Shifter cable brackets
marvinmadman
Lafayette, Louisiana
Anybody know off hand what I'll need to correct this dogleg in the shifter cable?
Looks like the bushings between the top and bottom bracket could be worn out. Hard to tell from the picture but you can pull the brackets remove the old bushings clean well and just bolt together with normal bolts making sure there centered then weld.
ktmrider
Tempe, AZ
Make sure you don't have 90 TEL brackets, good thread here: click
marvinmadman
Bushings are all good. I remembered about the different brackets but didn't really have the time to search. I'll read the link. Thanks
marvinmadman
It appears that the shifter brackets I have are correct. What I don't know is whether my trans arms are correct. I am willing to say that the front arm is too long and that's why the cable is pushed crooked. Can anybody give me the lengths or anything to verify? Thanks!
marvinmadman
Can anyone go outside and measure their shifter arms for me? /ubbthreads/images/graemlins/cool.gif
EMX5636
Bucks County, PA
1990 shifter arm. Center of pivot rod to center of post about 2.5" 1991 shifter arm about 3.25"
marvinmadman
The 90 would make the cable look straight. But all my brackets are 91+. I don't understand /ubbthreads/images/graemlins/confused.gif
EMX5636
Bucks County, PA
You could tweak the right (pass side) cable bracket a bit to point better at the shifter arm. That's all I could think of is maybe it got bent either being dropped on, pried off of etc. /ubbthreads/images/graemlins/dunno.gif Don't move it further or closer to the linkage, just angle it slightly.
EMX5636
Bucks County, PA
I have seen cables that angle slightly like this though, without any ill effects. Unless you have a bind or hanging up in the cables, you might be worrying over almost nothing.
marvinmadman
Probably nothing. Just trying to take care of any odd things that look out of place before I start putting some miles on it.
ronkonkoma, ny
You can twist the dust boot around so it stacks better. If your not having any issues shifting, it's doing its job.
marvinmadman
It's against the clutch line. That's why it looks that way.
G
zompton
Where is that rubber clutch line coming from and why is it anywhere near the cables? Also that arm does not look right. Nor does that much angle look right.
marvinmadman
Stock clutch line in its bracket G. I know the angle of the cable doesn't look right. That's my reason for checking into this.
