Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Need opinion on a tune
vr4hotness
New Daddy
436/2000
Galant VR-4 org Post #: 1215793 posted 09/02/15 11:08 PM     Remind Me!  Send Private Message   Edit Post
Need your opinion plz
Tuner said it was crappy 91 octane gas
I was getting really bad knock at 4k and above,
Look at the graph
Mods
E3turbo
880cc
Full bolt ons
272/272
3g lifters
Multi layer head gasket
Aem tru boost
Ecmlink v3
Ets fmic
Car was running great with no issues minus that
852/2000 (sold
436/1000 rust free
(Beer is living proof that god loves us and wants us to be happy)- Benjamin Franklin
Posts: 182 | From: Chino Hills, California | Member Since: 12/02/10 | IP: (96.229.161.95) | Report this post to a Moderator
A hole
820/1000
1837/2000
Galant VR-4 org Post #: 1215806 posted 09/03/15 06:31 AM     Remind Me!  Send Private Message   Edit Post
Output looks low for the boost level.
I need a log...Preferably one from the dyno pull. Any 3rd gear pull from ~3k to redline will work, though.
820/1000
1837/2000
1546/2000-SOLD
1813/2000-SOLD
Posts: 3373 | From: SoCal | Member Since: 01/02/12 | IP:
(72.45.2.251) | Report this post to a Moderator
CutlassJim
poop load of room
1799/2000
1788/2000
935/1000
912/1000
Galant VR-4 org Post #: 1215809 posted 09/03/15 07:43 AM     Remind Me!  Send Private Message   Edit Post
And not hitting 18lbs until 4000 rpm? Either you have some mechanical issues or that's a poopy tune. I find it suspect too that the A/F ratio isn't also on the graph with the boost. Post a log please.
I love my crazy mother!!!
Posts: 1542 | From: Manchester, NH | Member Since: 07/17/06 | IP: (74.94.142.161) | Report this post to a Moderator
OldHairyBastard
I take bottom on trannies
1/0000
Galant VR-4 org Post #: 1215811 posted 09/03/15 07:57 AM     Remind Me!  Send Private Message   Edit Post
Jim's right about the air fuel mixture. Without being able to see where your air fuel is in the RPM it will be hard to give good advice an the tune you have. I do find it a bit strange that your torque is that much higher than your HP. It would be nice to see where your timing is set to across the RPM range. What type of waste gate and exhaust do you have?
1990 G-GSX-RS Conversion-138M
1999 Toyota Camry 3.0L V6-202M
2008 Toyota Sequoia 5.7L V8-113M
2013 Toyota Tundra 5.7L V8-88M
2017 VW Passat 1.8L Turbo-23M
Posts: 4497 | From: Lindenhurst, IL-Northern Chica... | Member Since: 04/27/05 | IP: (50.193.72.173) | Report this post to a Moderator
vr4hotness
New Daddy
436/2000
Galant VR-4 org Post #: 1215815 posted 09/03/15 08:23 AM     Remind Me!  Send Private Message   Edit Post
I will try and get a log set up today, I've never done one on ecmlink before.
2.5inch exhaust and a evo3 wastegate
852/2000 (sold
436/1000 rust free
1990/2000
Galant VR-4 org Post #: 1215822 posted 09/03/15 08:49 AM     Remind Me!  Send Private Message   Edit Post
102 degrees Fahrenheit ambient air temperature is not optimal conditions to try and set up / optimize a tune.
... with no changes other than a drop in ambient temperature, I bet you find some missing ponies
Posts: 3532 | From: Never Summer Ranch, Colorado | Member Since: 04/30/06 | IP: (70.196.198.74) | Report this post to a Moderator
vr4hotness
New Daddy
436/2000
Galant VR-4 org Post #: 1215839 posted 09/03/15 10:45 AM     Remind Me!  Send Private Message   Edit Post
Ya was super hot, but that a big loss in power across the band.
What values should I capture in the log ?
852/2000 (sold
436/1000 rust free
Posts: 182 | From: Chino Hills, California | Member Since: 12/02/10 | IP: (2607:fb90:21c1:9) | Report this post to a Moderator
OldHairyBastard
1/0000
Galant VR-4 org Post #: 1215859 posted 09/03/15 12:55 PM     Remind Me!  Send Private Message   Edit Post
With or without a CAT? Also what MASS/MAF are you using if any?
Quoting vr4hotness:
Edited by OldHairyBastard (09/03/15 12:57 PM)
r4pt0x
Galant VR-4 org Post #: 1215862 posted 09/03/15 01:23 PM     Remind Me!  Send Private Message   Edit Post
I have overpressure from ~1800rpm and easily >1bar at 3000rpm with an evo3 16g, stock Galant RS cams ('92 model) and a little over 9:1 CR (1.8l head). peak+hold boost is ~1.5-1.6 bar (~24psi). Only knock events are at ~2800-3000rpm which are mostly only harmonics from the engine missing its balance shafts.
Are you using any boost control or driving direct wastegate-pressure? Latter one could fit your very slow boost builtup.
Your torque is accordingly quite low, especially considering the cams which should get much more air into the cylinders (if timing is set up properly...).
What are the 880cc injectors for? You're planning on using E85? I was running on stock evo9 injectors (560cc) and they weren't even close to be maxed out... I only switched to 1000cc PTEs for E85 and later engine&turbo upgrades.
The logs should include: rpm, TPS, load, ignition, AFR map and WB02 and eventually boost, which is/should be (in kPa) roughly identical to the load value anyways and hence isn't terribly important unless your MAF scalings are way off...
If you use ECU-based boost control, wastegate-duty might also be interesting to clarify the slow boost built-up.
Posts: 123 | From: Bavaria / Germany | Member Since: 11/20/13 | IP: (24.134.98.243) | Report this post to a Moderator
vr4hotness
New Daddy
436/2000
Galant VR-4 org Post #: 1215867 posted 09/03/15 01:55 PM     Remind Me!  Send Private Message   Edit Post
No cat
Evo8 maf sensor
852/2000 (sold
436/1000 rust free
EfiniX
Member ++
543/1000
Galant VR-4 org Post #: 1216029 posted 09/06/15 02:48 PM     Remind Me!  Send Private Message   Edit Post
Quoting GSTwithPSI:
THIS
I would expect you closer to 280hp at that boost level. You must be running fairly low timing or something else is wonky...
RIP 543
Ded click
2006 Suzuki SV-650 (for sale)
2011 BMW 335d (~510'lb/tq and 36mpg. hwy. How can you go wrong?)
Posts: 647 | From: portland, or | Member Since: 10/18/12 | IP: (108.13.154.91) | Report this post to a Moderator
1 registered and 9 anonymous users are browsing this forum.
Generated in 0.219 seconds in which 0.195 seconds were spent on a total of 14 queries. Turbo powered.
