Galant VR-4 Forums » Galant VR-4 » Technical Discussions » Wideband troubles
Wideband troubles
AuSpecVr4
Galant VR-4 org Post #: 1028367 posted 10/24/11 04:32 AM     Remind Me!  Send Private Message   Edit Post
Hey
I have a innovate MTX-L i want to connect up to my ecu input but can't use pin 15 as an input because no wire or pin is located there on a gvr4. I want to keep my narrow band aswell, i have my wideband on the downpipe, which wire do i use as an input? i just got the car running on SD and have a GM iat sensor installed today.
Cheers.
Posts: 107 | From: Brisbane, QLD | Member Since: 12/01/10 | IP: (60.241.111.35) | Report this post to a Moderator
OMFGeofffff
All I want is a dodgy
567/1000
Galant VR-4 org Post #: 1028370 posted 10/24/11 05:48 AM     Remind Me!  Send Private Message   Edit Post
What are you using for tuning? This should point you in the right direction.
-Jeff
Kensington Grey - A87 stock (EQ/input, no sunroof)
XBL - uh oh its JEFF
Posts: 867 | From: Burnsville, MN | Member Since: 05/05/06 | IP: (24.245.28.159) | Report this post to a Moderator
AuSpecVr4
Galant VR-4 org Post #: 1028380 posted 10/24/11 07:22 AM     Remind Me!  Send Private Message   Edit Post
I use ECMlink, and i've been on that page allot, theres no pin 15 on a gvr4 ecu, all other available inputs are being used,
Eager Beaver
Galant VR-4 org Post #: 1028386 posted 10/24/11 08:50 AM     Remind Me!  Send Private Message   Edit Post
Sounds like you might need a USDM ECU due to it having the EGR circuitry to connect with?
C53A 1 of the ~1500
Posts: 1609 | From: THE Ottawa | Member Since: 03/05/05 | IP: (174.115.196.43) | Report this post to a Moderator
mikus
weiterhin das Huhn f#$k
1994/2000
Galant VR-4 org Post #: 1028406 posted 10/24/11 09:54 AM     Remind Me!  Send Private Message   Edit Post
You just need a pinned wire to stick in the harness #15 position. AUspec & USspec ECU's are both fine to log pin 15
ECU wire pins are easy to pop out, I believe there's a how-to.
If you can't find a pinned wire locally PM me --- I only have one handy but I'm not using it currently.
Edited by mikus (10/24/11 09:42 PM)
Posts: 2763 | From: Aurora IL | Member Since: 01/11/07 | IP: (198.178.234.30) | Report this post to a Moderator
talontyme
Member +
224/2000
1505/2000
Galant VR-4 org Post #: 1029416 posted 10/27/11 02:36 PM     Remind Me!  Send Private Message   Edit Post
I know you said you want to keep the narrow band but why would you if you have a wideband
95 Mitsu GSX-650hp monster
92 Laser RS awd-sold
1505/2000-sold
224/2000-traded
Posts: 329 | From: Portsmouth,VA. | Member Since: 03/16/09 | IP: (66.87.80.139) | Report this post to a Moderator
Brianawd
Higher Launch RPM
439/1000
Galant VR-4 org Post #: 1029460 posted 10/27/11 05:25 PM     Remind Me!  Send Private Message   Edit Post
Junkyard is you friend. Just go find any 90-94 dsm or galant and pull a pin from the plug. Its easy.
1992 Gaylant vr4 #439/1000
11.1at131 562awhp/484awtq
E85 FP3052 parted out
05 EB EVO SSL 11.48at124mph
450awhp/400awtq New 2.3 e85 hks 7460r
05 JEEP liberty CRD DD/ski slut
200hp/385tq
Posts: 2117 | From: Portland OR, | Member Since: 04/18/05 | IP: (134.134.137.75) | Report this post to a Moderator
AuSpecVr4
Galant VR-4 org Post #: 1029770 posted 10/28/11 07:38 PM     Remind Me!  Send Private Message   Edit Post
Thanks, i cut pin 4 and put my output there and simulated narrowband, its all working now, i was just hoping to use both but whats the point.
Cheers
Generated in 0.17 seconds in which 0.156 seconds were spent on a total of 14 queries. Turbo powered.
