FS: 91 Galant VR-4 Hanover PA $3000 OBO
dsmtalontsi95
Glenville, PA
Unfortunately I need to move the Galant. We are looking to move soon and I wont have space for it nor do I have time to work on it. The car does run. The car has developed a horrible water leak. I believe it is coming from the water pipe behind the turbo. I think I didn't dent the water pipe enough and the turbo wore a hole into it. A new water pipe and a tubular manifold will fix this. I wanted to put on -AN fittings but never got around to it. I had the car for a while with the intensions of keeping it. Things change and life happens. The motor has a really good bottom end (ARP everything). On to the good and bad. You can text me at 443-677-8647 Motivated to sell.
Bad:
front bumper.
Rust on the hood
Water pipe is leaking around the turbo
1 black wheel and 3 green wheels (came that way)
vinyl dash is separating from it self
Clear coat is half way off
Coolant temp sensor doesn't work
Windshield is cracked
Good:
Motor
Evo9 piston and 1g rods
ARP rod bolts
ARP mains
ARP Head studs
Trans:
ACT 2600 clutch
Clutch line from Master to Slave cylinder
New Master
New Slave
Turbo:
Frank 4 (old school)
Tail V-Band 38mm
O2 dump
2g manifold
Intake:
ETS intake
ETS fmic
Turbo XS BOV
Misc:
3" TBE with cat
DSMLink
Non cruise cable
255 fuel pump
Motor mounts
I was going to post this link as I just saw this on Tooners.
GLWS!
