From what I can tell from the pics, the turbo and color is fine.
It's the exhaust manifold leak that's probably killing ya. You can see the leakage from the flange pic on the #4 cylinder exhaust port. And then look at the turbo pic where you can see a crap load of black soot all over your water pipe and the engine side of the compressor housing.
That turbine wheel looks like it's shot. That sucks, man.
Also, your manifold could use a bit of port work. Taking that step out will probably help a bit. Your oil line needs to be replaced. It looks like it's falling apart. I guess when you replace the turbo you can fix that as well.
