FS: 1991 Galant VR4 NorCal *SOLD*
DeadDuck
New member
Chico,CA
*SOLD*
Selling 1373/2000. This has been a good car for the couple of years I've had it, but I don't drive it much anymore and I'd like to see it go to someone who will.
The Goods
Engine was replaced before I bought it (I have paper work for this)
Larger intercooler, I thinks its an old ARC unit, its about the size of a starion intercooler
2.25'' piping
Synapse Engineering recalculating BOV
2G throttle body elbow
Good 14b turbo (no shaft play)
Hallman manuel boost controller
Had the ECU rebuilt by ECM Tuning, also has an unknown chip
Rewired fuel pump
Feal coil-overs
White Line sway bars front and rear
Most of the car has urethane bushings
Steal braided brake lines
5 lug swap with new brakes
DSM power steering rack installed, 4 wheel steer has been removed
Enkei Evo 8 wheels with new tires
Strut bars front and rear
The Bad
Paint is starting to fade on the hood
Clear coat is starting to break down on the spoiler
The urethane bushings make the rear diff. noisy
I rebuilt the drive shaft and mixed up the shimming for the hanger bearings so there is some noise on decel. I've been playing around with it and got it pretty quiet, but its not perfect.
I think the front axles should be replace soon, it has a slit vibe when you start to accelerate
A/C has been removed
Small tear on the drivers seat
The dash has just started coming unglued by the defrost vent
It also comes with a manuel steering rack, an extra t-case and a 4 bolt rear diff. with axles. I had the diff. rebuilt, drove on it a couple of months and it started making noise. Not sure whats wrong with it. There is a 3 bolt installed now.
Let me know If you have any questions
Erik
G
zompton
Looks nice. Engine pics?
DeadDuck
New member
Chico,CA
I keep forgetting stuff. The car has just under 150,000 miles. I also have a DSM 5 speed trans. and a light weight flywheel to go with it.
