What's a safe reading the for stock water temp gauge?
JamesFoster
ALL
Hey guys, I just finished putting my new 2.3L in my galant, and everything seems to run great, but I feel like it might be running a little hot. The factory water temp gauge is getting up near the second line on the gauge, maybe 4
3/4 of the way up. How warm would that be and is if too warm?
As far as cooling fans, I currently only have one spal fan on the pass side of the stock radiator. Would adding another help? I'm just worried about the downpipe/manifold getting it too hot on the driver side.
Thanks in advance.
James
citymunky
Chesapeake, VA
You mean a real water temp gauge.
Anyway to answer your question my stock water temp gauge sits a little passed the half way mark. Once you start making your way near the 3/4's mark, you have a cooling problem.
How many CFM's can your Spal push?
Jason G.
Anderson, SC
By the time it reads hot, it's likely too late.
Personally I've recorded 170-240f on a logger and the gauge never moved from slightly left of the middle area. ymmv.
JamesFoster
ALL
Well, tonight I drained the 50/50 coolant and put a mixture of 70/30, and I also installed dual fans with a shroud, so hopefully that will take care of it. I'll update tomorrow to see what I find.
galantrevolution
las vegas, nv
I have the autometer gauge for the temp and it goes over 210 ,230 but the stock Gauge don't pass tha half way mark
