383mazda
Car needs a new transmission and timing belt (current mileage: 115k), so I figure I'll just pull the motor and knock it all out at once. Advise I'm looking for is what other things (mods / maint) should I do while the motor is out.
Here's a quick list of stuff I'm planning, let me know what else you would do (budget of about $300 on top of what I have planned)
Pulled motor:
New timing belt
Full Gasket / Seals kit
Balance shaft delete
New rubber coolant hoses
?? Oil pump??
?? Oil filter housing / oil filter remote mount (to make room for downpipe in future)
?? New gen 3 lifters ?? (nothing ticking currently)
?? anything else
Engine Bay:
ABS delete (new prop vale and hard lines from DSM)
pressure wash and clean
Trans:
Issue is clutch engagement and 1st and 2nd gear crunching - supposedly has brand new ACT 2600, fork, pivot ball and throw out bearing - I have adjusted and replaced everything clutch related (MC / SC, welded pedal assy, shifter cables and bushings bleed, bleed and bleed some more. Even longer push rod, still had to adjust it way too far and clutch continues grabbing right off the floor /ubbthreads/images/graemlins/banghead.gif ) New Amsoil trans fluid and still grinding gears.
Got an old 0 miles Shep trans ready to go, but clutch is still unknown... Worst case I'll need a new clutch and flywheel (will use SBC)
Best case - shim pivot ball??
SO tell me, what are some other practical and crazy things you would do while the motor is out. Future plans for the car are probably an HTA68 or FP Green and supporting mods...
Thanks guys!
Pulled motor:
New timing belt
?? Oil pump??
?? anything else
Engine Bay:
Trans:
Thanks guys!
