Galant VR-4 Forums » Marketplace » Cars For Sale » FS: 490/2000 $2500 OBO SOLD
91_427
427/2000
490/2000
Galant VR-4 org Post #: 1233488 posted 11/15/16 04:44 PM     Remind Me!  Send Private Message   Edit Post
I no longer have the time, space, or will to work on this car. I'm asking $2500 OBO. I will not accept paypal for this transaction. Vehicle CANNOT be driven on the street and will need to be trailered. I am willing to work with the buyer to arrange delivery. If there are any further questions please contact me either via private message or directly at CAR IS [email protected]
Here's the background on this car:
I purchased the car in July 2013 from a gentleman in central Texas area. At that time the car did not run because the engine wiring was disconnected in preparation for an engine removal. The PO had plans to get the engine built, but didn't end up going that route. I trailered it back to Arkansas where it was stored for the next 2 years under a carport and car cover. I then brought it with me to New Jersey when moved there for school. At that point I was able to reassemble the vehicle and get it running again. One fine sunny day I decided to replace the cracked stock manifold. In the process of doing that one of the exhaust studs snapped. In the process of trying to extract the broken exhaust stud I damaged the head. I then replaced the head and timing components. After reassembly the vehicle runs very rough. I'm very confident that I performed the timing belt replacement correctly and the engine is mechanically in time. I believe the rough running issue is due to a combination of boost/vacuum leak, an out of date tune (has DSMLink V3 full),and the CAS (camshaft angle sensor) being out of adjustment. I no longer have anywhere to work on this car let alone any free time to do so.
Body/Suspension/Brakes
170,XXX Miles/ Clean Title
Southern Vehicle! Minimal rust!
Non-Sunroof Model
Polyurethane Bushings throughout/ subframe/ control arms/ etc
New 1G power steering rack
New inner and Outer tie rods
Evo 8 rims and new tires (less than 500 miles)
Full ABS delete with GGSX proportioning valve
Braided steel brake lines
5 lug conversion
Both front control arms replaced
Engine
Stock 2.0 4G63T
Felpro Head Gaskets and head studs
Gates timing components
Gates waterpump
180* thermostat
New accessory drive belts
Prothane engine mounts
New spark plugs and wires
Drivetrain
Original transmission and clutch
4 bolt rear lsd differential
Redline Fluids
Metal Carrier Bearing bushings
Metal shifter end and shifter base bushings
T/E/L shortened Shift Lever
Greddy weighted shifter
Fuel and Ignition
FIC 550cc injectors
Walboro 255 Fuel Pump
-6 line from pump to fuel rail
Aeromotive Fuel Filter
Fuel pump rewire
Fuellab Fuel Pressure Regulator
Turbo/Exhaust/Intake
OEM turbo, piping, and intercooler
GM MAF 3"
Full 3" exhaust with magnaflow single tip muffler
Exhaust manifold tapped with EGT probe installed
ISC/FIAV delete
Profec Manual boost controller
Interior and Misc
Manual seat belt conversion on both front seats
DSMlink V3
Greddy shift knob
89 underdash cover
All ac components installed on car, but system either needs recharged with R-12 or retrofitted to R-134 (had to drain system to remove drivetrain)
Optima red top battery relocated to trunk with 0 gauge wiring
1G washer fluid reservoir relocated to where oem airbox used to be
THE BAD
Transmission grinds a little on 1-2 shift @rpms over 3000 ( I have a bmtranny stage 2 transmission that can be included for the right price)
Needs an alignment badly
Runs pretty rough
Needs a tune (DSMlink V3)
PO removed spoiler so there are holes in trunk lid
Front grille missing clips
Hood slightly bent on D/S
D/S a pillar has small rust spot (see pictures)
D/S a pillar interior trim piece missing
Headliner has multiple stains (see pictures)
Edited by 91_427 (03/28/17 09:18 PM)
Posts: 101 | From: South Jersey | Member Since: 04/02/12 | IP: (2601:83:8002:272) | Report this post to a Moderator
91_427
427/2000
490/2000
Galant VR-4 org Post #: 1233489 posted 11/15/16 05:03 PM     Remind Me!  Send Private Message   Edit Post
427/2000-Designated Donor
490/2000-Newest Project Pending EAS
Htech1982
Newbie
Galant VR-4 org Post #: 1233891 posted 11/30/16 06:28 PM     Remind Me!  Send Private Message   Edit Post
Still for sale? I'm in Gettysburg and am motivated to buy.
Posts: 1 | From: gettysburg | Member Since: 11/30/16 | IP: (66.87.80.43) | Report this post to a Moderator
91_427
427/2000
490/2000
Galant VR-4 org Post #: 1233929 posted 12/01/16 09:44 PM     Remind Me!  Send Private Message   Edit Post
Yes it is still for sale.
Romanova
the coolest person to ever post in the past 2 hours
Galant VR-4 org Post #: 1233951 posted 12/02/16 04:17 PM     Remind Me!  Send Private Message   Edit Post
This was my old car. Wish I had the space and time for it. Good luck with the sale!
tyler
2016 Explorer PI
2006 LS430
2012 GX460
Posts: 3855 | From: Cypress, TX | Member Since: 08/07/02 | IP: (50.162.93.211) | Report this post to a Moderator
91_427
427/2000
490/2000
Galant VR-4 org Post #: 1234529 posted 12/30/16 09:33 AM     Remind Me!  Send Private Message   Edit Post
Updated price to $2500. Will also come with rebuilt transmission and any extra parts I have. Need it gone soon, and will deliver within a few hours if I get some gas money as well.
91_427
427/2000
490/2000
Galant VR-4 org Post #: 1234864 posted 01/23/17 03:37 PM     Remind Me!  Send Private Message   Edit Post
Sold
PJGross
both buccal and lingual
490/1000
Galant VR-4 org Post #: 1235116 posted 02/03/17 02:06 PM     Remind Me!  Send Private Message   Edit Post
PM me if the new owner wants both 490's, I have 490/1000....
-PJ
#490/1000
Posts: 1519 | From: Lake Orion, MI | Member Since: 12/05/02 | IP: (50.232.255.42) | Report this post to a Moderator
turbofonz
Member +
255/1000
153/2000
369/2000
490/2000
Galant VR-4 org Post #: 1235119 posted 02/03/17 05:33 PM     Remind Me!  Send Private Message   Edit Post
I am the new owner. Hmmm....
Ryan W.
Posts: 439 | From: Granby, MA | Member Since: 09/27/06 | IP: (73.142.6.86) | Report this post to a Moderator
l8apixvw
1984/2000
Galant VR-4 org Post #: 1235197 posted 02/07/17 01:09 PM     Remind Me!  Send Private Message   Edit Post
Still for sale would u be willing to trade for a running nicely modded 2000 mkiv GTI 1.8t
Tune 4 Life
Posts: 41 | From: wny nj | Member Since: 09/08/08 | IP: (2600:1017:b406:4) | Report this post to a Moderator
Generated in 0.127 seconds in which 0.081 seconds were spent on a total of 14 queries. Turbo powered.
