinalaska
676/1000
Galant VR-4 org Post #: 1234296 posted 12/20/16 02:55 PM     Remind Me!  Send Private Message   Edit Post
I have no problem engaging into any gear, but shift up anything but nice and slow, it will click in right after you feel the resistance. Downshift is so sweet you think you're downshifting a Honda. zero noise, zero resistance, no matter how fast you go.
Is this normal or a sign of something. The clutch is 1K old. Running Amsoil 75/90 GL4 as recommended.
Posts: 47 | From: Alaska, USA | Member Since: 11/15/16 | IP: (24.237.106.213) | Report this post to a Moderator
gvr4ever
Forever Member
347/1000
Galant VR-4 org Post #: 1234297 posted 12/20/16 03:26 PM     Remind Me!  Send Private Message   Edit Post
It can be a few things. Cheapest, easiest thing to check is the shifter bushings on the transmission. I've never driven a really smooth Mitsubishi transmission. Not like a BMW or Miata. I had a odd ball POS FWD Turbo Talon that had a really butter smooth transmission. Smoother then my GVR4 has ever been. Mine feels more mechanical.
1992 Nile black w/sunroof
Posts: 5808 | From: Crawfordsville, IN | Member Since: 08/06/02 | IP: (128.210.106.178) | Report this post to a Moderator
turbofonz
Member +
255/1000
153/2000
369/2000
490/2000
Galant VR-4 org Post #: 1234299 posted 12/20/16 06:02 PM     Remind Me!  Send Private Message   Edit Post
Checking all bushings and mounts is a good place to start. When the shifter is in gear, how much slop is there?
Bleed the clutch. I swear, I just did it to my 4 cars, and every car I noticed smoother shifting after.
Ryan W.
Posts: 438 | From: Granby, MA | Member Since: 09/27/06 | IP: (73.142.6.86) | Report this post to a Moderator
383mazda
860/1000
Galant VR-4 org Post #: 1234352 posted 12/22/16 11:47 AM     Remind Me!  Send Private Message   Edit Post
I just tossed in a "new" transmission (Shep trans that had been sitting in a corner in some shop for years...) and brand new clutch - all new shifter cables with new bushings on the transmission side (only one cable is adjustable), and all new bushings in the shifter linkage and aluminum bushings for the shifter base...
First is a little hard to select, but no grinding at all, 2nd to 3rd gear is crunchy unless I A) shift slowly, or B) am WOT past 5 grand??? (guess which option I pick, lol )
I still need to fine tune the clutch peddle, swap to Amsoil MTG and I could try bleeing clutch again.
The only other thing is maybe adjusting the shifter base? If I shift into 3rd aiming a little wide (towards the 5th gear side of the gate) rather than dead center on 3rd that seems to help. My 4-5 change feel like my miata, which is arguably the best shifting car in the world, so hopefully I don't mess that shift up when I adjust everything...
Wife's car: 2004 Subaru Forester XT
My car: 1992 GVR4 #860/1000
Let the battle begin!!!
Posts: 61 | From: Gainesville, TEXAS | Member Since: 10/10/15 | IP: (75.141.153.242) | Report this post to a Moderator
scottinalaska
676/1000
Galant VR-4 org Post #: 1234360 posted 12/22/16 10:19 PM     Remind Me!  Send Private Message   Edit Post
I have hardly any slop at all and the bushings appear good and do not show any significant movement. I'll have to try the 5K shift method.
0 registered and 26 anonymous users are browsing this forum.
Generated in 0.232 seconds in which 0.215 seconds were spent on a total of 14 queries. Turbo powered.
