Galant VR-4 Forums » Galant VR-4 » Technical Discussions » EGR pin 53 on 92 Vr4
marvinmadman
136/1000
Galant VR-4 org Post #: 1216983 posted 09/21/15 12:02 PM     Remind Me!  Send Private Message   Edit Post
Where does it go? The wire is in the harness and I'd like to use that with Ecmlink to control something. I'd hate to cut it and run another wire through the firewall if the current wire is already under the hood somewhere. So where is the other end at? Also the color is Light green/blue, not Black/yellow as in all the diagrams I found.
1982/2000 sold
1263/2000 parts
136/1000 work n progress
08 ZX14
10 Ford Flex TT/AWD
05 Galant GTS
Edited by marvinmadman (04/05/16 08:04 PM)
Posts: 2350 | From: Lafayette, Louisiana | Member Since: 11/10/03 | IP: (2600:100d:b121:a) | Report this post to a Moderator
marvinmadman
136/1000
Galant VR-4 org Post #: 1226425 posted 04/05/16 08:02 PM     Remind Me!  Send Private Message   Edit Post
Well I finally found it. Real obvious spot too. Right next to the underwood fuse box. So now I could literally connect the temp switch wire from the back of the Thermo housing to this EGR connector without any extra wire. It reaches right across.
Posts: 2350 | From: Lafayette, Louisiana | Member Since: 11/10/03 | IP: (2600:387:1:810::) | Report this post to a Moderator
cupajoe
Member +
1242/2000
Galant VR-4 org Post #: 1237227 posted 05/16/17 11:49 PM     Remind Me!  Send Private Message   Edit Post
Instead of starting a new thread for this, where is this plug on the 91? Because I'm trying to do the same thing and I do NOT have that plug coming from that wire loom.
GVR4 1242/2000
Posts: 321 | From: Wasilla, Alaska | Member Since: 03/01/10 | IP: (66.58.184.202) | Report this post to a Moderator
0 registered and 17 anonymous users are browsing this forum.
Generated in 0.099 seconds in which 0.09 seconds were spent on a total of 14 queries. Turbo powered.
