Galant VR-4 Forums » Galant VR-4 » Technical Discussions » OBDII Port Wiring with a Blackbox 2G ECU Swap
Mac
860/1000
Galant VR-4 org Post #: 1224614 posted 02/23/16 08:29 AM     Remind Me!  Send Private Message   Edit Post
I built a jumper harness to swap a 2G flashable ECU into my 90 Talon AWD. I know it's not a GVR4, but the wiring should be the same.
I can't find a list of which wires on the OBDII port need to be connected and to where they be connected. Currently, I have OBDII pin 1 attached 2G ECU pin 56 with the yellow wire and OBDII port 7 to 2G ECU pin 62 with the pink wire according to the wiring guide I found.
What else needs to be connected?
Posts: 54 | From: Memphis, Tn | Member Since: 05/15/11 | IP: (208.115.24.194) | Report this post to a Moderator
Galant VR-4 org Post #: 1225587 posted 03/16/16 10:52 AM     Remind Me!  Send Private Message   Edit Post
The only wires the OBDII port needs from the ecu are power, ground, and K-line. The L-line is not used.
Connect OBD2 Pin 4 to chassis ground - DSM pin 101
and OBD2 pin 16 to switched power - DSM pin 102
Posts: 1403 | From: ronkonkoma, ny | Member Since: 12/19/12 | IP: (74.71.69.137) | Report this post to a Moderator
Spyke169
Member +
Galant VR-4 org Post #: 1225663 posted 03/17/16 08:34 PM     Remind Me!  Send Private Message   Edit Post
Hopefully this is everything you need click
'90 Galant GSX, Daily Driver
'93 TSI AWD, Project Car
Sold the VR4s that I have owned, miss them everyday.
Posts: 324 | From: Greenfield, Wi | Member Since: 08/17/05 | IP: (2602:304:b095:ca) | Report this post to a Moderator
Generated in 0.231 seconds in which 0.223 seconds were spent on a total of 14 queries. Turbo powered.
