FS: 727/2000 sold Asheville NC
Egalloway
Asheville nc
Needs a new home and I need the shop space.
737/2000
228xxx. on chassis
Engine:
Bogussvo new head for 800 hp running kelford 272 and adjustable cam gears
2.0 with 2g pistons
New ACL Race main and rod bearings
“New” crank from a bone stock 2.0 turbo car (probably had ~100k on it, but all dimensions in spec)
3g lifters
ARP head studs
All new gaskets
Exhaust:
New exhaust manifold studs
2g exhaust manifold
3” turbo back exhaust
Meagan Racing tubular O2 sensor housing
Meagan Racing 3” stainless downpipe
Meagan racing resonator
Dynomax muffler
no cat
Go fast/tuning:
AEM wideband O2 sensor
Ecm link on speed density
1000cc injectors
Gizzmo MS IBC electronic boost controller
Bullseye Power Borg Warner S256 turbo (~58 lb/min)
ETS Galant VR-4 specific intercooler
New Autometer boost gauge
Adjustable fuel pressure regulator
Tuned by 3SI in Charlotte
Electrical:
New Battery relocated to trunk
New alternator
New oxygen sensor
New ignition coil pack
New ignition igniter
New NGK spark plug wires
New NGK BPR7ES spark plugs
New idle stop switch
New idle speed control motor
New throttle position sensor
New coolant temp sensor
Clutch/driveline/brakes:
Rebuilt clutch pedal assembly from Shep Racing
New Exedy clutch from Shep Racing
New clutch slave cylinder
Machined stock flywheel (done on a lathe so it's flat and step height is correct)
New flywheel and pressure plate bolts
4 bolt LSD
New passenger side CV boots
New front brake rotors & pads
New rear brake calipers
New e-brake cables
ABS delete with legit Galant GSX non-ABS proportioning valve & brake lines
Suspension:
New KYB GR2 shocks
New strut mounts
New KYB strut boots/bumpers
HR lowering springs
Lubricant/aesthetics:
Amsoil engine oil, filter & transmission oil
Redline rear diff oil
Carbon fiber hood and rear spoiler
3g headlights (I think)
Sunroof
Prior to head work car made 301hp 294tq from 4000 to 8000 held steady power nice and flat at 18lbs of boost on rough tune with speed density on 93 octane. Found out during/after dyno run it had 3 bad valves and needed head rebuilt. So off to dale bogussvo got a full tilt head. Will need tune dressed up with new setup.
Spare 2 g trans and case comes with it for asking price.
Runs but bring a trailer, brand new tires and performance slotted rotors green pads. Garage kept. I’ve owned it for about seven years. Moving on to another car setup for auto to drag race on full race setup.
I've got about 8 grand in it and I'd like 4500 OBO cash only.
828-nine8nine-75five0 Eric I can text additional photos.:O
Egalloway
Asheville nc
4500 come get. Tons of tire kickers and don’t sell it I’m going to get but no cash in hand for it.
gvr4737
New Jersey
I would really love to own my old car again!!! What memories I had in that thing!! 16+years ago
