FS: 91 GVR4 371/2000 Memphis ,TN $3800 SOLD
blackeagle92
New member
memphis,tn
The time has come to part with my vr4. Mostly stock it has 174,xxx miles on it original motor. I have had it for 4 years almost.The body is in good condition it has its dents and dings and scratches. The underneath is good as well with no rust. It has been in memphis area as far as I can tell for its life.
Transmission:
It does not have the original transmisson in it but, I do have it. It just needs to be rebuilt as the bearings are shot.
ECU:
The ecu was fixed by ecm tuning due to bad isc left plugged in and shorted out driver. When there it had new caps put in and had socket put in for eprom chip.
Engine:
2 years ago the all timing belt components were replaced oem bearings and tensioners and gates timing belt and balance shaft belt. All timing belt oil seals replaced cam, crank, oil pump ,balance shaft plug front case gasket, oil filter housing, rear main seal,head gasket, valve stem seals, 99 lifters, water pump, intake manifold gasket ,all coolant hoses replaced,plugs and wires, kyb front struts and strut mounts. Only 10k miles have been put on since all those items replaced.
Turbo:
The turbo is 14b which is in good shape but , it is in a 7cm exhaust housing and it has evo 3 exhaust manifold. The air can was hacked when I got it.
Fuel:
It has a evo 9 fuel pump and fuel pump rewire. everything else is stock.
Brakes:
Just had new rear brakes and rotors put on. Front brakes still have plenty of life.
I am asking $3800 but am open to offers.
kdott96
Valley Stream, NY
Helo I sent you a private message, please get back to me when you get the chance, I'm very interested in this beauty, thanks!
4orced4door
Moderator
Raleigh, NC
Looks like a nice car, mostly unmolested which is getting pretty hard to find. Should be easily worth your asking price!
gvr4ever
central Indiana
Nice car. Not too many southern ones come up. Good luck with the sale. Sadly, I don't have the will to own a 2nd one.
evoquon
Active member
Cali
Too bad I am oversea right now. Love to pick this up if it not sold by then. /ubbthreads/images/graemlins/banghead.gif
blackeagle92
New member
memphis,tn
Car is sold as of today. I just want to thank everyone for showing interest on it. Special thanks to the board members for letting me put it for sale on here.
Thanks again
Jeff
strokin4dr
Savannah, GA
Show your appreciation to the board by ensuring it's future. CLICK HERE
Buduzka78
Florida
Hello guys I am the proud owner of #371. Jeff it was a pleasure doing business with you. Thanks for your honesty it was worth to drive almost 30hrs round trip.
Now his next to #1115/track/street car.
4orced4door
Moderator
Raleigh, NC
Congrats to the new owner and to the seller for the quick sale. I knew this one looked like a good buy!
