belize1334
Or is this a 6-bolt G4CS with the letters 4G64 stamped on it? My understanding is that there is no such thing as a 6-bolt 4g64. But I've been through the bottom of this thing. It's a 6-bolt. It has a 86.5mm bore, and it's not a wide block 'cause it has the same transmission pattern as my 2.0. The picture is a bit hard to make out 'cause the surface corrosion has just about wiped the letters clean off but I'm fairly certain it reads 4G64. What do you think?
